| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#71 | |
Drives: 2016 WRX, 2016 Corvette Z51 3LT
#72 |
Drives: Neptune GR86
The 17 is geared "better" as far as power delivery is concerned.
#73 |
Drives: '22 WRB
#74 |
Drives: 2017Crystal White Pearl BRZ Limited
If I'm being totally unbiased and honest... I'm scratching my head over the purpose
of 1st? 1st gear is really short and parasitic on adding to the acceleration time between a 1 and 2 shift,. maybe 2 through 6 and add a 7th gear for better (slightly taller?) ratios. |
#75 | |
![]() Quote:
I agree with you totally on the tyres offerings. I too had to purchase "practical" performance tyres if I dared drive all season weather. Case in point tho.. They have a PP offering with a 7.5" wheel (to clear the Brembo calipers..I get that) but use the SAME tyres @ 215 now STRETCHED SILLY rather than a proper 225 tyre fitting the wheel width... |
#76 | |
Drives: 2017 Series.Yellow + Perf Package
On stock tires, ABS was hit early and often. A set of MPSS fixed that. Now it stops like an accident happened.
#77 | |
Your right though, if you are just putting around town, you dont need these brakes. |
#78 |
225 MPSS fit perfectly, look great on the 7.5" wheel. Best $641 you can spend today.
#79 | ||
Proud of BOXER
Drives: Subaru Boxer
Yeah the decision to stretch the 215s versus using 225s is bizarre and disappointing.
| The Following User Says Thank You to Clipdat For This Useful Post: | Lateral G (02-24-2017) |
#80 | |
| The Following User Says Thank You to Lateral G For This Useful Post: | funwheeldrive (02-24-2017) |
#81 | |
Reads that a 17 inch x 9" width 35mm offset has no clearance fender issues with a stock suspension. Sounded great but then closes with "if using standard tyres." This is confusing. Do I use a 215 tyre on a 9 inch wheel???? Why would I want to do that? Bizarre. |
#82 | |
Drive From Home
Drives: BRZ STI Performance
![]() Not all 215 tires have the same exact width. I've seen the Performance Package car at the autoshow two weeks ago and it looks fine. Here are my 215 width Michelin Pilot Sport A/S 3 tires (a little wider in real life than the stock Primacy HP) on 17" x 7.5J JDM STI wheels. |
| Specs for BRZ Performance Package wheels? | ~el~jefe~ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 04-17-2020 06:31 PM |
| To get the Performance Package or Not? Thread | Zaku | BRZ First-Gen (2012+) — General Topics | 141 | 12-06-2016 10:04 PM |
| Someone tested the Performance Package... small but SOME info at least | ~el~jefe~ | BRZ First-Gen (2012+) — General Topics | 13 | 11-29-2016 04:21 PM |
| 2014 Subaru BRZ (Aozora Package Review) | sik20fan | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 14 | 07-29-2015 04:10 AM |
| Crawford Performance BRZ (450 HP) review by Matt Farah (Drive) | switchlanez | BRZ First-Gen (2012+) — General Topics | 66 | 09-20-2014 01:31 PM |
