#183 |
Drives: 2001 Impreza 2.5 RS
Colin Beck
#184 |
I should be buying mine this weekend.
#185 |
Drives: 2017 WR BLUE BRZ
http://www.vorshlag.com/blog/
Vorshlag added the MRS update to their blog. Hopefully that helps kick up the pre orders too. |
#186 |
Guest
Posts: n/a
FWIW my car with Weapons Grade's swap has functional push button start and AC working. Not sure how they did it though. They mentioned to me that they'll be using the MRS modules in the future too.
| The Following User Says Thank You to For This Useful Post: | Sportsguy83 (01-27-2017) |
#187 |
Drives: Sterling BRZ Ltd
Do you have any plans to keep the front sway bar? aren't guys having to loose it with the LS
#188 |
Guest
Posts: n/a
Another V8 Swap
#189 |
thats good to hear
#190 |
Guest
Posts: n/a
| The Following 3 Users Say Thank You to For This Useful Post: |
#191 |
sweet!
#192 |
Shorties into 3" with v-bands?...are you doing that yourself? looks great!
Still mocking it up?...doesn't look like you've finished welding yet and it looks really tight towards the rear or the transmission. May have to clearance it a bit? |
#193 | |
Guest
Posts: n/a
#194 |
Drives: 2013 Ultramarine FR-S
Yeah the Vorshlag headers are why the front sway bar can't be used. Trying to decide how to move forward with the header solution. Weapons grade has said their header solution is ~$3000
![]() I like the vorshlag headers, but really hoping to see a sway bar solution here very soon. I may wait on ordering headers until then. (Or go another direction for headers all together)
#195 | |
Colin Beck
| The Following User Says Thank You to MRS-Colin For This Useful Post: | DustinS (01-27-2017) |
#196 |
Just this picture alone show the difference between Weapons Grade and Vorshlag. Look how much further back Vorshlag got the engine.
WGP: ![]() Vorshlag: ![]() Does anyone see any issue with leaning the top of the radiator way forward? (Other than hose routing) Edit: Looked at WGP Headers. They are listed at $2000. Few hundred more than Vorshlags, which is quite a bit better than the $3k I saw quoted some time ago. Just not sure on how they will fit with the Vorshlag mounts.
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| Ls or 2jz swap? | sgoldberg01 | BRZ First-Gen (2012+) — General Topics | 13 | 03-22-2016 03:07 PM |
| Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-21-2015 11:38 PM |
| AT-->MT swap | AlwaysSideways | Want-To-Buy Requests | 3 | 12-15-2014 11:14 AM |
| Should I swap? | michaelahess | BRZ First-Gen (2012+) — General Topics | 8 | 06-12-2012 07:32 PM |
