#15 | |||
Seriously? SMH ![]() Quote:
#16 |
Exactly as I stated in my first response.
#17 |
Oh, shit. I was too fired up to read through your whole post. I just read "Get the code read [more stuff trying to actually be helpful] ..."
And I just shut down. ![]()
#18 | |
[insert cool phrase here]
Drives: BRZ Premium
Something tells me your google-fu is getting rusty.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#19 | |
![]() humfrz |
#20 |
Weight Weenie
Drives: 15 FR-S
Have you had the air filter out at all?
If so, make sure it was put back in correctly and that it is seated properly. |
#21 | |
Drives: 13 Subaru BRZ
Sent from my Moto G4 Plus using Tapatalk |
| The Following User Says Thank You to ybotspawn For This Useful Post: | guybo (02-26-2017) |
#23 | |
OH and a Google search of "what does a cel on my car mean?" did not have one response that said to read the code in the top 10 responses. They all either give the top 5 most common reasons (so pissing in the wind) or said to see your mechanic. So even at just being told to read the code he was ahead of the game by asking here where we at least said we are clueless without a code.
#24 |
Drives: 2017 BRZ - WRB
Well my OBDII scanner is coming in tomorrow.. But in the meantime I was thinking that although theoretically the catback exhaust itself has no sensor on it, is there still a possibility to get a CEL from changing it out?
| The Following User Says Thank You to Oxyg3n For This Useful Post: | Tcoat (03-01-2017) |
#25 |
Nah. You're safe with that. Not even near any wires/sensors.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (03-01-2017) |
#26 |
Drives: BRZ DGM Limited
Use the scanner when it comes and report back with the code. The good thing is since it is running fine with the code, and since it is a new car, it is most likely not serious plus any fix will be covered. But I am with you and would be very annoyed to get a code on a new car!
#27 | |
Drives: 2016 Subaru BRZ
I just bought one of these to help chase down a misfire in my truck and I was kicking myself for not spending the $25 to get this in the first place. Prior to that, I'd been out there swapping coils and boots and plugs and injectors like a real mechanic. It's like doing long division when there's a TI-83 sitting right there. |
| The Following User Says Thank You to Da Brz For This Useful Post: | Tcoat (03-01-2017) |
#28 |
Drives: 2015 FRS Asphalt
Your car is brand new....just take it back to the stealership....you have a new car warranty which you'll have to eventually take it back to them to fix the issue....
| The Following User Says Thank You to 86geek For This Useful Post: | JazzleSAURUS (10-09-2017) |
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 09:39 AM |
| Engine Check light, Traction Control light, cruise control light all on suddenly | wqc3241 | Software Tuning | 2 | 01-10-2016 07:37 AM |
| Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? | djdrugga24 | Issues | Warranty | Recalls / TSB | 3 | 06-25-2014 06:06 AM |
| Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
