Drives: 02 Toyota 4Runner
Dipstick leak vs Timing Chain Cover
So I picked up my new to me 13 BRZ limited today with 59k on the clock. I didn't notice the burn oil smell after i test drove it, and I somehow missed the leak visually inspecting it. I've searched some and continuing to do so, but I'm in slight panic mode currently. Anyone have any advice on whether or not this is the timing chain cover leaking or the dipstick? I don't have a warranty, and bought from a private seller, clean carfax and the car has otherwise been well maintained. I haven't found much in the way of a DIY resealing the timing chain cover, am I missing a huge thread on this?
#2 |
Hard to tell where it is coming from
Here is everything you need to know about diagnosing and repairing all the usual leaks. http://www.ft86club.com/forums/attac...1&d=1413834741
| The Following User Says Thank You to Tcoat For This Useful Post: | Traffic (02-26-2017) |
#3 | |
#4 | |
humfrz |
#5 | |
![]() Your pictures don't show up for me. I would suggest that you clean up the area that is seeping oil and observe where it starts to reappear. As far as a DIY removal and reseal of the timing chain cover, I figure that would be a really BIG DIY job you may wish not to take on. I hope you get it sorted out. humfrz |
#6 |
So yesterday I saw build up on the front of the timing cover and assumed that's where the leak and smell were coming from. Turns out my rear cam plate was leaking and definitely causing some smells. I cleaned everything up and will continue to monitor everything to see if there are any other leaks, but in the mean time I have a Raceseng cam plate on it's way to me!
Thanks again for the help. I'm in love with this car. I feel like you can almost judge a car based off the forums dedicated to them, and with that said, the 86 seems to be a big winner. |
| The Following 4 Users Say Thank You to jpeaslee For This Useful Post: |
#7 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
I know you originally messaged me about my wheels for sale, but I l've actually gone through about 30,000 of oil leaks on my BRZ during ownership thus far, I can't see your pictures and I know you found some oil near the rear cover, but if it comes up again send me some pictures. I had the "timing cover" problem and it turned out being my half blocks splitting apart from the front-center->back... So I know those signs now too lol. The fix was a new short block... So i hope for your sake that it's a cam-plate, those are easy!
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
| Oil leak - timing chain cover | CB762 | Issues | Warranty | Recalls / TSB | 3 | 08-24-2016 04:45 PM |
| Can Toyota's 103 FIPG silicone be used in timing chain cover? | Astroboy | Engine, Exhaust, Transmission | 16 | 08-24-2016 12:16 PM |
| Timing Chain Cover Leak | alexand3r | Engine, Exhaust, Transmission | 17 | 09-29-2015 11:05 AM |
| TSB for P1604 with no CEL; Startability Malfunction/Timing Chain Cover replacement | Hector | Issues | Warranty | Recalls / TSB | 1 | 03-01-2015 08:01 PM |
| Timing Chain Cover Replacement - Need Advice | Gen | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 04-02-2014 12:15 PM |
