Drives: 2013 scion frs
Alternate way to open hood
hey guys! my hood release cable got loose i think and i used a plier to pull on the driver side and wrecked the cable. now its totally unable to open. any alternate ways?
#2 |
Drives: 2015 FR-S
Easy
![]() ![]() Going from underneath looks impossible looking at it. Maybe remove drivers side wheel and wheel well cover and reach over there or at least get to the wire? Good luck. Can you at least grab the wire going to it inside? Maybe with two people you can grab it and have another person bump on the hood to release it? |
#3 | |
![]() What do you mean ..... you wrecked the cable ... ?? If I were you, I would remove the kick panel and try to get a hold of the cable with a pair of vise grips and pull on the cable. Or, go with the Bubba method: humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Cole (02-03-2017) |
#4 |
the cable from which it comes out from the drivers side is like almost gonna break anytime from all that yanking. and yea i removed the side kick panel already. the wheel well side seems far from the latch itself. i dont even know if its possible for it to be detached from the latch.
#5 | |
If so, what happened when you pulled it .... ?? If it simply pulls hard, I suggest you pull on it harder, using a vice grip as a lever. They seem to pull hard, even with its lever. If it has become detached from the latch under the hood, it should pull on through. That would not be good. Come back. humfrz |
#6 |
PS - as you are attempting to pull the cable, have someone gently push down on the front center of the hood to release pressure on the latch mechanism (like @Impureclient suggested).
humfrz |
#7 |
hey you, yeah you <3
Drives: 2014 37J FR-S
from inside? drop seats, get in there with a flashlight
#8 |
#9 |
you are right! Damn. GG hood in that case.
| The Following User Says Thank You to Packofcrows For This Useful Post: | humfrz (02-03-2017) |
#10 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Maybe PM the OP in this thread to get more details on how he accessed his hood latch; he had the same issue. I'd be interested in knowing as well:
http://www.ft86club.com/forums/showthread.php?p=2620340
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#11 |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#12 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | gravitylover (02-03-2017), stevesnj (02-05-2017) |
#13 |
Right well i removed the wheel liners and had access to the left bottom bay area. well the good is that its still attached to the latch. the bad is no matter how hard i pull using a vice grip its still unlatched. oh and the air box is blocking the path to the latch so yea..
#14 | |
| An alternate to OEM Audio + that's actually affordable | BMHumanic | Electronics | Audio | NAV | Infotainment | 24 | 02-28-2014 06:28 PM |
| DIY - Alternate Hood Prop | F1point4 | DIY (Do-It-Yourself) Guides | 13 | 03-20-2013 10:22 PM |
| Injen installed, open/closed hood dynoed | Bahraini86 | Engine, Exhaust, Transmission | 55 | 02-14-2013 11:24 PM |
| Alternate car? | ngabdala | Other Vehicles & General Automotive Discussions | 35 | 05-18-2012 01:09 PM |
