Old 02-28-2017, 08:51 AM   #15
czechm8
520
czechm8's Avatar
Drives: Series 10 Fr-s #520
Originally Posted by LowAndSlowBecauseNoTurbo View Post
so I'm looking into getting this LOC
http://www.autozone.com/stereo-speak...ter/272463_0_0
and I'm wondering if I can just splice into my wire that runs straight from my rear speaker or if I have to go through my wire harness?
Yes, that will work.
For God's sake, don't just tap into the high level speaker wires and connect it to the low level inputs of your amp! You'll cook the amp and probably start a fire.
As suggested, use molex connectors if possible for a clean, easy to undo connection. Make sure you fuse the power wire to the new amp as well.
Do not use your teeth and electrical tape, ever!
czechm8 is offline   Reply With Quote
Old 03-01-2017, 10:18 AM   #16
FRS 10 series #0239
LowAndSlowBecauseNoTurbo's Avatar
Drives: #0239 FRS 10 series silver ignition
hahahaha I'm not one to use electrical tape and wrap open wire. ill use beans and splice the wire before that I did use these http://www.autozone.com/ignition/ele...uestid=1925470
and they worked damn fine and I've gotten her all hooked up. thanks again
Drop in K&N filter, CX Racing oil cooler, Tomei Expreme UEL headers, Invidia N1 Catback, OFT stage 2, Raceland coilovers, stage one Exedy clutch kit, Stoptech drilled and slotted rotors and Hawk HPS street pads
10 series #0239
LowAndSlowBecauseNoTurbo is offline   Reply With Quote
amp, rca, subs, wire harness
How to use the OEM amp Wiring RandomHero Electronics | Audio | NAV | Infotainment 258 07-04-2024 12:34 PM
Wiring in IAT for SD mrk1 Software Tuning 13 04-14-2023 08:15 AM
Need some help with some wiring timmydatooth Scion FR-S / Toyota 86 GT86 General Forum 41 08-14-2015 09:10 PM
Wiring for DRL Yap Cosmetic Modification (Interior/Exterior/Lighting) 2 01-19-2015 01:13 AM
LF VA Wiring Help OURO3OROS Mid-Atlantic 0 02-23-2014 08:24 AM
