Old 10-21-2013, 10:40 AM   #1
whatsinaname
Drives: 1998 Ford ZX2
Low fuel level and engine performance
Is it just in my head or does the ECU make changes to the engine performance when it notices the fuel tank level is a bit low? (I mean around when the low fuel light comes on or a bit above that).
Do you guys refuel at quarter/half tank left or let it get close to empty?
whatsinaname is offline   Reply With Quote
Old 10-21-2013, 10:43 AM   #2
sklimo
I never let it go below 1/4 tank. But that is just an OCD thing on my part
Old 10-21-2013, 11:03 AM   #3
dbrandt01
Drives: none
I'll second sklimo above. I never go below 1/4. One of those things I'm paranoid about
dbrandt01 is offline   Reply With Quote
Old 10-21-2013, 11:09 AM   #4
Frostyman
Drives: 2013 Raven FRS
To answer your question, there are documented cases of fuel starvation while under acceleration and hard cornering below half a tank while forced inducted. I'd imagine that the same issues would present themselves on even a stock car at that low a fuel level.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 10-21-2013, 11:13 AM   #5
sklimo
Glad I'n not the only one!!!
Last edited by sklimo; 10-21-2013 at 12:11 PM. Reason: I'm an idiot who can't spell
dbrandt01 (10-21-2013)
Old 10-21-2013, 12:00 PM   #6
whatsinaname
I thought I noticed the difference when moving from a stand still in first gear at traffic lights.
I guess it wouldn't hurt to just refill at a quarter tank and higher like sklimo and dbrandt01 mentioned.
Old 10-21-2013, 02:27 PM   #7
Flow
Drives: DGMBRZ
I've also noticed that performance is worse with a low fuel tank. No idea of the cause... I was thinking it was a problem with the fuel injection system, but really have no idea.
Flow is offline   Reply With Quote
Old 10-21-2013, 02:51 PM   #8
muffinz
Drives: 2013 DGM BRZ Ltd
I always feel like performance is better when the fuel tank is almost empty...but that may be due to the car being lighter.
Full tank @ ~12gal x ~6 lbs/gal = 72lbs
Almost empty tank @ ~.5gal x ~6lbs/gal = 3lbs
Significant difference that I can feel. When I fill up after running the tank real low, the car definitely feels slower.
muffinz is offline   Reply With Quote
The Following 2 Users Say Thank You to muffinz For This Useful Post:
ntron1 (12-02-2013), strat61caster (10-21-2013)
Old 10-21-2013, 03:21 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
No.
Engine performance is only dictated by fuel pressure and the ability to maintain that pressure into the injectors...
So the only way a performance hit will be built in to the ECU software is if the factory fuel tank is prone to have fuel starvation issues to the pump while under normal driving conditions, which may be a fuel tank design issue by itself. But given that this is not an issue, don't worry about it.
-alex
Old 10-22-2013, 11:19 PM   #10
brzadrian
I'm Batman
brzadrian's Avatar
Drives: 2013 Subaru BRZ aka Sally
I was wondering the same thing
brzadrian is offline   Reply With Quote
Old 10-23-2013, 01:34 PM   #11
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Most of us who autocross the BRZ/FRS run them with the Empty light on. There is no performance loss or starve that we have seen so far.
2superblus is offline   Reply With Quote
Old 10-23-2013, 09:56 PM   #12
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Same here. I've had cars that would starve for fuel on an autocross course under certain circumstances at under 1/4 tank, the BRZ isn't one of them.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 10-24-2013, 09:13 AM   #13
I run Olivia with the fuel light on average about once a week, sometimes for as much as 25 to 30 miles. I have never noticed a fuel supply or performance issue with it low.
Yes, I like living on the edge.
Old 12-01-2013, 08:43 PM   #14
TIsbell34
I don't know if it's a performance loss or anything but I've noticed the car definitely feels better after filling it up if the tank was previously on E
TIsbell34 is offline   Reply With Quote
Accelerated Performance's Fuel System Fix for the BRZ/FRS/GT86 Visconti Forced Induction 103 12-01-2013 12:50 PM
Fuel level GeeTee86 Issues | Warranty | Recalls / TSB 6 05-21-2013 06:57 AM
High performance and race engine oil tests Kamran Tracking / Autocross / HPDE / Drifting 16 02-10-2013 01:06 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 11:06 PM
High compression engine fuel requirements Ben_G Engine, Exhaust, Transmission 3 01-16-2013 12:44 PM
