Old 02-07-2017, 01:37 PM   #589
churchx
churchx's Avatar
Drives: 2014 GT86
Cartman: DS2500 squeeled a lot? Hmm. On stock or aftermarket brakes? On stock brakes here they were completely quiet 3/4ths of year and only on colder days in winter started squeel, not much/not very loud though, much quieter then half-worn stock pads did. So about the only thing i may dislike for them, they do dust a lot.
churchx is offline
Old 02-07-2017, 03:51 PM   #590
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
This is the RR racing BBK thread... I'm, of course, talking about them on the bbk...
Cartman is offline
Old 02-08-2017, 01:09 PM   #591
gskv
Drives: 2017 BRZ
Originally Posted by maregt View Post
Hi, you should send them an email with a specific question, I'm sure they can give you the answer you are looking for
Originally Posted by JRitt View Post
I asked for detailed specs and bias information to be published about a year ago. I was told "go find it on their website." Then I was accused of being a bad person for posting a technical question in a competitor's thread. I thought a technical question in a technical thread was valid.
I've emailed them, but as soon as I've asked about brake bias. There wasn't much detail or response.
For that reason, I'm most likely buying the Essex kit this Spring to pair with the ugly rear stock brakes.
gskv is offline
Old 02-08-2017, 01:29 PM   #592
jamal
jamal's Avatar
Drives: Legacy GT
Hey why bother when nerds on the internet will do the math for you?
jamal is offline
Old 02-08-2017, 02:27 PM   #593
maregt
Drives: Subaru BRZ
Look here http://www.ft86club.com/forums/showthread.php?p=2834441
maregt is offline
Old 02-09-2017, 11:20 PM   #594
canyons
canyons's Avatar
Drives: 2013 Supercharged BRZ, E85, Ohlins
Hello RR-Racing guys,
If you are looking for product ideas:
I'm looking for a simple caliper extender bracket and larger rotor kit to re-purpose the OEM rear calipers. You could include pads and sell it for about $499, I am certain there are lots of guys who want better rear brakes without spending a fortune.... give it some thought
canyons is offline
Old 02-10-2017, 01:21 AM   #595
jamal
jamal's Avatar
Drives: Legacy GT
I think that is possible by using tribeca brackets and rotors. You would just need to have the rotors redrilled because they are 5x114.3. Rotors are 320x18 vs 290 stock.
If someone wants to buy a caliper bracket and see if it fits with their upright/caliper the part number appears to be 26625XA01A. I'm like, 99% sure it will work.
Also racing brake has kits that do this. They have a rear upgrade listed but it's for the older cars.
jamal is offline
The Following User Says Thank You to jamal For This Useful Post:
canyons (02-10-2017)
Old 03-04-2017, 03:24 AM   #596
choi0706
Drives: t
how do these compare with AP sprint kit in terms of wheel clearance? looking at both fitment sheets, it appears the stage 4 is still more narrow than the AP sprint?
choi0706 is offline
Old 03-04-2017, 10:27 AM   #597
Traktor
Drives: Subaru BRZ Limited
No need for ugly rear stock calipers. Change them out for 06/07 WRX 2 pots using a KNS adapter bracket. OEM Rotor is reused and there is no change to stock bias.
I've paired this up with the Sprint kit and it works great on track.
Traktor is offline
Old 03-22-2017, 11:09 PM   #598
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
Originally Posted by sickmint79 View Post
ah yes, i noted this in the article, i use OD and the same pad size for all as it's all the information i've got to go off of. it's hard enough to get piston sizes let alone for this stuff. since the same error as committed across the board though i consider it fair to compare kit A to kit B though. i'm not sure more accurate numbers would affect those overall conclusions.
i certainly don't recall what i used as source now, but i had very different sport kit front numbers in my article - 1.49606x2 - which actually kept bias quite stock looking. however with the above numbers (i use 328mm = 12.9134 rather than 12.8 for rotor) - i'm ending up with 0.733, and the most forward of all their front only kit options then.
So we meet again, on FT86Club this time. I imagine complimenting the from Sport Performance BBK with the rears would help the bias get closer to OEM?
edit: I contacted RR Racing asking for some numbers. They were not very helpful at all...I was told that the brake bias chart they supplied was computed using brake pad sizes. I don't think you can use just that as a reliable way to compute brake bias...
editing this post 3 years later to say I have no idea what I was saying
gkubed is offline
Old 04-01-2017, 08:08 PM   #599
ryoma
ryoma's Avatar
Originally Posted by brzest View Post
Does anyone know if the Stg4 kit will clear Enkei RPF1 17x8 +45 (planned track wheels)? Also XXR 527 18x8.75 +35 (planned street wheels)?
Don't have the wheels yet, so can't test =/
Thank you!
here's an update for you. I just fitted the stage 2 fronts with 17x8 +45 RPF1's and the closest point between the caliper and spoke was roughly 2-3mm. I'm not running any spacers. the rears fit just fine.
ryoma is offline
The Following 2 Users Say Thank You to ryoma For This Useful Post:
brzest (04-02-2017), MisterSheep (04-01-2017)
Old 04-01-2017, 10:36 PM   #600
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I'm thinking of switching from the supplied BP10's to Ferrodo ds2500 or Carbotech. I am mainly looking for a quieter experience for daily driving and then running something more aggressive for the track, and I have read that those two are the quietest/streetable. Should I buy rotors too just for the track, or is it no big deal swapping back and forth? I will only be doing a few track days a year at most and a few autox days.
I sold my stock stuff and don't have anything to check. Who makes our OEM pads? Are the stock pads and calipers OEM-Style Brembos? I hear tell that Brembo makes most of the oem stuff and not just the expensive aftermarket stuff. Seems like if they do that the OEM pads should be pretty good, as far as, steet pads go, right? Compound for equal compound, they must be pretty good. Obviously upgrades would be to the compound itself, but not necessarily the quality of the part or formulation, right?
Irace86.2.0 is offline
Old 04-02-2017, 02:27 PM   #601
Irace86.2.0
Looking for pads for the fronts (7420) and for the rears (7912). EBC redstuff shows DP3037/2C for the front and DP3057C for the rears. I can't find them in the states. Well, I can find the fronts, just not the rears. Any help?
Old 04-09-2017, 02:13 AM   #602
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I recall that I had mentioned previously that I would measure the caliper pistons next time I was in there. 1.615 inches based on my cheap digital caliper for the Sport Performance kit.
Lynxis is offline
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 08:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 06:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 05:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 12:31 PM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
