Old 01-19-2017, 10:51 AM   #15
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
A lot of great suggestions in here. I'd also add an allowance for oil coolers, since they aren't really going to do much for you in autox anyway and it'll allow those who also participate in HPDE to participate in an autox class with rules that would make for a decent mild track day prep too.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following 2 Users Say Thank You to Shark_Bait88 For This Useful Post:
juliog (01-19-2017), whataboutbob (01-19-2017)
Old 01-19-2017, 11:39 AM   #16
Racecomp Engineering
This could be interesting. I think somewhere between CS and STX is the sweet spot as others have mentioned, along with enough allowances that make sense for FRS/BRZ drivers that make sense (like the oil cooler).
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
cjd (01-19-2017), Shark_Bait88 (01-19-2017), whataboutbob (01-19-2017)
Old 01-19-2017, 01:26 PM   #17
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by stock View Post
To me the header/reflash is basic kit for this car. Adds no weight, fairly easy to install yourself, removes nothing from the original design intent.
Except street legality.
ineedyourdiddly
Old 01-19-2017, 02:59 PM   #18
stevesnj
stevesnj's Avatar
So is Solo2 Autocross or Track?
My 2016 Build thread
Old 01-19-2017, 03:29 PM   #19
redlined600
redlined600's Avatar
Drives: Fr-s
Autocross
I'd argue against the whole idea of a spec class, in part for the reasons Tqless wonder already stated. Once you spec things people will open their wallet to find any edge.
The closest thing to a spec class now is the car de jour in any street class. The twin already has places to play and if the miata didn't warrant a spec class then the twin sure won't.
Finally, you want to talk about the mother of all take-backs once participation wanes and the class evaporates.
redlined600 is offline   Reply With Quote
The Following 3 Users Say Thank You to redlined600 For This Useful Post:
justint5387 (01-21-2017), strat61caster (01-19-2017), whataboutbob (01-19-2017)
Old 01-19-2017, 04:54 PM   #20
Shark_Bait88
Yeah, as much as I like the idea I think it would spread things too thin between three classes (spec, street, and street touring). With a lot of participation it could be fun, but making the idea work in reality would probably prove pretty difficult.
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Old 01-19-2017, 05:36 PM   #21
TrqlessWonder
Drives: 2014 FR-S
Well, whether it happens can be heavily influenced by where the alleged "groundswell" is coming from.
From the participants, mixed luck. From above (national office)? I present to you Heritage Classic...
And that's kind of hints at the basic situation. Who knows if it'll happen, and who knows what it'll look like? That said, this is probably one of those "write your letters" kind of things. Only the vocal get heard.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
The Following User Says Thank You to TrqlessWonder For This Useful Post:
Old 01-19-2017, 06:27 PM   #22
xwd
A spec class has to use specific parts for suspension/power, no real room for interpretation. 17x8 wheels, tires open.
The Following 2 Users Say Thank You to xwd For This Useful Post:
Shark_Bait88 (01-20-2017), whataboutbob (01-19-2017)
Old 01-20-2017, 01:27 AM   #23
renfield90
The Stig's German cousin
People already bring sticker tires for nats, it's part of the game. Hell I know of some SSR ballers who have brought one full sticker set PER DAY.
You want the car to be tunable, which is why off the shelf SA Konis are a great idea. But part of the cost control is limiting innovation and saying "thou shalt use this part, and no other" so you really don't have much creativity to find an edge over someone. Spec Miata is an example of spec racing gone too far (who here remembers what a plunge cut is?) but there are plenty of other good examples of what a spec series could look like. I actually built most of a Spec E30 on a college student budget way back when (not counting safety stuff, but hey, the car was pretty fun).
I'll also point out, there's no reason this has to happen under the SCCA umbrella. We can make our own sanctioning body, get insurance, and hold events across the country. Maybe pair up with all those 86 fests that keep popping up everywhere. I'd say this is actually more likely to succeed than trying to go through the SEB. Given that the twins are potential overdogs in DS, sorta viable in CS, and top contenders in STX, it's a tough sell to add yet another class that would probably draw people from all three of those rather than bring additional fresh blood into the sport.
It's fun to think about, but if you're serious about making this happen, you need to have clear goals and vision for the spec class and who you're going to draw into your events.
Old 01-20-2017, 12:23 PM   #24
TrqlessWonder
Drives: 2014 FR-S
Careful, there. No room for interpretation does not equal no room for variation. Everything that's made, is made within a tolerance of some sort/size.
OTS shocks only have to be in a range. If they're tested at the factory, they might be on a sampling plan, and an odd set might sneak through. So some will spend the time and effort to find well-matched shocks, with the measurements all the way at one end of the tolerance range. Others might look up the acceptable limits for the size of crash bolts or size of the strut slots, and do the work to get at the limits of those ranges.
That's just the most front-of-mind example. Here you'd have two cars, running all the same part numbers. One guy was just a little more in the spirit of the rules, and literally bolted up whatever he got out of the box. The other guy has shocks matched left to right with much more of an ideal dyno curve, and is carrying another 2-3 tenths more negative camber.
These are the kinds of things I'm talking about when I say it's hard for a rules-making committee (SCCA, NASA, Optima, Good Guys, doesn't matter) to control for. It might not happen right away, but by the third season, we'll have dorked it up for ourselves.
-Mike
#24 CS/CSR
Old 01-20-2017, 01:10 PM   #25
M0nk3y
I highly doubt there will ever be a Spec class of any car ever. We don't need more classes, and this is exactly what this does.
The Following 3 Users Say Thank You to M0nk3y For This Useful Post:
Biggins (01-20-2017), G_Ride (01-21-2017), justint5387 (01-21-2017)
Old 01-21-2017, 03:08 AM   #26
justint5387
Drives: 4 wheels
What's the point?
justint5387 is offline   Reply With Quote
The Following 2 Users Say Thank You to justint5387 For This Useful Post:
APEXIT53 (01-23-2017), G_Ride (01-21-2017)
Old 01-21-2017, 01:52 PM   #27
APEXIT53
Drives: 17 Camaro SS
hmmm, not exactly sure what I think of this. There are already sooooo many classes in scca solo as it is. The two strongest numbered classes last year were CS and STX so something is currently working. STX almost already is SPEC BRZ/frs/86 as it is and the longer they own the class the more prepped cars you will see out there. That said a few people have proven that the class can be competitive on a 5k build.
Im not entirly sure what adding a in between class would really do but thats just me.
APEXIT53 is offline   Reply With Quote
The Following 2 Users Say Thank You to APEXIT53 For This Useful Post:
justint5387 (01-22-2017), strat61caster (01-21-2017)
Old 01-21-2017, 02:08 PM   #28
bslate3
Drives: 2015 CWP BRZ
I like the idea of a spec 86SM class. It would be cool to see what people can come up with.
But a slightly cheaper option would be the CSP86 class.
bslate3 is offline   Reply With Quote
SCCA pro solo what class TRD_Demon527 Tracking / Autocross / HPDE / Drifting 34 05-11-2015 11:45 PM
What Class do you think the Twins would go to for SP??? Scooby South Tracking / Autocross / HPDE / Drifting 40 01-14-2014 01:16 PM
SCCA Class Reshuffle trippinbillies40 Tracking / Autocross / HPDE / Drifting 34 05-15-2013 04:46 PM
Help determining SCCA Class mrjester Tracking / Autocross / HPDE / Drifting 6 04-28-2013 04:58 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
