Old 02-11-2017, 02:28 PM   #1
killconey
Aftermarket pulley wobble with video
After I installed an aftermarket Raceseng crank pulley I noticed it wobble but when you give some gas it looks stable. I've uploaded a video. I did make sure to torque it to 94ftlb.
killconey is offline
Old 02-11-2017, 10:40 PM   #2
I'd strongly suggest that you take that puppy off, put that pretty thing on a shelf in your garage, then put the OEM pulley back on .......
humfrz is offline
Old 02-11-2017, 11:06 PM   #3
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
Im still surprised people still buy these things
Barefootdan is offline
Old 02-11-2017, 11:15 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Did you doible check the issue described here?
http://www.ft86club.com/forums/showthread.php?t=26386
finch1750 is offline
Old 02-11-2017, 11:32 PM   #5
killconey
Yeah. It was flush. I'm guessing this is not worth it.
Old 02-12-2017, 01:37 AM   #6
+1 Lest we forget its function let's call it what it is; a harmonic damper.
Ultramaroon is offline
Old 02-12-2017, 05:57 AM   #7
killconey
Noted. I'll take it off. Hopefully the OEM won't start wobbling.
Old 02-12-2017, 06:04 AM   #8
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
not on an internally balanced 4 cylinder it is not.
why? is offline
Old 02-12-2017, 06:28 AM   #9
finch1750
finch1750's Avatar
Old 02-12-2017, 09:41 AM   #10
Somerandom18
Drives: 2017 manual BRZ
Better yet get a fluidampr..
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline
Old 02-12-2017, 11:24 AM   #11
killconey, here is some interesting reading for your Sunday pleasure.
http://www.onallcylinders.com/2015/1...and-balancers/
If the OEM pulley wobbles after you put it back on ...... I'd suggest you check your pulley changing procedure.
humfrz is offline
Old 02-12-2017, 11:28 AM   #12
Would you buy that the OEM crankshaft pulley is a "elastomer style harmonic balancer" ....??
If not, prepare for a down from ol @Ultramaroon ........
humfrz is offline
Old 02-12-2017, 11:35 AM   #13
norcalpb
norcalpb's Avatar
Last time I got in a pulley debate (well last last last time) I got sent a bunch of links that we're inconclusive. I've had my lightweight crank pulley for 20k miles.
norcalpb is offline
Old 02-12-2017, 01:11 PM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, it's just me or it's not the CP that seems vibrating in video but one small pulley .. but most of dampener related remarks seem to be related to CP.
churchx is offline
Crank Pully Wobble... With video Norcalmav23 Engine, Exhaust, Transmission 33 09-25-2019 07:26 PM
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-04-2019 11:37 PM
Pulley install help.. Video inside brzzy Engine, Exhaust, Transmission 4 04-27-2016 08:13 PM
Agency Power vs. Perrin Lightweight Pulley - Review Video FT-86 SpeedFactory Engine, Exhaust, Transmission 5 10-04-2012 03:07 PM
