#211 |
Drives: 2015 WRB BRZ Premium
He was talking about removing the hub from the e-brake assembly, not the rotor from the hub.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
| The Following User Says Thank You to Nickosport For This Useful Post: | stevesnj (06-22-2016) |
#212 |
Grasshopper
Drives: Ultramarine
Just order the studs from Subaru dealer for 3$
Toyota charges 8$ per stud and they're the same
#213 |
Drives: 13 BRZ Limited WRB
Except the part where they're horseshit. The whole reason this thread exists.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
| The Following User Says Thank You to Gopherboy6956 For This Useful Post: | Tristor (04-18-2018) |
#214 | |
Grasshopper
Drives: Ultramarine
#215 |
True. I did that a few times before I just said FK it and went ARP
#216 | |
Grasshopper
Drives: Ultramarine
Happened to me yesturday 😅 Sent from my Nokia using Tapatalk
| The Following User Says Thank You to _sams86_ For This Useful Post: | Tristor (04-18-2018) |
#217 |
Drives: GT86
I hate to be that guy who says there is no problem when plenty of other people say there is, but I really don't think the stock wheel studs are bad. Perhaps a lot of you are just over tightening them?
I've taken the front and rear wheels off at least 30 times, and not a single one of my threads on any of the wheel studs are showing any sign of stripping. Every time I've put the wheels back on, I use a torque wrench to torque the wheel nuts up to 120 Nm (89 ft-lbs) as per the service manual instructions. A lot of other people I know who work on their own cars say that you should just do them as tight as you can... so I'm guessing a lot of people in this thread that have stripped the stock threads might have followed that same theory. The only time I've ever stripped any bolt threads was when I got the wrong torque value for a bolt that holds the rear lower control arms to the suspension strut, and over tightened it by 30 Nm. So if you guys are tightening the wheel nuts up Maybe I've just been lucky, but it seems unlikely considering the number of times I've had the wheels off.
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits |
#218 |
I don't know about anyone else, but I'm not. Mine were never unusable but they were definitely stretched and wanted to crossthread after taking the wheels off a handful of times. I torque to 80ftlbs. I wonder if the studs have been improved since the first models.
| The Following User Says Thank You to qoncept For This Useful Post: | Tristor (04-18-2018) |
#219 | |
Drives: GT86
Oh and mine is an older model btw, 2012.
#220 |
Drives: 2014 Silver BRZ
Are 5mm spacers safe on stock studs?
#222 |
Vorshlag R&D
Drives: A new one every month
No. 3mm can be safe, depending on the pad depth of the wheel.
Jason McDaniel at Vorshlag Motorsports
| The Following User Says Thank You to modernbeat For This Useful Post: | Tristor (04-18-2018) |
#223 | |
Drives: 2013 pearl white FR-S
Also, it looks like I can just slip the tool between the hub and backing plate based on your picture. I'm trying not to remove the hub if possible as I'm just putting in OEM-length studs |
#224 |
Country Boy 4 Life
I LIKE TIRES! |
| flush with stock wheels. with Stud installation. | adamturbo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 43 | 12-10-2012 04:30 AM |
| Wheel stud | Guaruja | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 10-11-2012 02:42 AM |
| Lug Nut Stud | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-22-2012 10:26 PM |
| Scion FRS center wheel caps replacement? | Silverback | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-03-2012 02:16 AM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 12:28 PM |
