Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
Is this the normal amount of play for stock shifter?
Recently got my clutch replaced due to a failing TOB bearing and I was wondering if the play I have in my shifter is considered normal or not (both neutral and in-gear).
...or if my OCD bearing is starting to come loose. ![]() [ame="https://www.youtube.com/watch?v=6zhT-GK8j04"]Scion FR-S Stock Shifter Play - YouTube[/ame] |
#2 |
TRACKBREAD
Oops, see below.
#3 | |
TRACKBREAD
Edit: this one. If it isn't a solid joint and they separated the trans, letting too much weight hang on the linkage before disconnecting it, that part can wear out. ![]() I'd check the shifter plate first though, that's much easier. Sent from my iPhone using Tapatalk |
#4 | |
........ stop looking for stuff to be wrong.Ain't nutten wrong with your shifter (unless mine is lose too). Heck, back-in-the-day, I had a floor board shift, 3 speed, in a 1937 Chevrolet, that 2nd gear would point to anywhere between the speedometer and the glove box ....... and it worked just fine ...... ![]() @Tcoat ....... what was that other disorder that some people confuse with OCD .... ?? humfrz |
#5 |
The Gunshine State
Drives: '14 BRZ Limited
Normal.
![]() Current DD: M235i |
#6 | |
Junior
Drives: a car
#7 |
........ well that too.What I was thinking of was OCPD. https://en.wikipedia.org/wiki/Obsess...ality_disorder humfrz I'm off to tend to my OCNP (Obsessive Compulsive Nap Time) ..ZZZZZZZZ |
#8 |
Drives: 2014 GT86
Hmm. Isn't it about time for post 'totalled' to come?
#9 |
#10 |
Drives: World Rally Blue BRZ
I've wondered this myself and checked out a few 86/BRZs. Bottomline, it's normal.
And, I believe the WRX shifters have more play than this, yet they consider it normal as well. |
| The Following User Says Thank You to Brzerker For This Useful Post: | dhuang (02-13-2017) |
#11 |
Drives: car
@Brzerker @8RZ this amount of play is not be normal. No video on youtube I've seen from a vendor or tuner or other has had sloppy gearshifts like these.
@dhuang I have the same amount of play after my clutch replacement as well. Keep us posted if you find anything. @Yoshoobaroo thanks so much for the tip |
#12 |
Drives: 2014 monogram frs
Anyone find anything?
#13 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
this thread kills me lol
#14 |
Senior gif poster
Drives: 2013 Asphalt FRS
That's totally normal, relax and get used to it and before you know it you will be slamming through gears getting on the highway in no time flat, by the time you hit 80 you will have a smirk on your face.
Compared to my previous manual cars this one is slightly more tricky and less forgiving but better throw and less play. Drive a manual car from the 80s and you will see what play is. Also don't jiggle the shifter in gear while its running, shift and take your hand off the stick until another gear change is needed. Do not rest your hand on the stick. |
| The Following User Says Thank You to DandoX For This Useful Post: | Drakiv (10-16-2018) |
| Shifter rattle. Normal? | slyphen | Issues | Warranty | Recalls / TSB | 37 | 08-13-2020 02:58 PM |
| How much shifter play is normal? | radroach | Engine, Exhaust, Transmission | 16 | 08-02-2017 10:25 PM |
| Normal amount of rust for a 13? | Spacemane969 | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 05-30-2015 09:48 PM |
| Normal amount of corrosion on brake calipers? | Annahra | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-05-2014 03:19 PM |
