Old 01-07-2017, 10:04 AM   #211
sqd
sqd's Avatar
Drives: '13 SWP GT86
Originally Posted by fizzymike View Post
Can someone help me decide on tire sizing?
My wheel setup is staggered 18x9.5 -9 and 18x10.5 -19. Im looking to get the Toyo r888 but an not sure on tire sizing. I heard that 245-255 front and 255-275 for rear would be good but I'm not sure. For the setup the car won't be slammed low and I will have 3.5 degrees camber. I don't want the tire to look stretched either. any advice is appreciated thanks.
I'll be running R888 18x9.5 front with 245/40, and rear 10.5 with 285/35. Since I have to get PCD adapters to fit my 5x114.3 wheels, I'm still unsure what offsets to go with though. Thinking about -5 front and -15 rear?
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 01-07-2017, 07:55 PM   #212
fizzymike
fizzymike's Avatar
Drives: 2014 Silver BRZ
does it look stretch or is that meaty tires?
fizzymike is offline   Reply With Quote
Old 01-08-2017, 09:56 AM   #213
sqd
sqd's Avatar
Front will probably have a slight stretch, but still look meaty since R888 are fat tires, and 40 profile. Rears will be pretty square, so meaty as well.
IG @squareddesign
The Following User Says Thank You to sqd For This Useful Post:
fizzymike (01-13-2017)
Old 01-20-2017, 01:31 PM   #214
Sarusanj
Drives: 2015 FR-S
18x10.5 -13 Front
18x11.5 -26 Rear
Tires will be stretched accordingly. Hoping not massive camber, like -3 to -5 F/R. On V1 fenders, and coilovers as low as will allow with this fitment. I want flush as can be, or maybe a very slight poke. According to calculators, the rear seems totally fine, but it's the front I'm not 100% on. What do you guys think?
Sarusanj is offline   Reply With Quote
Old 01-21-2017, 04:57 PM   #215
azynneo
so I plan on going wheels first before fenders. Will a 18x10 -7 front and 18x11 -25-30 rub when turning on the stock fenders? I know this sounds stupid and everything should be done at once but is this a bad idea?
azynneo is offline   Reply With Quote
Old 01-23-2017, 11:20 AM   #216
JarredH
JarredH's Avatar
Drives: Scion frs
Toyota r888 275/35/18 on 18x10.5 +30 squared.
I have a 25mm spacer on the rear and a 22mm spacer on the front.
Rear sits perfect. Couldn't be happier about that. The front rubs a ton. Barely can turn without the tire crushing the fender liner. Any suggestions for tires sizes up front to prevent rubbing in front and behind the face of the tire?
It's practically touching the front bumper as you can see from the last picture
JarredH is offline   Reply With Quote
The Following User Says Thank You to JarredH For This Useful Post:
DustinS (01-28-2017)
Old 01-25-2017, 08:57 AM   #217
Sarusanj
Drives: 2015 FR-S
Cut the fender liner and bumper? Those tires are huge though. If you don't want to run stretched then you'll just have to adjust other things like ride height, caster, camber, etc.
Old 01-25-2017, 11:49 AM   #218
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
That will poke like crazy on stock fenders. The recommendation is to get the wheels + kit and then install at the same time. So you can adjust camber and make sure everything fits nicely.
I mean you could get the wheels on stock fenders, but you would have to run stock height so they dont hit your fenders lol. What kind of wheels were you looking at? Maybe I can help?
Kami Speed is offline   Reply With Quote
Old 01-27-2017, 08:30 AM   #219
sqd
sqd's Avatar
What the fuck
First the guy asking if 17x8 +40 is a good fit for RB fenders, now someone who wants to fit 18x11 -30 without a kit... I've seen it all!
IG @squareddesign
Tcoat (02-01-2017)
Old 01-28-2017, 12:45 AM   #220
churchx
churchx's Avatar
Drives: 2014 GT86
Given thick enough spacers (i guess, 500mm should do), you can forget about rubbing issues with any wheel! Well .. maybe steering angle in front also should be limited, but that's minor issue
Old 01-31-2017, 10:47 AM   #221
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
What are your camber settings? Looks like more camber to tuck under fender, as previously mentioned, you need to make modifications to the rest of the car to fit wide tires on a rocket bunny. Just the unfortunate side effect. Mainly cutting bumper, and knocking down the frame extension at the rear of the fender well.
I am showing a 18x10.5 et10 should be flush which is what I am going to shoot for. Then clearance the car for a 285 and eventually a 315.
Old 02-01-2017, 09:18 AM   #222
Aboodilatif
Aboodilatif's Avatar
Drives: '14 Red Toyota GT86 RocketBunny
ordered these.
will post pics when they arrive.
http://www.ravspec.com/shop/te37v5100gb
18×9.5 -15mm 5×100
18×11.0 -8mm 5×100
'14 Toyota GT86 - 2JZ GTE - R154 - GTX3582R 1.06 - Motec M130 PNP - RocketBunny v1
'09 Audi RS6 C6 - MTM 850HP
Aboodilatif is offline   Reply With Quote
Old 02-01-2017, 01:30 PM   #223
What the fuck
And people wonder why I lose my shit every now and again?
DustinS (02-01-2017), sqd (02-02-2017)
Old 02-02-2017, 02:21 AM   #224
sqd
sqd's Avatar
Right, but you'd go crazy either way, seeing how much you're here
Closing in on 35k posts.. You've lost your shit a long time ago
IG @squareddesign
Tcoat (02-02-2017)
Replica rocket bunny crildz Cosmetic Modification (Interior/Exterior/Lighting) 103 05-09-2014 04:35 PM
Rocket Bunny FRS in Dubai TAP Auto Parts FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 49 12-04-2012 01:39 PM
Red Rocket Bunny FR-S - Speedhunters RaceR FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 10-12-2012 12:48 AM
Rocket Bunny or Modelista? HELP!!! ShowstoppersUSA Cosmetic Modification (Interior/Exterior/Lighting) 21 08-16-2012 01:23 PM
GReddy/Rocket Bunny Wheels? Coultergeist Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-15-2012 02:39 AM
