Old 05-14-2014, 11:08 AM   #1
mrk1
Drives: Sterling BRZ Ltd
Wiring in IAT for SD
Has anyone installed an aftermarket air temp sensor for speed density. I am trying to find a diagram that labels the wires to MAF so I know which to splice into.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-14-2014, 11:13 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Electrical Wiring diagram.
http://www.ft86club.com/forums/showthread.php?p=1166113
Why not use your stock MAF for SD IAT?
Old 05-14-2014, 11:20 AM   #3
mrk1
Thats what I was looking at, can someone smarter then me decode the labels. I know +B is power.
The Build Thread
Old 05-14-2014, 12:32 PM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
not sure how much this will help since they're not color coded, but here's a photo of fa20club's external IAT harness for the maf sensor. The two wires on the left are the IAT wires. the right 3 are MAF wires.
Old 05-14-2014, 03:42 PM   #5
mrk1
so does that end plug into the maf connector on the stock harness?
The Build Thread
Old 05-14-2014, 03:47 PM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
Yep, then one end coming off of it goes to the stock maf sensor, the other end goes to your IAT sensor.
The Following User Says Thank You to xjohnx For This Useful Post:
Sportsguy83 (05-14-2014)
Old 05-14-2014, 03:57 PM   #7
mrk1
ok cool I think I can reverse think that out, awesome
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
Old 01-13-2015, 12:06 PM   #8
blown
Drives: ft86
figured out what e2 and THA mean?
blown is offline   Reply With Quote
Old 01-17-2015, 02:02 PM   #9
blown
Drives: ft86
bump
Old 01-17-2015, 02:21 PM   #10
mrk1
I was never able to make this work
The Build Thread
Old 01-17-2015, 10:35 PM   #11
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
THA is your air intake temp
E2 is sensor ground
B+ 12v power
E2G and VG must be the maf signals.
Kotu100 is offline   Reply With Quote
Old 01-18-2015, 05:32 AM   #12
Kodename47
Kodename47's Avatar
Drives: UK GT86
I have done this to mine so it's possible, however I haven't had my car recently to be able to help. From memory you only need two wires and it doesn't matter on polarity. I pretty much just used the picture from above and I had the same connector in my hand.
I might have access to my car later so I'll see if I can get a photo for you.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-14-2023, 07:51 AM   #13
Nawar
Drives: 2016 Red GT86
Hey man its been a while, hope you see this.
Im confused to which wire should i splice into?
are they the Green and Red?
Nawar is offline   Reply With Quote
Old 04-14-2023, 08:15 AM   #14
tomm.brz
Drives: brz 2017 hksv2
No it s the green and the one right next to it
Green is pin1, so you cut green cable and the one next to it (pin2) and connect them to the external IAT
the sensor usually has no polarity
How to use the OEM amp Wiring RandomHero Electronics | Audio | NAV | Infotainment 258 07-04-2024 12:34 PM
LF VA Wiring Help OURO3OROS Mid-Atlantic 0 02-23-2014 08:24 AM
Rear fog wiring Gunman DIY (Do-It-Yourself) Guides 0 02-17-2014 08:26 PM
Wiring a sub in a BRZ Shizuma Electronics | Audio | NAV | Infotainment 22 06-08-2013 01:02 PM
So is there a DIY yet for BRZ headlight wiring for the FR-S? seven Cosmetic Modification (Interior/Exterior/Lighting) 4 11-25-2012 09:24 PM
