Old 10-25-2012, 03:52 PM   #1
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Injen installed, open/closed hood dynoed
Added injen intake system today. Did a number of pulls on a dynojet
Stock base pull 145.2whp 129.1tq
Removal of the stock system
Adding the injen intake
First pull with hood open after resetting ECU 163.7whp 135tq
Second open hood pull 162.5whp 133.3tq
First closed hood pull (best pull of the day) 165.7whp 132.3
Second closed hood pull 162whp 130.4tq
Comparison between stock and best pull on injen intake
Max gain recorded was 20whp 3tq
Pulls were done on the same day, same hour on 4th gear
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline   Reply With Quote
Old 10-25-2012, 03:56 PM   #2
tnt
Drives: argento frs at
Do we have to reset the ECU to get the after effects ? and if so how do we reset the ECU ?
Thanks
tnt is offline   Reply With Quote
Old 10-25-2012, 03:59 PM   #3
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
I just unplugged the battery while installing the intake, just like what I read on this forum. I cud be wrong tho
Old 10-25-2012, 04:02 PM   #4
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
No you are right...just need a 10mm wrench and pull off the black wire(negative) leave it off for about 10-20mins and then put it back on. Nice gains, with this car i believe in resetting the ecu with any mod that affects afr and things of that sort(even if it doesnt do anything i will still reset). Just wondering whats up with those weird dips in the graphs, regardless nice gains with the injen
brichard0625 is offline   Reply With Quote
Old 10-25-2012, 04:07 PM   #5
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
I read this as better top end power but the low rpm power dip has gotten worse with a loss of about 10HP. Am i reading this right???
pixel67 is offline   Reply With Quote
Old 10-25-2012, 04:09 PM   #6
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
The rpm sensor on the dyno kept moving... That's why it diss connected on the graph, sorry for that
Old 10-25-2012, 04:10 PM   #7
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
That's right sir, but my butt dyno didn't feel it on public roads
Old 10-25-2012, 04:11 PM   #8
tnt
I had mine installed at a dealer so not sure if they reset the ECU or not ... if they didn't ... can I still do that now ?
Old 10-25-2012, 04:13 PM   #9
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
ECU shud adapt eventually
Old 10-25-2012, 04:19 PM   #10
raz0rbladez909
I'm here for the beer
raz0rbladez909's Avatar
Drives: 2013 Scion FRS, 1971 Datsun 240z
Nice gains! Seems like it lost a little bit of power/tq in the lower rpm range though. I wonder if the ECU will compensate down the line and negate any gains?
raz0rbladez909 is offline   Reply With Quote
Old 10-25-2012, 04:23 PM   #11
JDMenrique
DEEEERP
JDMenrique's Avatar
The more i read about the Injen intake, the more i see impressive results.
How is the drive-ability with it? is idle alright, is it rough?
JDMenrique is offline   Reply With Quote
Old 10-25-2012, 04:30 PM   #12
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Seems like a really low baseline pull.... hmmm
uspspro is offline   Reply With Quote
Old 10-25-2012, 04:31 PM   #13
2forme
This is encouraging me to grab an Injen and do some comparisons of my own.
I'm really intrigued at how low your car dynoed stock. My stock pull with ONLY an SRT HB exhaust was 174whp... but I also ran a full unit leaner too (like on your injen run). Take away the exhaust, which is advertised at 10whp and that puts me at 164whp stock... which is what your car ran with Injen.
@Bahraini86, any chance you could email your drf files so I could do a direct overlay in WinPEP?
Old 10-25-2012, 04:33 PM   #14
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Wow 10HP??? Could that be real? I mean when do you ever see 10HP from an intake. Especially, it's not even a CAI. Just wondering here...
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Injen Short Ram Intake Installed on my 86 :D R2RO Engine, Exhaust, Transmission 57 06-10-2014 07:14 PM
Installed my Injen Intake, looky! BuBlake Engine, Exhaust, Transmission 75 07-21-2013 02:19 AM
Invidia TI exhaust Dynoed and Ecutek tuned(Video) Ny Brz Engine, Exhaust, Transmission 12 10-12-2012 11:13 AM
JDM 86 HOOD PROPS INSTALLED nigel-jdmparts Cosmetic Modification (Interior/Exterior/Lighting) 10 09-25-2012 12:02 PM
Brz.co.nz closed Metabrz AUSTRALIA 2 06-13-2012 08:24 AM
