Old 02-21-2017, 10:48 PM   #1
hellyvin
Drives: WRB Brz
Passenger Side Window Issues
Hello 86 fam.
Need some insight into an issue I am currently having with my passenger side window. The issue with my passenger side window is that it will not come down when using the buttons on the driver's side or the passenger's side. Both buttons are never illuminated. On the driver's side, the button for the driver side is illuminated however the button next to it for the passenger side is not. So essentially I can't control the passenger side window up or down.
The window still automatically lowers one inch when opening the door so I am guessing the motor is not the issue? Is this more of a fuse thing or something with the controls inside the door?
Note: I have used the search function and this is not the issue where the door window light switches are blinking and needs a reset. I have tried that anyways but it did not resolve the issue.
Thanks in advance.
hellyvin is offline   Reply With Quote
Old 02-21-2017, 10:51 PM   #2
Joon525
Joon525's Avatar
Drives: 2016 BRZ
You must have the window lock turned on. Press the button next to the door unlock switch and I bet the switches illuminate.
Joon525 is offline   Reply With Quote
The Following User Says Thank You to Joon525 For This Useful Post:
hellyvin (02-21-2017)
Old 02-21-2017, 11:18 PM   #3
hellyvin
Drives: WRB Brz
That fixed it. Can't believe I was that incompetent. Lol
Thanks alot
Old 02-21-2017, 11:38 PM   #4
Thanks alot
You're in good company. I believe we have a special registry for victims of that switch if you care to sign up.
There's one for trunk switch too.
Old 02-22-2017, 12:15 AM   #5
Thanks alot
... .....now, go read the manual again ... ALL of it this time .....
Joon525 (02-22-2017)
Old 02-22-2017, 03:06 PM   #6
brzee_vic
brzee_vic's Avatar
Drives: frown slasher
At least it wasn't the window jam sensor taking over. Where the power window button just blinks and does nothing.
brzee_vic is offline   Reply With Quote
Old 02-23-2017, 06:58 AM   #7
Also a 10 second fix for anybody that actually reads the manual.
Old 02-23-2017, 02:29 PM   #8
Noises from passenger side door/window FatFree Scion FR-S / Toyota 86 GT86 General Forum 8 02-05-2015 09:43 PM
Rattling sound on passenger side window G8mou BRZ First-Gen (2012+) — General Topics 7 10-17-2014 01:28 PM
Passenger Side Window Doesn't Work JNovo79 Issues | Warranty | Recalls / TSB 5 02-18-2014 04:14 PM
Passenger side window issue. I've searched and tried everything but no fix skygt19 Issues | Warranty | Recalls / TSB 14 11-09-2013 04:22 PM
Passenger side window auto-up less sensitive? l0aded Scion FR-S / Toyota 86 GT86 General Forum 8 09-17-2013 04:01 PM
