Old 02-18-2017, 03:18 PM   #43
sobrz
sobrz's Avatar
After
sobrz is offline   Reply With Quote
The Following 7 Users Say Thank You to sobrz For This Useful Post:
brandonblt2 (10-02-2018), chaoskaze (08-07-2018), Drakiv (12-24-2018), JeremyR (02-19-2017), kevaughan (07-17-2022), MJones_RB (02-20-2018), RavioliG (08-06-2017)
Old 02-18-2017, 03:25 PM   #44
sobrz
sobrz's Avatar
Doesn't seem to be necessary
Correct.
The other 4 clips are different and they're tight.
In my case the gap was there even when only 2 clips were loose, this kit fixed it.
The Following User Says Thank You to sobrz For This Useful Post:
asdf (03-22-2017)
Old 02-19-2017, 09:18 PM   #45
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Originally Posted by sobrz View Post
After
WOW that's a huge difference! looks wayyyy better. any tips for the install?
JeremyR is offline   Reply With Quote
Old 02-20-2017, 12:08 AM   #46
sobrz
sobrz's Avatar
1) As @cjd said already: screws go on the top (nuts and the metal plate go on the bottom).
2) As you're re-installing bumper, make sure to also give it a push directly under the headlights - there are clips there too and the bumper gap will disappear only when those clip in.
The Following 2 Users Say Thank You to sobrz For This Useful Post:
cjd (02-20-2017), JeremyR (02-20-2017)
Old 03-21-2017, 05:47 PM   #47
kdbar
Drives: Dark Grey BRZ
Just ordered this. Did you have to take off the entire bumper to install these? If not, is there instructions on how to do it without taking it all off?
Thanks!
kdbar is offline   Reply With Quote
Old 03-21-2017, 07:33 PM   #48
Ashikabi
Ashikabi's Avatar
Thanks!
You'll have to remove the whole bumper. There are no instructions. Check youtube
Old 03-21-2017, 11:05 PM   #49
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by mabviper View Post
How many pieces did you get? Is it metal and can you able to measure its thickness? Thanks!
I measured .011 inch thick. Looks like 31 gauge stainless.
Old 03-21-2017, 11:06 PM   #50
Gunman
Thanks!
this comment says no. I'm going to try by taking the top, and wheel openings loose, and leave the underside attached.
http://www.ft86club.com/forums/showp...1&postcount=21
The Following User Says Thank You to Gunman For This Useful Post:
Old 03-22-2017, 01:28 AM   #51
kdbar
Please let me know how it goes through that method! Thanks
Old 03-23-2017, 01:33 AM   #52
sobrz
sobrz's Avatar
Based on my experience, you'll save plenty of time by taking off the bumper completely.
The bottom has just two 10mm bolts and push pins that take no time to get out.
I tried to save time by just undoing the top but then:
1) it's much harder to attach the new part correctly (the small bolt is barely as long as the bumper is thick)
2) if you drop the tiny nut (like I did) you'll end up taking the bumper anyway to find it
Gunman (03-23-2017)
Old 03-25-2017, 05:03 PM   #53
Gunman
I ended up taking the entire cover off.
You can see how much of the clip portion on the bumper was gone. Once I got the new clips bonded, and screwed in place, I built up some glue to replace the missing section. Unfortunately, that side still won't clip. LH side snaps in nice and solid now, and I doubt I'll ever have an issue over there. I suspect the bracket the RH snaps into has some issue as well, and that is why I can't get it to snap in place
All that aside, it seems like a valid fix, provided you're not trying to bridge a canyon.
Old 03-25-2017, 05:12 PM   #54
Ashikabi
Ashikabi's Avatar
You could try putting one on top
Old 03-30-2017, 05:45 PM   #55
jcinque
jcinque's Avatar
Drives: White 2015 BRZ
[IMG]https://uploads.tapatalk-cdn.com/20170330/c7c6cd17c213a57178765ce34d33399c.jpg[/IMG
Move over racing quick release absolutely fixed my bumper gap. Unfortunately like an ass I did not take before picks. Still a very slight imperfection on the driver's side but 98 percent fixed. Satisfied I guess. Still have slight headlight gap which is driving me nuts. Any fixes for that?
Sent from my XT1650 using Tapatalk
jcinque is offline   Reply With Quote
The Following User Says Thank You to jcinque For This Useful Post:
slizoth (03-22-2019)
Old 06-10-2017, 11:57 PM   #56
Wyatt2617
Wyatt2617's Avatar
Drives: 2015 Subaru BRZ Series.Blue
Has anyone ever considered making these little plates instead of having to buy from Japan and wait for them to arrive? They don't look to hard to make!
Sent from my SM-G935P using Tapatalk
Wyatt2617 is offline   Reply With Quote
bumper sag repair, anyone tried this yet? nickmerronesucks Cosmetic Modification (Interior/Exterior/Lighting) 23 07-28-2016 11:14 PM
Bumper repair keneyy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 10-19-2015 06:30 PM
WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement mariolefty1 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2013 05:52 PM
Front Bumper repair grgonium Scion FR-S / Toyota 86 GT86 General Forum 7 01-15-2013 07:25 PM
Bumper Repair Thatruth2001 Northwest 1 09-12-2012 02:15 AM
