Old 01-08-2017, 08:46 PM   #1
allowe
allowe's Avatar
Info on unmarried oft
Tomorrow, I'm buying an open flash tablet off someone. How do I know if it's unmarried and are there things I should check for before buying it
Thanks
allowe is offline   Reply With Quote
Old 01-08-2017, 10:16 PM   #2
phrosty
iirc it won't allow you to read the current tune if it already has one in it.
phrosty is offline   Reply With Quote
Old 01-09-2017, 12:41 AM   #3
allowe
allowe's Avatar
Thanks for your reply, when I plug it into my car, how do I know it's unmarried (hoping that's the way to know) do I have to flash it on the spot, or can I just check wether it's unmarried or not
Old 01-09-2017, 12:54 AM   #4
steve99
Drives: FT86
see oft tips link below
The Following 2 Users Say Thank You to steve99 For This Useful Post:
carsebuco (01-09-2017), Tcoat (01-09-2017)
Old 01-09-2017, 08:47 AM   #5
allowe
allowe's Avatar
Where's the link
Old 01-09-2017, 08:58 AM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by allowe View Post
Where's the link
Yay Tapatalk suckage. It's in his signature. Or here...
http://www.ft86club.com/forums/showthread.php?t=71157
The Following 2 Users Say Thank You to cjd For This Useful Post:
allowe (01-09-2017), yelsew (01-09-2017)
Old 01-09-2017, 08:59 AM   #7
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Where's the link
It was in his signature, but those don't show on Tapatalk. Here I'll link it here for you. http://www.ft86club.com/forums/showthread.php?t=71157
Its a great read, and Steve is a master resource on this thing and tuning with it.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following 3 Users Say Thank You to yelsew For This Useful Post:
allowe (01-09-2017), carsebuco (01-09-2017), Teseo (01-09-2017)
Old 01-09-2017, 11:42 AM   #8
allowe
allowe's Avatar
I don't want to make another post. Before I buy it , I have an injen intake. I've been told that after tuning it, my car will run smoother, will the open flash tablet help make it smoother ? Also , my car was made in the time where the direct injection problem was there. Will this help? Do I have to change my injectors
What I'm most concerned about is if oft works with the intake and if it makes the car smooth. Not looking for power, just smoothness over the rev range
Old 01-09-2017, 11:50 AM   #9
Originally Posted by yelsew View Post
Its a great read, and Steve is THE master resource on this thing and tuning with it.
FIFY
yelsew (01-09-2017)
Old 01-09-2017, 04:12 PM   #10
steve99
Drives: FT86
Ok the OFT tunes are made for stock intake.
If you have an injen intake you will need to rescale the MAF (mas air flow sensor) to suit the new intake to get best results from tune, or put the stock intake back on car.
Early cars before mid 2013 from memory had a rom calibration with an error that caused excessive knock on upshifts when the shift occurred at or near redline. The problem was increased of you ran poor quality fuel like 91 usa fuel.
The oft tunes are based on the later calibrations which have the transient ignition retard enabled correctly.
you wont need to replace DI injectors unless they are already damaged, di seal failure usually results in poping out of the intake and sometime but not always CEL light and codes for misfire, but this can also indicate coil pack problems. Generally the DI seal problem only occurred on car tracked and driven very hard.
Teseo (01-09-2017)
Old 01-09-2017, 04:18 PM   #11
allowe
allowe's Avatar
Can it be rescaled using the oft? Thanks for your input
Old 01-09-2017, 05:13 PM   #12
steve99
Drives: FT86
Yes you can use oft and romraider to rescale maf sensor
http://www.ft86club.com/forums/showthread.php?t=64790
using romraider
http://www.ft86club.com/forums/showthread.php?t=79152
vgi maf scaling tool
http://www.romraider.com/forum/viewt...p?f=32&t=10481
WTB: OFT Unmarried vinhdt Australia Classifieds 0 09-08-2016 06:16 PM
WTB- OFT unmarried Shaunybumpkins Want-To-Buy Requests 1 07-12-2016 10:56 PM
OFT unmarried phatfil Engine, Exhaust, Bolt-Ons 0 10-31-2015 12:29 PM
FS - OFT unmarried Optimus Prime Engine, Exhaust, Bolt-Ons 4 09-03-2014 09:38 PM
