Old 01-19-2017, 06:16 PM   #141
Teseo
Drives: frs
I got answer of weir, he was sick. So guys expect to recive a response of him. Now deciding which ratio to go.
The Following User Says Thank You to Teseo For This Useful Post:
Lonewolf (01-19-2017)
Old 01-20-2017, 10:45 AM   #142
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Breaking in my 4.56
Absolutely no gear noise!
Beginning to think I should have gone 4.88...
Can't wait to push them once broken in tho see the real difference. Then I will know for sure- but I can already state there is no problem with 4.56 on a daily driver...
nextcar is offline   Reply With Quote
The Following User Says Thank You to nextcar For This Useful Post:
jcw99 (01-21-2017)
Old 01-21-2017, 09:43 AM   #143
FRS_PR
FRS_PR's Avatar
Drives: Scion FR-S Ultramarine
Just placed my order for a 4.88 with Weir 2 days ago. Can't wait!!!!
FRS_PR is offline   Reply With Quote
The Following User Says Thank You to FRS_PR For This Useful Post:
Teseo (01-21-2017)
Old 01-21-2017, 10:16 AM   #144
Teseo
Drives: frs
Im looking forward to your review
Old 01-26-2017, 01:00 PM   #145
nextcar
Originally Posted by nextcar View Post
Breaking in my 4.56
So my gears are now broken in... and I have begun pushing them!
This is a nice improvement - the 4.56 gears are not radical by any means and are absolutely fine for a daily driver and freeway use. I like the ability to break loose off the line if desired (which I lost with my sticky tires), and there is definitely an improvement in acceleration.
As stated previously there is no gear whine/noise with the OEM part.
So, would I do it again? Perhaps...
This is not a cheap upgrade - I have about $1K all in (I opted to buy a entire 3rd member from a crashed FRS with 24K miles for $250, the gears were about $500, seals and gear setup ran $300).
The effects are noticeable but not drastic - I do wonder if I might have been happier with 4.88s - (I have a manual transmission - no question for an automatic). Of course gear noise and freeway driving might have been too much for me. I have a nagging doubt about not choosing 4.88; however I will never know...
Final conclusion: nice upgrade, a bit costly (though could have been cheaper with non-oem gears and no spare third member), total stealth mod and no California smog issues or dealer concerns, perhaps too conservative but still fun.
The Following 2 Users Say Thank You to nextcar For This Useful Post:
Lonewolf (01-26-2017), Teseo (01-26-2017)
Old 01-26-2017, 02:14 PM   #146
Teseo
Drives: frs
We need someone who is crazy enough to put 5.71 ratio and report it
Old 01-26-2017, 03:00 PM   #147
Icecreamtruk
Drives: Track preped NA FRS
Not worth at all, you basically loose one gear as your first gear is no longer usable and your six is basically what 5th was before. Speaking as someone with the 4.88 and I find it to be the highest you could go before losing utility on first gear.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Teseo (01-26-2017)
Old 01-26-2017, 03:23 PM   #148
ssidd
Drives: 2015 Scion FRS - Asphalt
I remember reading somewhere on this forums through the many threads that the FD upgrade threw off the Gear Count on the MT. I believe it was reading the incorrect gear because the TCU was calculating off of the RPMS & gear ratio.... not sure, can't remember what the logic/.theory was and i cant find the thread i initially read it in.
Is this effect true to the AT? I have an AT Frs and am planning to do a 4.88 FD upgrade. I wondering if the gear count in manual mode that is displayed will be incorrect? I.E. Display reads 3rd gear when I'm actual in 4th...etc. Also if it would confuse the TCU in any way regarding the AT's downshifting or upshifting... I assume it wouldn't be affected but i'm no expert
I would appreciate those with an AT and FD upgrade could chime in...
Thanks!
ssidd is offline   Reply With Quote
Old 01-26-2017, 03:52 PM   #149
Icecreamtruk
Thanks!
No it doesnt affect the automatic. The manual calculates gears like that because the transmission has no electronic controller (like the auto) to tell which gear it was in. Change the FD as much as you like, your car will keep on working the same way.
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
ssidd (01-26-2017), Teseo (01-26-2017)
Old 01-26-2017, 04:51 PM   #150
ssidd
Part Number help Sh944 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-14-2013 02:10 PM
what's the part number for this? chenshuo BRZ First-Gen (2012+) — General Topics 11 10-07-2013 11:22 AM
Part number for Toyota 86 GT Limited red leather seats? iketiak Scion FR-S / Toyota 86 GT86 General Forum 8 04-10-2013 11:54 AM
I need a part number Bones36 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-01-2012 05:25 PM
Part Number for this DriftEightSix AUSTRALIA 20 06-25-2012 08:30 PM
