Old 10-13-2016, 07:23 PM   #547
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by Sarsi View Post
Thanks Wayno, I thought you suggested logging from 2-6k in your dialling in thread but see that I've somehow gotten mixed up, anyway good to know all is good
Next step is to install the PSR header
You should try the new v117 maps I've posted. They have static 20% port injection at WOT instead of 100% direct injection. Unknown if they will make as much jam, but should be safer for the intake valves.
Old 10-13-2016, 09:41 PM   #548
thambu19
Drives: Scion FRS
wouldnt port injection with ethanol cause valve seat recession though?
thambu19 is offline   Reply With Quote
Old 02-10-2017, 12:55 AM   #549
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I'm planning on running E85 in my car from next week onwards and I just had a few questions.
I have an Openflash Tablet and a Tomei Header so the process should be pretty simple.
1. I just changed my oil with Toyota OW20 a week ago. Is it a huge issue to run E85 with this oil for the forseeable future?
2. Are there any issues or snags I should look out for? Parts that will wear faster?
Wise is offline   Reply With Quote
Old 02-10-2017, 06:09 AM   #550
steve99
Drives: FT86
Toyota 0w20 oil is fine on E85 its SN rated
wear , well maybe the tyres from the extra power
File Type: pdf UOA_TGMO_0W20_SN_GF5_OCT2015_Normal-WEB.pdf (153.6 KB, 147 views)
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Lantana frs (02-10-2017), Wise (02-10-2017)
Old 02-10-2017, 01:18 PM   #551
Lantana frs
Drives: 13 frs red
Thanks for all the information Steve. I switched to e85 this week and this thread made it possible. Now imttrying to decide whether or not to remove power blocks. Lol
Lantana frs is offline   Reply With Quote
Old 02-10-2017, 05:53 PM   #552
steve99
Drives: FT86
yeah the block will shift the powerband down 500-1000 rpm to around 6000-6500, but E85 tunes generally make power over that band.
Its not going to cause any harm, you will just be a few hp down over 6500.
But you will likely have a more usable powerband for street driving.
Teseo (02-10-2017)
Old 02-10-2017, 08:23 PM   #553
Lantana frs
Drives: 13 frs red
Acceleration is smooth and effortless with e85 whereas with cbp 93 tune it was choppy and slower albeit with more drama. Placebo affect.
Old 02-10-2017, 08:25 PM   #554
steve99
Drives: FT86
probably not E85 is generally smoother and provides power/torque gain over entire rpm range
Old 02-10-2017, 10:02 PM   #555
Lantana frs
Drives: 13 frs red
No I meant the 93 tune. Lol. With e85 the buttdyno and speedo agree with one another. Lol
Old 02-11-2017, 03:08 AM   #556
Wise
Circle Work Clerk
Thanks for putting my concerns to rest mate.
Old 02-11-2017, 07:11 AM   #557
Lantana frs
Drives: 13 frs red
What I've found with e85 is that the car accelerates much smoother and quicker across the board. Next up will be a good header.
Old 03-04-2017, 03:43 AM   #558
MileMonger
MileMonger's Avatar
Drives: 2015 Subaru BRZ
Hey everyone,
After months of lurking and anticipation, I finally switched to E85!! Buuut... now I seem to be having a little trouble.
I followed all the directions on the first post of this thread. I filled up about 20 miles after the low fuel light came on at a Shell station that claimed a minimum of 70% ethanol content. Tonight, after 110 miles of driving on the e85 tune on my stock BRZ, I started hearing louder throttle noise than usual... Sounds like rapid tapping/hitting (knock?), it starts at about 2300 rpm and goes away just past 3000. When I turned off the car after this trip, it shook quite a bit. Please tell me this isn't bad news...
Other concerns are that having swapped from the OTS 93 octane tune, I have found the car to be less smooth overall... The 93 tune really improved taking off from a stop on first, but on E85, it feels like the car is more prone to jitter at very low speeds on first. It's better than stock, but worse than the 93 oct tune. Acceleration also doesn't feel as smooth as the 93 tune did. Judging by everyone's impressions, none of this is normal... or is it?
If anyone could please help me out I'd really appreciate it.
Here is a log after my first 15 miles on e85. Unfortunately I did not have my OFT with me when I felt the noise today. Will run another one tomorrow to see if it shows anything abnormal in those rpm ranges.
http://www.datazap.me/u/milemonger/e85-after-15-miles?log=0&data=1-7-8-9
Thanks a lot!
MileMonger is offline   Reply With Quote
Old 03-04-2017, 07:20 AM   #559
Lantana frs
Drives: 13 frs red
Did you watch fuel trims before switching to e85 tune? Sounds to me like its still burning some 93 off.
Old 03-04-2017, 09:18 AM   #560
MileMonger
MileMonger's Avatar
Thanks for your response. That's one of my guesses too, although when I filled up, the needle was just underneath the E line. The other guess would be that it learned 93 and is now hitting E85 and has to learn that. I watched them for a while and after about 3 miles my stft started rising higher and higher. Then quickly going back down. A few minutes later my ltft started to hold at around 2, then 4. It remained like this for a couple more miles, so I stopped and flashed, since for the first 3 it mostly held around 0.
UPDATE: I just ran another datalog and the noise was present: http://datazap.me/u/milemonger/e85-a...&data=1-4-9-10
Here's a video I took at the end of it as well. Didn't really have a chance to rev any higher and was a bit hesitant to anyway... The noise can be heard in the video, though it's a bit louder in person.
https://www.youtube.com/embed/XS3Xwv4m2m4
Thanks a lot!
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
