Old 02-19-2017, 09:51 AM   #15
-Willis-86touge
Drives: Stock
Originally Posted by brzfl View Post
Was definitely thinking of this kit, I just wanted to boost now and build later which is why I wasn't leaning to heavily towards this kit, but it might be more cost effective to just do it all at once.
Ask moto east but think you can use it on stock with normal pulleys! Of course they will prob recommend a built motor,but from what I remember reading; they ran it for a year on stock motor. This is what I'm prob coining to do! This or jacksons racing with 4.88 gears! Should give it a nice kick down low and still have about 150 mph top end if it's redlined to 8000. Should be plenty for this car
-Willis-86touge is offline   Reply With Quote
The Following User Says Thank You to -Willis-86touge For This Useful Post:
brzfl (02-20-2017)
Old 02-19-2017, 12:05 PM   #16
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I personally hate this cars first gear and im at 4.1, i dont understand how anyone would want the gears to be smaller.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 02-19-2017, 01:17 PM   #17
-Willis-86touge
Drives: Stock
Yea figured first gear will be useless just trying to make the other gears more responsive. Don't know first is boost then I'll see how things go maybe no gears at all. "You don't know unless you know"-
Oh and I was thinking of raising first and second gear with the Cisco transmission set. Did a little figuring and should make fist and second close to the 4.56 gear ratio if you use the 4.88 gears and transmission set. So maybe that with help out!�� And make it close ratio tuboot
Old 02-20-2017, 12:22 PM   #18
brzfl
Drives: 2015 CWP BRZ Limited
Did more research an apparently the kit is capable of 500+whp? If that's true, I'll most likely be going this route, I'll definitely look to see if it can be used on stock with a less agressive tune (:
brzfl is offline   Reply With Quote
Old 02-20-2017, 02:01 PM   #19
-Willis-86touge
Drives: Stock
Don't think you'll see quite 500 but a little over 400 maybe 450
Old 02-20-2017, 08:48 PM   #20
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
The torque curve of the Works looks really interesting to me, although it does fall off near the higher RPMs, I'll look into that for sure!
So correct me if I'm wrong, if I go with a bigger twin-scroll turbo as I'm beginning to sense I'm going in the wrong direction, it would give me a good balance between low end torque and good power on the upper limit with headroom to grow with a built motor?
Loving the idea of this kit, although it is a bit more expensive that I'd hope to go, definitely an option
Full race is pricey right off the bat, but you get a monster manifold that will take track abuse. This isn't cheap to produce. Their kits also are as complete as you can get with an EFR and all the bells and whistles. Any other kit will cost close to the same when you spec it with the same level of components.
No SC kit will hit 500whp. Not 400 whp on a calibrated dynojet. Turbo only to hit anything above that. That isn't to say a 400 whp SC isn't a complete blast on the street. The instant response makes it feel like a v8. But a 500 whp turbo is a whole different beast altogether. Once you cross that 400 whp threshold you have to factor in the transmission. If you aren't willing to do a swap ($$$) or at least upgraded gears, then you won't get to use the 500 whp very much. We know, we've done several 500+ whp builds and most of them end up going through a trans pretty quick. In the end it isn't a big deal to go through a stock BRZ transmission once a year now that they are about 500-1000 used, but it is still rather inconvenient when it lets go as you're walking away from a 911 turbo or a modified GTR.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Fred E (02-21-2017)
Old 02-21-2017, 06:41 AM   #21
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by Icecreamtruk View Post
Would a Garrett GT2860RS be consider small enough that it would have good torque early? Maybe not 3k, but say full boost at 4k or so?
I ran a 28RS and loved it, peak torque was 4100 if I remember right, that was also with a .86 hot side.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Icecreamtruk (02-21-2017)
Old 02-21-2017, 07:43 AM   #22
GsxrMe
GsxrMe's Avatar
@moto-mike give us a transmission solution!
2014 Subaru BRZ
2017 BRZ torque/power curve on dash... softgrip BRZ First-Gen (2012+) — General Topics 15 11-05-2019 01:41 PM
The FRS torque curve smbrm Scion FR-S / Toyota 86 GT86 General Forum 29 06-30-2016 04:10 PM
Customizing the torque curve using ROM Raider illmatic_frs Software Tuning 8 02-15-2016 01:12 AM
Ideal street torque curve Bischoff Forced Induction 29 05-03-2014 10:53 AM
BATHTUB CURVE ON GRAPH alan.chalkley Engine, Exhaust, Transmission 12 06-09-2012 10:58 PM
