Old 06-28-2012, 11:45 PM   #71
Oriental Life
Oriental Life's Avatar
Drives: Forester 2007, BRZ Limited '13
Guys, relax. OP is in SoCal, which means 91 octaine fuel. We simply don't get higher 93 octain in Cali.
The fact that engine shook and RPM dropped prior to the light appeared, lead me to believe that its a detonation. Why? DI + port injection switching.
Give both companies some time to gather more cases and stats. Demo cars had 10K + miles on them during some reviews we read back April. I'm sure it would come up if it was THAT big of a deal.
Take notes and bring those to your dealers. Meanwhile get gas only from reputable gas stations.
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
Oriental Life is offline   Reply With Quote
The Following 2 Users Say Thank You to Oriental Life For This Useful Post:
Linseal (06-28-2012), W2 (06-28-2012)
Old 06-28-2012, 11:50 PM   #72
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
While that may be a contributing factor, it shouldn't start throwing CELs from 91 vs 93. Even the lowest grade fuel should 'work' but just not optimally. This is a 2013 car, I doubt it's that sensitive to fuel grade to the point it starts having idling issues and throwing codes.
Also, to Toyota's credit, they've beat Subaru in reliability for the last decade on both year-old and 10-year old cars.
eriktherod is offline   Reply With Quote
Old 06-29-2012, 12:11 AM   #73
Oriental Life
We don't know anything about OP fuel. Numbers written on the wall are nothing. Deponation could trigger CEL and its a nasty one to figure out via codes - they are all over the board.
Old 06-29-2012, 12:13 AM   #74
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by Oriental Life View Post
Oh, now you remembered that its a Subaru! :-) How about the fact that issue may lay in the ONLY part that Toyota provided - DI. :-)
You guys make me smile:happy0180:
actually the valve timing was left to toyota because of D4S
toyota was in charge of
1. money
2. exterior
3. D4S( injection)
4. the Diff
5. transmission(both manual and automatic)
6. intake
7. keyless
8. power steering(its actually tech trickled down from the LFA!!)
9. interior design
10. electronics(buttons, ergonomics of the cabin)
11. areo dynamics
12. exhaust tuning/development
13. all the glass window( thicknesses, auto up down, uv protection)
14. airbags
15. frame design(types of metals used/crash testing)
subaru
1. suspension
2. engine donor
3. chassis
4. homelink
5. driveshafts
6. brakes
7. wheels
8. making the car
9. carpets
10. Frame design (ring shaped designed)
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following 7 Users Say Thank You to carbonBLUE For This Useful Post:
BlaineWasHere (06-29-2012), excited86 (06-29-2012), gdi2290 (08-29-2012), Linseal (06-29-2012), rice_classic (06-29-2012), Sciontissst (06-29-2012), Septic (06-29-2012)
Old 06-29-2012, 12:18 AM   #75
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Cam sensors/alignment/engine internals (sans DI) are from Subaru, not Toyota. Don't try to be a fanboi and pin things on the other "parent". The twins belong to both companies and the most important thing is they work together to settle the issues quickly and efficiently.
Hawaiian is offline   Reply With Quote
Old 06-29-2012, 01:50 AM   #76
dirk_diggler
Drives: 2011 BMW 328i Coupe M-Sport 6MT
Originally Posted by the_3d_man View Post
Dealerships are always so quick to say that the ECU must be defective. I've NEVER seen a car with a bad ECU. They don't just fail but I know so many people who in the process of trying to diagnose a problem have had the dealership replace the ECU. It's just the answer that dumb service techs like to give.
ECUs can and do fail, especially if they are exposed to the heat and NVH of the engine bay. Sometimes it's a design fault, like the 90's Jeep Grand Cherokee ECU. These cars also had really bad main harnesses. A harness in good shape goes for $400+. Ask me how I know.
The JGC had all of the above going for it.
dirk_diggler is offline   Reply With Quote
Old 06-29-2012, 01:56 AM   #77
eriktherod
When you mention a Chrysler from that era, it says it all to me. My dad had one of those Chrysler vans from that same time period, eugh..
Old 06-29-2012, 02:07 AM   #78
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
I've put over 3500 miles on my FR-S, driven all over the southwest....giving her all the chances I could to break on me.
Pscylo is offline   Reply With Quote
The Following 2 Users Say Thank You to Pscylo For This Useful Post:
eriktherod (06-29-2012), Spartan65 (08-12-2012)
Old 06-29-2012, 02:18 AM   #79
w arghh x
[I 86 I]
w arghh x's Avatar
Drives: Toyota 86 GT
Its interesting because here in Aus we are told to run 98octane (95 at a minimum) and in Japan I'm fairly certain their fuels are 100octane.
I wonder if there is a difference between quality of US vs AUS/JPN fuels or if the US market cars have been de-tuned to suit etc..
w arghh x is offline   Reply With Quote
Old 06-29-2012, 02:24 AM   #80
eriktherod
I believe the fuel trims (ECU maps) are different for each region.
I remember when I would reflash the ECU on my Si, the Hondata stock maps for various regions were different and even some of the ECUs themselves were different.
Old 06-29-2012, 02:43 AM   #81
Oriental Life
:happy0180: Read my sarcasm between the lines! Peace!
Old 06-29-2012, 02:46 AM   #82
Oriental Life
There is a differense. US 91 come as 95 EU. This car needs 98 EU. I guess its the same for you as well. Need tl look it up, but not in the mood.
Old 06-29-2012, 02:50 AM   #83
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
The octane discussion is entertaining but it doesn't address the problem.
It says in the manual that 91 will do the job fine - most likely the ECU has been tuned to it then.
Old 06-29-2012, 03:35 AM   #84
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I never had this problem when I lived in MI, but out here in CA I find if I stray from Shell or Chevron you can get bad fuel. Stations like Rotten Robbie and other cheaper stations would throw CEL in my GTI, which is a DI motor.
My car is in and still 1,304 miles away! joshua BRZ First-Gen (2012+) — General Topics 16 06-28-2012 09:02 PM
Some Miles White_OUT_FR-S Scion FR-S / Toyota 86 GT86 General Forum 0 06-22-2012 03:00 PM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 10:50 PM
Check Engine Light directly after pickup Stu L Tissimus BRZ First-Gen (2012+) — General Topics 27 06-15-2012 06:07 PM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 06:06 PM
