Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > DIY (Do-It-Yourself) Guides
Old 03-19-2016, 01:35 PM   #1
VerusEric
Design Guy
VerusEric's Avatar
Drives: 2014 BRZ, 1993 MR2 Turbo
How To: Free Clutch Spring Removal in 15 Minutes - A must do for manual trans!
Starting a new thread as my old account was banned and I have received multiple requests asking for picture links to be fixed. Figure we can just let that thread die, and start fresh!
The twins have a clutch spring that greatly reduces the strength needed to push the clutch in. This is actually a really neat idea from Toyota/Subaru, and it is the first time I’ve seen it used and it does a great job. However, this also leaves the pedal without any feel, making it much more difficult to drive smoothly. This spring can be removed with relative ease, and in under 15 minutes with a little know how.
Tools Needed:
  • Needle Nose Pliers
  • A flashlight
  • Screwdriver
First, lets familiarize ourselves with what is under the dash.
Circled in red is the spring assembly we are going to remove.
You’ll want to slide the seat all the way back and place the flashlight so that you can see what you’re working on. I also cleaned the spring at this time, it’s fairly caked on from the factory.
E-Clip is circled in red.
Looking at the assembly from the passenger side of the car, we see a clip (specifically called an “E” clip) that holds the stud in place. We will need to remove this.
Needle nose pliers positioned to remove clip.
Twist the E-clip so that the opening faces down. Using the needle nose pliers, one tong on each side of the clip, gently push up or hit the handle with your hand. Be careful not to lose this clip.
E-clip removed
With the E-clip removed, we are now able to remove the stud. The spring has considerable pressure, as I’m sure you’ll see, which makes removing this stud difficult. Depressing the clutch pedal (pedal on the ground), releases some of this pressure. Push the clutch pedal all the way in, and with the needle nose pliers, push the snout (E-Clip side) towards the drivers side. This should give enough room for you to use the needle nose on the other side of the stud. Using the pedal as leverage for the pliers, pull the pin the rest of the way out while the clutch is depressed. Next, using the flat head, push on one of the legs of the clutch clevis upward. This will take some force but it will come off!
All the components off the car.
Re-assemble and push the E-clip on with the needle nose or the flat head. Both methods should work well. This is not necessary but I felt I was less likely to lose everything this way if I wanted to revert back *Hint: NO ONE DOES!*
Thanks for reading and let us know if you have any questions.
Previous thread: http://www.ft86club.com/forums/showthread.php?t=84622
General consensus from previous thread: This is the best free modification you can do to a manual transmission FRS/BRZ/GT86 to make the clutch pedal *feel* more like a normal clutch.
VerusEric is offline   Reply With Quote
The Following 24 Users Say Thank You to VerusEric For This Useful Post:
200hp/tonne (07-29-2016), Brzzee (07-28-2016), cbryant514 (08-02-2017), Drakiv (03-20-2016), D_Thissen (03-31-2016), Gin Ryuu (09-12-2016), HSUBLU (09-07-2017), jcw99 (08-02-2016), jcz (06-27-2016), JMon85 (06-03-2018), jonboy99 (11-22-2017), Mazikowski (04-19-2016), mixtape (03-31-2016), Pointmutation (04-24-2016), SkAsphalt (07-28-2016), Spectre20 (09-14-2016), stock (06-04-2016), Strife26 (01-19-2018), tato.valverde (03-20-2016), Teseo (02-25-2017), TofuJoe (09-24-2017), toyubie (10-13-2017), Trap63 (07-20-2016), VenomRush (05-25-2017)
Old 03-19-2016, 03:06 PM   #2
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
After owning my car for 3 years, I decided to finally do this mod. I should have done it a long time ago, I like the pedal feel alot better and i'm sure driving will be smoother shifting between 1st gear to 2nd gear. Anybody on the fence should quit waiting and do this mod. It is not that hard to do.
malubawla is offline   Reply With Quote
The Following 3 Users Say Thank You to malubawla For This Useful Post:
Curtski96 (04-08-2016), funwheeldrive (08-23-2016), Plumbus (09-12-2019)
Old 03-19-2016, 03:58 PM   #3
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
I read somewhere that this is actually bad for the car, can someone chime in on this? I actually wanna try this, but I don't wanna break anything in my car over something as simple as this.
Alltezza is offline   Reply With Quote
Old 03-19-2016, 04:56 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
nope, not bad for car at all.
