Old 02-02-2017, 09:11 PM   #1
Bjack21
Drives: 2013 scion frs
Alternate way to open hood
hey guys! my hood release cable got loose i think and i used a plier to pull on the driver side and wrecked the cable. now its totally unable to open. any alternate ways?
Bjack21 is offline   Reply With Quote
Old 02-02-2017, 10:27 PM   #2
Impureclient
Drives: 2015 FR-S
Easy
Going from underneath looks impossible looking at it. Maybe remove drivers side wheel and wheel well cover and reach over there or at least get to the wire? Good luck.
Can you at least grab the wire going to it inside? Maybe with two people you can grab it and have another person bump on the hood to release it?
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
canyons (02-03-2017), softgrip (02-06-2017)
Old 02-02-2017, 11:00 PM   #3
Welcome to the forum, Bjack21.......
What do you mean ..... you wrecked the cable ... ??
If I were you, I would remove the kick panel and try to get a hold of the cable with a pair of vise grips and pull on the cable.
Or, go with the Bubba method:
Cole (02-03-2017)
Old 02-02-2017, 11:39 PM   #4
Bjack21
the cable from which it comes out from the drivers side is like almost gonna break anytime from all that yanking. and yea i removed the side kick panel already. the wheel well side seems far from the latch itself. i dont even know if its possible for it to be detached from the latch.
Old 02-03-2017, 12:24 AM   #5
So, can you get ahold of the cable on the inside of the car end ... ??
If so, what happened when you pulled it .... ??
If it simply pulls hard, I suggest you pull on it harder, using a vice grip as a lever. They seem to pull hard, even with its lever.
If it has become detached from the latch under the hood, it should pull on through. That would not be good.
Come back.
Old 02-03-2017, 12:36 AM   #6
PS - as you are attempting to pull the cable, have someone gently push down on the front center of the hood to release pressure on the latch mechanism (like @Impureclient suggested).
Cole (02-03-2017), Tcoat (02-03-2017)
Old 02-03-2017, 02:05 AM   #7
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
from inside? drop seats, get in there with a flashlight
Old 02-03-2017, 02:14 AM   #8
...... pay attention, Packofcrows ....... he is trying to open the hood not the trunk ...... sheeesh!
Old 02-03-2017, 02:33 AM   #9
Packofcrows
you are right! Damn. GG hood in that case.
The Following User Says Thank You to Packofcrows For This Useful Post:
humfrz (02-03-2017)
Old 02-03-2017, 10:45 AM   #10
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Maybe PM the OP in this thread to get more details on how he accessed his hood latch; he had the same issue. I'd be interested in knowing as well:
http://www.ft86club.com/forums/showthread.php?p=2620340
shiumai is offline   Reply With Quote
Old 02-03-2017, 01:57 PM   #11
stevesnj
stevesnj's Avatar
My 2016 Build thread
Old 02-03-2017, 02:10 PM   #12
Originally Posted by stevesnj View Post
That gave me an idea ...... place some det cord around the seam between the hood and the rest of the body ....... give it a jolt ....... maybe the hood will blow straight off ......
gravitylover (02-03-2017), stevesnj (02-05-2017)
Old 02-03-2017, 09:24 PM   #13
Bjack21
Right well i removed the wheel liners and had access to the left bottom bay area. well the good is that its still attached to the latch. the bad is no matter how hard i pull using a vice grip its still unlatched. oh and the air box is blocking the path to the latch so yea..
Old 02-03-2017, 09:31 PM   #14
shiumai
shiumai's Avatar
The OP in the other thread did it through the passenger side - I wonder how he actually did it.
An alternate to OEM Audio + that's actually affordable BMHumanic Electronics | Audio | NAV | Infotainment 24 02-28-2014 06:28 PM
DIY - Alternate Hood Prop F1point4 DIY (Do-It-Yourself) Guides 13 03-20-2013 10:22 PM
Injen installed, open/closed hood dynoed Bahraini86 Engine, Exhaust, Transmission 55 02-14-2013 11:24 PM
Alternate car? ngabdala Other Vehicles & General Automotive Discussions 35 05-18-2012 01:09 PM
