Drives: 2014 Raven Scion FR-S
Turbo help
Not sure if this topic belongs here or somewhere else, if so please place it in the correct section.
My buddy and i will be putting a turbo into his car in the next few months, he has a 2013 FR-S Automatic transmission. My FR-S is a manual and i'm not sure which turbo we should purchase for him. We were considering the Greddy 518v kit or the MAPperformance FA20 precision kit, but i realized a completely stock MANUAL FR-S might have clutch problems with either of these kits, so i'm not sure if they would be the best in an automatic. If anyone could provide me with information on a decent working turbo kit for an automatic kit, it would be much appreciated. |
#2 |
Drives: 2014 frs
if you keep the torque low and under 300whp then you don't need a clutch
#3 | |
The forum has a forced induction section that you may wish to check out ..... maybe ask over there ...... ![]() humfrz |
#5 |
Drives: 2014 Scion FRS (Asphalt)
Personally I'm running 220 torque on an AT with a stage 2 avo turbo, it's been holding up well. I'm not sure what the max torque that would be reliable for an AT though.
#6 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
It should hold fine in terms of catastrophic failure from failure from what I have read. But from talking to a local tuner on FI cars that have AT the fluid is taking a beating from the extra heat which could lead to premature wear. I would ask in threads for each kit for AT guys and also talk to the companies themselves
#7 |
Found some old threads for you.
http://www.ft86club.com/forums/showthread.php?t=18868 It states that the auto torque capacity is 300nm which equates to 220 ft lbs. But here's some real world data http://www.ft86club.com/forums/showthread.php?t=106593 There's a couple autos running 340 - 400 ft lbs reliably. I know AVO Japan has been testing an auto that runs around 260 ft lbs for quite a while now. I would probably stay under 260 ft lbs to keep it safe. As mentioned above, the #1 killer of our transmissions is heat. It's best to get a transmission cooler and high temp auto transmission fluid if you plan on running the car hard for extended periods of time. Personally I run Redline D6. |
#8 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Yeah I run a turbo automatic FRS and so far so good. I love not losing boost between shifts :p
| To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 07:33 PM |
| FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices | FullBlown | Forced Induction | 588 | 12-02-2015 02:41 PM |
| Bren5279's Full turbo partout (JDL uel turbo, Greddy Evo 3, AEM gauges, + More) VA | bren5279 | Engine, Exhaust, Bolt-Ons | 69 | 06-29-2015 10:56 PM |
| Greddy turbo kit and AVO world turbo kit SPECIAL PRICING! | THMotorsports.com | Forced Induction | 129 | 07-24-2014 06:51 PM |
