#15 |
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
Have the same code on a customer car with a kraftwerks sc and upgrade fuelpump, actually the code came after changing the pump.
today going to fix it with a new sensor hopefully part nr su003-01106 |
#16 |
Drives: '22 BRZ
I've gotten this code recently. Guess if it happens again I'll have to try replacing the sensors too. Lame.
#17 |
Drives: Kraftwerk c30 suchercharged frs
P0462 issue
Did anyone fix this? I am having this issue with p0462. My car turns off here and there on neutral. I change one of my fuel sender but still
#18 |
Drives: 14 BRZ Limited
For me on the third trip to the dealer(on a flatbed) they replaced both senders under warranty. I haven't had an issue since.
#19 |
Huge E85 fan!
Drives: 2016 Scion FRS
I don't know about this car, but in other cars it is common for the sending unit to go just before the fuel pump goes. Jayfrs95 sounds like your fuel pump is on the way out. Start monitoring your fuel pressure and note what the pressure was at when you stall.
#20 |
I threw a P0462 code at the track. Was full throttle down a straight when the course workers threw a red flag. Immediately went from ~100 mph to complete stop with a hot engine. About a minute later, saw the CEL pop on. First thought was another fried coilpack (happened before in this exact scenario), but when I checked codes, was surprised to see P0462.
Good news is I cleared it and it went away for the rest of the day. We'll see if it returns.
2022 BRZ Build 2013 FR-S Build |
#21 | |
| Fuel pump and speed sensor | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 28 | 04-20-2017 02:54 PM |
| p0462 code | brady86 | Issues | Warranty | Recalls / TSB | 15 | 03-09-2017 09:25 PM |
| Brand new 4 Bar MAF Sensor & 700cc Deatschwerks Fuel Injectors | deedz | Engine, Exhaust, Bolt-Ons | 7 | 03-26-2015 01:21 AM |
| Low fuel level and engine performance | whatsinaname | BRZ First-Gen (2012+) — General Topics | 20 | 12-03-2013 01:55 PM |
| Fuel level | GeeTee86 | Issues | Warranty | Recalls / TSB | 6 | 05-21-2013 06:57 AM |
