Old 11-30-2016, 09:19 AM   #1
softgrip
Drives: 2017 BRZ - Dark Grey Metallic
2017 BRZ torque/power curve on dash...
Does anyone know if the torque/power graph is just an image with some marks that move with your RPM or does it recalibrate when you tune or go FI?
I expect it's static... but if it recalibrates, that would be amazing!
softgrip is offline   Reply With Quote
Old 11-30-2016, 05:07 PM   #2
himbo
Drives: Lightening Red BRZ Ltd.
You know, I asked that same exact question in my head. My guess, is that its just a copy of the dyno and the line that moves across the HP and TQ curves is linked to throttle. So, my guess is that the curves will probably stay the same.
himbo is offline   Reply With Quote
Old 11-30-2016, 05:47 PM   #3
WWFT86
Drives: 2017 BRZ Limited
Just static - the user manual said so...
WWFT86 is offline   Reply With Quote
The Following User Says Thank You to WWFT86 For This Useful Post:
funwheeldrive (12-01-2016)
Old 11-30-2016, 05:52 PM   #4
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
I imagine someone being able to import whatever dyno sheet you want on there then
Barefootdan is offline   Reply With Quote
Old 11-30-2016, 08:22 PM   #5
softgrip
Hopefully, or we are cursed with a permanent reminder of the dreaded torque dip... basically the only negative of this amazing platform.
Old 12-01-2016, 02:21 PM   #6
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Nah, the side marker design is much worse. At least the torque dip can be fixed.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 12-01-2016, 04:57 PM   #7
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
It's static, like others have said (and the manual says).
My 2017 BRZ is tuned and it does not change...
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
ROFL it's Waffle (11-05-2019)
Old 12-01-2016, 05:25 PM   #8
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Aftermarket sidemarkers are cheaper than headers and a tune lol
"Chasing speed with patience"
MurderousPandas is offline   Reply With Quote
Old 12-02-2016, 12:50 PM   #9
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
As in the "sidemarker on the corner of the bumper" design. It looks very good deleted, and after removing the bumper its very prone to cause fitment issues. They should have relocated the sidemarker on the refresh.
A header and tune would be pretty close in cost to having a body shop delete the sidemarkers. I guess aesthetics bother me more than something that is non-existent for me now (no torque dip w/ a turbo).
The Following User Says Thank You to BRZoomTX For This Useful Post:
funwheeldrive (12-02-2016)
Old 12-02-2016, 02:45 PM   #10
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
don't forget the dreaded bumper sag
Old 12-02-2016, 02:49 PM   #11
FX86
That explains why one of my side markers doesn't sit flush ...i got my car brand new and it already had some deep scratches on the front bumper coming off the truck....they had to remove the bumper and repaint it
Old 12-02-2016, 03:42 PM   #12
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Yep, once the bumper comes off, they never seem to sit right on a majority of cars. At least the 13-14's I've seen.
Old 12-02-2016, 03:44 PM   #13
FX86
Mine is 2015 model and the side marker on the right sticks out quite a bit...At first I thought there was something wrong with the metal tabs or I didn't insert it the right way
Old 12-03-2016, 10:00 PM   #14
WWFT86
I find it very useful.. to see where I land in the curve after a _up shift_. Knowing this allows me to upshift at the right RPM next time. Basically -wring it out -wring it out at redline every shift
softgrip (12-03-2016)
One piece dash and other 2017 parts Summerwolf Cosmetic Modification (Interior/Exterior/Lighting) 340 05-05-2020 08:47 PM
2017 BRZ Headunit (and Dash!) Replacement Dok Henz Electronics | Audio | NAV | Infotainment 105 04-14-2018 12:23 AM
The FRS torque curve smbrm Scion FR-S / Toyota 86 GT86 General Forum 29 06-30-2016 04:10 PM
Customizing the torque curve using ROM Raider illmatic_frs Software Tuning 8 02-15-2016 01:12 AM
Ideal street torque curve Bischoff Forced Induction 29 05-03-2014 10:53 AM
