Old 02-12-2017, 10:25 PM   #1
HaVoj
Drives: Frs
Do I need a tune?
I have a '13 scion with Injen intake, Greddy catback exhaust, motive front pipe. With all that do I need a tune? I love the way the car felt and sounded after start up but once the maf kicked in after a day or two it went back to somewhat normal. Any advice?
HaVoj is offline   Reply With Quote
Old 02-12-2017, 11:31 PM   #2
swarb
Yes.
You'll gain more power from a tune than you have from having all those parts without a tune.
Old 02-13-2017, 12:23 AM   #3
HaVoj
Drives: Frs
Ok but all I've seen out there are stage 1. Once it gets into stage 2, 3, and up its only if you have headers, turbo, E85 etc. indontnhave any of those
Old 02-13-2017, 12:27 AM   #4
D_Thissen
D_Thissen's Avatar
Stage 1: stock header
Stage 2: aftermarket header
For your set up, you would want stage 1.
Old 02-13-2017, 12:31 AM   #5
HaVoj
Drives: Frs
Even though I don't have aftermarket headers?
Old 02-13-2017, 12:34 AM   #6
phrosty
phrosty is offline   Reply With Quote
Old 02-13-2017, 12:35 AM   #7
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
With a tune, you will have some slight but noticeable power gains. Engine should run a bit smoother and a little less Torque Dip. I was happy with a Stage 1 tune, but much happier once I went stage 2 (header) with a tune. Unfortunately, a Tune is merely a gateway drug. You will always want just a little bit more.....
PNW-BRZ is offline   Reply With Quote
Old 02-13-2017, 01:02 AM   #8
HaVoj
Drives: Frs
Ok so..... Which tune to go with? Ecu tek? Open flash?
Old 02-13-2017, 02:00 AM   #9
Calvin27
Drives: GTS
the biggie is the intake and the possibility you need MAF scaling (no idea what your intake looks like).
Calvin27 is offline   Reply With Quote
Old 02-13-2017, 02:30 AM   #10
steve99
Drives: FT86
Intakes can alter the fueling and afr on your car as the MAF sits in the intake it samples basicly the velocity of the air passig it to determine air flow, if the intake changes the velocity of the air past maf then it can throw fueling off, this is eespecially true if the intake alters the positioning of maf in air flow or the diameter of tube the maf sits in.
The ecu will attempt to compensate but doesnt always get it correct.
intakes on the whole produce little power gain.
if ir was me i would sell the injen intake put money towards a set of catless headers and a tune.
have a read of the basic bolt on mods guide below link in blue
Old 02-13-2017, 02:32 AM   #11
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You will gain a little drivability with a tune. A bit of power through the rev band. The mods you already have will make little or no difference. They are essentially cosmetic. In other words, if you went back to stock an then ran a tune, you'd get the same HP. If you replace the header, you can get a noticeable boost in HP. A header might, just might, work with those other mods to add some insignificant amount of power.
Old 02-13-2017, 02:38 AM   #12
aagun
Drives: 86
if you think about save money . the car can holds any change on air or fuel . that called LTFT AND STFT . the ecu take time to learn whats new and what's different . there are limit for that limit . upto 10% of change from stock . above of that will coz lag / delay / failsafe mode
looking for power . tune best option
aagun is offline   Reply With Quote
OpenFlash Headers in 2017 &a Tune -- success & no tune yet gskv Software Tuning 151 03-29-2018 09:10 PM
B01D 6AT SBD Turbo Tune Questions *Tune Attached* Pro60modman Software Tuning 6 09-05-2016 10:04 PM
How can you trust a tune? (tune noob) Benschneider06 Software Tuning 20 05-21-2015 12:03 PM
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 01:57 AM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 03:49 PM