Plenty of us have this done, myself included (for probably 35k now? and over 2 years)
Old 03-19-2016, 06:16 PM   #5
Alltezza
Alltezza's Avatar
That's all the assurance I need, before I do this. How does this affect aftermarket clutches that most of us are probably going to be installing in the future like ACT for example?
Old 03-19-2016, 06:27 PM   #6
stevesnj
stevesnj's Avatar
I did this as soon as I could after I bought the car. I just couldn't feel feedback at all it was so light. It's just a nanny for under 25 guys with delicate feet.. jk of course :P
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
FRSBRZGT86FAN (04-03-2016)
Old 03-20-2016, 08:59 PM   #7
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
The purpose of the spring is to help people with depressing the clutch pedal to the floor. When you remove the spring, you remove the help, making the pedal harder to depress. So in the future, if you put in a heavier clutch, the pedal will feel that much harder to depress.
Just do more squats.
2013 Subaru BRZ Limited Crystal Black Silica (Sold.)
2006 Lotus Exige Aspen White (Supercharged Honda K24A2 swapped.)
2007 Suzuki SV650 (Track bike.)
akiranakayama is offline   Reply With Quote
The Following User Says Thank You to akiranakayama For This Useful Post:
Alltezza (03-20-2016)
Old 03-21-2016, 09:39 AM   #8
HunterGreene
Hail Magnet
HunterGreene's Avatar
Did this mod last year and haven't regretted it since.
As to those who are worried about the clutch being too heavy after going aftermarket, I'm pretty sure there is an aftermarket helper spring (I forget who makes it) that still maintains the clutch feel while not making it as vague as the original.
It has priests in it?
Old 03-21-2016, 11:33 AM   #9
continuecrushing
It'll have higher pressure vs a clutch-spring-installed car, but the upside is you'll know what the hell your clutch is doing!
The Following User Says Thank You to continuecrushing For This Useful Post:
JazzleSAURUS (03-28-2016)
Old 03-21-2016, 03:41 PM   #10
Sosa
[||]--(86)--[||]
Sosa's Avatar
Drives: 2015 Firestorm FR-S
Originally Posted by HunterGreene View Post
there is an aftermarket helper spring.
It's made by MTec:
http://www.ft86speedfactory.com/mtec...l#.VvBOZXNrnqA
[||]==(86)==[||]
Sosa is offline   Reply With Quote
The Following 3 Users Say Thank You to Sosa For This Useful Post:
DaBoBo21 (08-09-2017), funwheeldrive (08-23-2016), HunterGreene (03-21-2016)
Old 03-21-2016, 04:29 PM   #11
SLVRSRFR
Drives: 2013 BRZ, 2005 Legacy 2.5GT 5-speed
In before that guy starts posting about how this does nothing and you should change your clutch slave instead...
In all seriousness, I'll reiterate what I posted in the other thread, by saying that this is one of the best mods I've done to my car in terms of driving enjoyment, and it's relatively simple, and FREE (besides time spent, of course). Do it!
@bpennerz
SLVRSRFR is offline   Reply With Quote
The Following 2 Users Say Thank You to SLVRSRFR For This Useful Post:
Calum (03-29-2016), tato.valverde (03-22-2016)
Old 03-27-2016, 04:19 AM   #12
joe strummer
I did, and I agree. The clutch feel is much improved. Well worth the effort.
And also in all seriousness, I swapped out the slave cylinder before this mod, then reinstalled it. Could be my ignorance, but didn't feel much, if any, difference. Maybe I'll try again.
joe strummer is offline   Reply With Quote
Old 03-27-2016, 12:06 PM   #13
mpross
mpross's Avatar
Drives: 2015 Scion FRS
This really is a must for our cars. I thought I'd just forgotten how to drive because I could never get a feel for the clutch pedal when i first bought it. Removed the spring about six months ago and it was a whole new car.
Sent from my SAMSUNG-SM-G928A using Tapatalk
mpross is offline   Reply With Quote
Old 03-28-2016, 05:42 PM   #14
mcrane
mcrane's Avatar
I did this mod a couple months ago. Definitely worth taking the time to do it. The clutch feels alot more traditional now IMO.
mcrane is offline   Reply With Quote
Search this Thread:
Advanced Search
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 182 01-29-2018 04:57 PM
How To: Clutch Spring Removal in 15 Minutes eric6 DIY (Do-It-Yourself) Guides 165 02-15-2017 12:44 AM
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 04:42 AM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 10:14 PM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 08:08 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
