Old 03-01-2017, 01:36 AM   #43
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Yup. That's all there is to it.
Oh my god.....why couldn't the damn Firestone guy just do that real quick.....My damn car was already on the lift.....that @jamal guy was right omg lol. I'm praying they get my alignment right when I go back there.
Alltezza is offline   Reply With Quote
Old 03-01-2017, 01:39 AM   #44
lol, I'm sure a bunch of us were scratching our heads.
Live & learn
strat61caster (03-01-2017)
Old 03-01-2017, 03:49 PM   #45
Alltezza
Alltezza's Avatar
Alright got another update.
So I provided them with these instructions, tell me what you guys think of the comment(I honestly don't know what that means.... explain like I'm 5 I thought you adjust camber with camber plates?) about the negative front camber. From the looks of it, it looks he pretty much got close to where I wanted to be A different guy did it this time.
Tell me what you guys think.
Heres the before.
And here's my after/current. The only question I have is that, my before alignment settings(The one above) are different than my previous post after it got aligned the first time, is it not supposed to stay the same?
(http://www.ft86club.com/forums/showp...8&postcount=22)
Old 03-01-2017, 06:19 PM   #46
Lust
Drives: 2017 Subaru BRZ
What's up with your rear toe
Lust is offline   Reply With Quote
Old 03-01-2017, 07:02 PM   #47
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Heres the before.
maybe the tech did not realize that you had top mounts to adjust settings. another method to adjust camber is at the hub where some coilovers have a "slotted" top hole, (alternatively, many people use 'camber bolts' for adjustments at the hub):
seeing as they were able to get the after to -2.1, i assume they figured out you had adjustable top mounts.
your settings may have changed from the previous time if the suspension had "settled" a little after having been driven around for a bit (i.e. your coilovers were brand new and you had the car aligned immediately after install the first time).
looks like they got lazy with the rear toe and said good enough once it was "within range."
i'm not a big fan of the 'lifetime' alignments, but i did not have the greatest experiences with them.
asdf is offline   Reply With Quote
Old 03-01-2017, 07:11 PM   #48
Alltezza
Alltezza's Avatar
Oh my god...I just looked at the sheet when @Lust was like Whats up with that rear toe and I noticed how much a difference it is from the left and right side...... .13 difference
How hard is it to do an alignment? Can I just go under my car and fix it myself or is it a lot harder than that? I honestly want them to do it since I just threw 200 bucks at these guys.
Old 03-01-2017, 07:39 PM   #49
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
It is harder than that, I guarantee you will make it worse.
You can absolutely do it yourself without spending money on tools, but it takes a lot of time, precision and patience.
ineedyourdiddly
Ultramaroon (03-01-2017)
Old 03-01-2017, 08:11 PM   #50
nocoolname
To me, it looks like the firestone guys are kind of lazy. Next time ask them if any of their guys are certified by Hunter since they're using their machine.
On the difference of toe, looks like suspension settled. If one was toe out and the other was toe in then the alignment guy wasn't paying attention and pulled on the rack a bit crooked.
With the note on saying the top strut bolt hole needs slotted, sounds like he's just going by the recommendations from the alignment machine and either didn't mess with or didn't even look at the top hats. I'll throw my car on the rack this weekend just for curiosity on what Hunter recommends for adjusting camber
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
Old 03-01-2017, 10:01 PM   #51
cjd
cjd's Avatar
Drives: 2017 BRZ
I wonder if I have enough battery life and card space to try to catch the whole process... I'll be going under this weekend, full balance and alignment. I can't wait. And I spent a little money on tools, but it'll pay for itself in the next year, two at most. If I don't hate myself too much first.
I did get a set of initial measurements before I started swapping parts and found some slightly unexpected numbers on camber, especially in the back. I have a sneaking suspicion on why, which makes me glad I got the equipment to do this myself... These lovely alignment sheets I see sure help me feel slightly better.
The Following User Says Thank You to cjd For This Useful Post:
Racecomp Engineering (03-02-2017)
Old 03-01-2017, 11:11 PM   #52
jamal
jamal's Avatar
Drives: Legacy GT
The numbers are green so it's fine!
jamal is offline   Reply With Quote
The Following 3 Users Say Thank You to jamal For This Useful Post:
asdf (03-02-2017), strat61caster (03-01-2017), Ultramaroon (03-01-2017)
Old 03-01-2017, 11:17 PM   #53
strat61caster
Make sure your floor is level or you get some way to have the car level or you'll get incorrect camber measurements, we were seeing +0.2 degrees on one side and -0.2 on the other, so bang on perfect without leveling the car was 0.4 difference left to right.
And the rear toe links need to be torqued to like 75 ft-lbs, I was under torquing mine and they were slipping on me most of last year.
I pretty much budget at least half a day to measure and tweak something and then measure it again. That's the advantage of those fancy alignment racks, they can tweak while measuring and knock it out in an hour or so.
ineedyourdiddly
cjd (03-02-2017)
Old 03-01-2017, 11:23 PM   #54
Lust
Tech would probably respond, "but its in spec" lmao
Old 03-01-2017, 11:26 PM   #55
Hyper4mance2k (03-25-2018)
Old 03-02-2017, 08:42 AM   #56
cjd
cjd's Avatar
Drives: 2017 BRZ
I'll be starting by rechecking the leveling... It'll be as close as a digital level and a laser level can get me.
strat61caster (03-02-2017)
--00 (rev) or redline setting -Willis-86touge Issues | Warranty | Recalls / TSB 29 06-01-2016 04:05 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
Setting up for a night Chen Northwest 15 09-20-2013 03:10 AM
This is how I pan on setting my car up where does it put me jdzumwalt Tracking / Autocross / HPDE / Drifting 16 02-10-2013 10:24 PM
