Old 02-09-2017, 03:39 AM   #1
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Is this the normal amount of play for stock shifter?
Recently got my clutch replaced due to a failing TOB bearing and I was wondering if the play I have in my shifter is considered normal or not (both neutral and in-gear).
...or if my OCD bearing is starting to come loose.
[ame="https://www.youtube.com/watch?v=6zhT-GK8j04"]Scion FR-S Stock Shifter Play - YouTube[/ame]
dhuang is offline   Reply With Quote
Old 02-09-2017, 06:54 AM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Oops, see below.
Old 02-09-2017, 07:03 AM   #3
Yoshoobaroo
TRACKBREAD
Originally Posted by Yoshoobaroo View Post
That's not bad at all, I'd say it's within the realms of normal play.
I don't know if these cars have a bushing on the selector shaft on the transmission that attaches to the linkage, but on other cars (BMWs in my experience) they can wear out and cause epic slop side to side (like more than a half inch each way) and still shift properly.
Edit: this one. If it isn't a solid joint and they separated the trans, letting too much weight hang on the linkage before disconnecting it, that part can wear out.
I'd check the shifter plate first though, that's much easier.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
dhuang (02-09-2017), radroach (03-14-2017)
Old 02-09-2017, 01:08 PM   #4
........ stop looking for stuff to be wrong.
Ain't nutten wrong with your shifter (unless mine is lose too).
Heck, back-in-the-day, I had a floor board shift, 3 speed, in a 1937 Chevrolet, that 2nd gear would point to anywhere between the speedometer and the glove box ....... and it worked just fine ......
@Tcoat ....... what was that other disorder that some people confuse with OCD .... ??
The Following 3 Users Say Thank You to humfrz For This Useful Post:
chaoskaze (10-20-2018), dhuang (02-13-2017), Tcoat (02-09-2017)
Old 02-09-2017, 01:10 PM   #5
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Normal.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
dhuang (02-13-2017), JohnJuan (10-15-2018)
Old 02-09-2017, 03:37 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Boredom?
Old 02-09-2017, 04:17 PM   #7
Originally Posted by cdrazic93 View Post
Boredom?
........ well that too.
What I was thinking of was OCPD.
https://en.wikipedia.org/wiki/Obsess...ality_disorder
I'm off to tend to my OCNP (Obsessive Compulsive Nap Time) ..ZZZZZZZZ
cdrazic93 (02-09-2017), JohnJuan (10-15-2018)
Old 02-09-2017, 07:35 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm. Isn't it about time for post 'totalled' to come?
Old 02-09-2017, 09:16 PM   #9
Too soon .....
Old 02-10-2017, 03:47 AM   #10
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
I've wondered this myself and checked out a few 86/BRZs. Bottomline, it's normal.
And, I believe the WRX shifters have more play than this, yet they consider it normal as well.
Brzerker is offline   Reply With Quote
The Following User Says Thank You to Brzerker For This Useful Post:
dhuang (02-13-2017)
Old 03-14-2017, 05:04 AM   #11
radroach
Drives: car
@Brzerker @8RZ this amount of play is not be normal. No video on youtube I've seen from a vendor or tuner or other has had sloppy gearshifts like these.
@dhuang I have the same amount of play after my clutch replacement as well. Keep us posted if you find anything.
@Yoshoobaroo thanks so much for the tip
Old 10-15-2018, 01:44 PM   #12
Osment918
Drives: 2014 monogram frs
Anyone find anything?
Osment918 is offline   Reply With Quote
Old 10-15-2018, 01:49 PM   #13
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
this thread kills me lol
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 10-15-2018, 02:19 PM   #14
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
That's totally normal, relax and get used to it and before you know it you will be slamming through gears getting on the highway in no time flat, by the time you hit 80 you will have a smirk on your face.
Compared to my previous manual cars this one is slightly more tricky and less forgiving but better throw and less play. Drive a manual car from the 80s and you will see what play is.
Also don't jiggle the shifter in gear while its running, shift and take your hand off the stick until another gear change is needed. Do not rest your hand on the stick.
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
Drakiv (10-16-2018)
Shifter rattle. Normal? slyphen Issues | Warranty | Recalls / TSB 37 08-13-2020 02:58 PM
How much shifter play is normal? radroach Engine, Exhaust, Transmission 16 08-02-2017 10:25 PM
Normal amount of rust for a 13? Spacemane969 Scion FR-S / Toyota 86 GT86 General Forum 23 05-30-2015 09:48 PM
Normal amount of corrosion on brake calipers? Annahra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-05-2014 03:19 PM
