Old 03-16-2016, 08:03 PM   #155
atlbrz
Drives: Hyper Blue BRZ
When I remove the spring my first thought was to cut it down to about 1/3 of it's original length so it would be long enough to provide some tension while the pedal is at the top position, but short enough so it didn't assist with pedal effort. Then I thought I had a short spring in the draw. The spring is only about 1/4" in diameter and about 3/8-1/2" long. It is just long enough to provide a little bit of pressure so the pedal doesn't sag. The first 1/2'' of pedal travel is softer with the main spring removed. Did anybody else consider cutting down the spring or inserting a smaller spring? See pic.
atlbrz is offline   Reply With Quote
Old 03-19-2016, 12:44 PM   #156
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
After owning my car for 3 years, I decided to finally do this mod. I should have done it a long time ago, I like the pedal feel alot better and i'm sure driving will be smoother shifting between 1st gear to 2nd gear. Anybody on the fence should quit waiting and do this mod. It is not that hard to do.
malubawla is offline   Reply With Quote
The Following 2 Users Say Thank You to malubawla For This Useful Post:
funwheeldrive (07-22-2016), jcw99 (01-09-2017)
Old 03-19-2016, 02:00 PM   #157
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
New thread is live here: http://www.ft86club.com/forums/showthread.php?t=103157
Moving forward, post comments in that thread if possible. This is the best I can do currently.
Glad most/all of you are liking the modification!
VerusEric is offline   Reply With Quote
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
Sosa (03-19-2016), Whodunit (03-20-2016)
Old 03-19-2016, 10:05 PM   #158
ButeraFRS
Guest
Posts: n/a
if anyone in the GTA (Vaughan) area wants to do this for me I'll toss you a beer or a shot of Jack if you'd lik3
haha I don't have the tools and I don't wanna fuck anything up but I really want this done.
Old 03-20-2016, 04:11 AM   #159
joe strummer
Wow, what would a GTA (Vaughan) resident do for a bottle of Jack?
joe strummer is offline   Reply With Quote
Old 03-20-2016, 04:38 AM   #160
ButeraFRS
Guest
Posts: n/a
clean and claybar the car on those days I'm too lazy to do it. haaha
Old 01-05-2017, 01:46 PM   #161
STEWARDORNG
Drives: 2016 BRZ
If you want to put the spring back in the best way I found was to compress the spring in a vise and use some safety wire wrapped around it twice on two sides you don't even need to compress it all the way for it to fit back in place eaisely I tired some heavy duty zip ties the kind with the metal tang and they kept breaking.
STEWARDORNG is offline   Reply With Quote
The Following User Says Thank You to STEWARDORNG For This Useful Post:
funwheeldrive (01-11-2017)
Old 01-11-2017, 10:08 AM   #162
sato
sato's Avatar
Drives: Dodge Patitas
I used zip ties and vice too. Worked AOK.
Sent from my A1P using Tapatalk
sato is offline   Reply With Quote
Old 01-11-2017, 12:38 PM   #163
funwheeldrive
Why did you guys put it back on?
The Following User Says Thank You to funwheeldrive For This Useful Post:
jcw99 (01-11-2017)
Old 01-14-2017, 07:14 PM   #164
STEWARDORNG
Drives: 2016 BRZ
I tried a lighter spring I had and did not like it I might try without sometime. But I have a repaired knee and I am old :-)
Old 01-16-2017, 10:25 AM   #165
sato
sato's Avatar
Had some noise, vibration in clutch pedal. Wanted to see if it was related, although I was sure it was being transmitted thru pedal and coming from elsewhere else.
The Following User Says Thank You to sato For This Useful Post:
funwheeldrive (01-16-2017)
Old 02-14-2017, 11:44 PM   #166
JohnnieBoy
JohnnieBoy's Avatar
Drives: 13 BRZL/12 Tundra TURD/09 FJR 1300
So rather than delete the spring all together, I installed an Mtec clutch spring today. I just like the idea of a smoother pedal return and as some have referred to it, no slop at the top. Great product, best of both worlds - I think anyway. I can now feel the clutch... little heavier pedal but with smooth return and positive engagement. Win win.
http://www.modbargains.com/MTEC-Ind-...Z-86-MCS86.htm
I have the two shift springs by them and a Perrin rear shift rod bushing in my garage slated for install next.
JohnnieBoy is offline   Reply With Quote
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 12:40 PM
Car dies after 15-20 minutes? PolishFrs13 Issues | Warranty | Recalls / TSB 28 10-08-2015 04:28 PM
Toyota 86 in 10 minutes. KKaWing FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 03-28-2013 09:06 PM
32 Hours 7 Minutes Wes B. Other Vehicles & General Automotive Discussions 11 12-26-2012 09:10 AM
How to hack a BMW and steal it in 3 minutes Dadhawk Other Vehicles & General Automotive Discussions 9 07-11-2012 12:11 PM
