Old 01-04-2017, 01:03 PM   #2619
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I just do the plate adjustment, zero toe at max camber, the front will toe out as you go positive camber so if you need less camber for an event you'd get a touch of toe out which isn't a bad thing.
Going more positive for driving back and forth to the event, balancing how much toe out you want to live with, got solid wear out of my ZIISS with that strategy, ~20k miles and a season of non-competitive autocross, ~3 track days.
You could also figure out a toe adjustment between an autox and street settings to do at home pre/post event, a simple string box in your driveway and a weekend of tinkering, turn tie rods X times to go between street/autox, should be pretty easy to replicate and not a huge time sink.
ineedyourdiddly
finch1750 (01-04-2017)
Old 01-04-2017, 03:32 PM   #2620
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
My driveway is nowhere near flat or level so a diy is kinda out of the question. I think the zero toe and might have the shop mark the plates at -2.5 and -3 to adjust more simply will be the ticket til I get my daily wheels in Summertime. Then ill just get cheaper tires to daily and not care if the alignment hurts them a bit lol
DocWalt (01-04-2017)
Old 01-04-2017, 10:33 PM   #2621
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by renfield90 View Post
Sounds good.
For anyone with plates who goes in for a custom alignment, it's worth having the tech work through a few different settings on the plates to see what values they generate. If your plates don't have markings, add some. That way you don't need to cough up more money if you decide you want 0.5 degrees more camber in a couple months.
This is a very good suggestion and shouldn't add much cost to your alignment if they know when they're doing.
I did mine at home and it took very little time.
redlined600 is offline   Reply With Quote
The Following 5 Users Say Thank You to redlined600 For This Useful Post:
finch1750 (01-05-2017), justinco (01-17-2017), Keenercarguy (01-14-2017), Racecomp Engineering (01-13-2017), Shark_Bait88 (01-05-2017)
Old 01-07-2017, 03:00 AM   #2622
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Hey all!
Haven't been around for a while but was thinking of hitting the local Autox again.
Would any of you know if the Whiteline rear upper control arm bushing set is legal for STX? If so, is it worth the upgrade?
Thanks!
Here's a link to the bushings.
http://www.ft86speedfactory.com/whit...l#.WHCfSrU76aM
RiskyTrousers is offline   Reply With Quote
Old 01-07-2017, 03:21 AM   #2623
finch1750
finch1750's Avatar
Originally Posted by RiskyTrousers View Post
Hey all!
Thanks!
Its legal, but just get the non adjustable along with LCAs. Your alignment guy will thank you. I have them (installed a few years ago) but will be swapping them out due to most places charging more to because theyre a bitch. Pita to install, pita to adjust. But they do really solidify the rear end but adds some harshness to the ride in exchange
Old 01-08-2017, 08:45 PM   #2624
redlined600
Drives: Fr-s
Is there a list a STX legal RLCAs?
Racer x
Rs-r
Velox
Old white line
SPC/new whiteline with poly bushing.
Am I missing any?
Old 01-08-2017, 09:12 PM   #2625
finch1750
finch1750's Avatar
Racer x
Rs-r
Velox
Old white line
Am I missing any?
A list is included here
http://www.ft86club.com/forums/showthread.php?t=103609
Old 01-09-2017, 10:12 AM   #2626
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Really looking forward to the autox season starting again, but thankfully being in the Midwest doesn't mean I have to stop racing in the winter!
What's an off-season?
Killin' cones year-round
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
G_Ride (01-09-2017)
Old 01-11-2017, 11:08 AM   #2627
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Anybody in STX running RCE Tarmac 2's with stock sway bars? Right now I'm running Whiteline 20mm front bar and I hate it. It makes popping sounds pretty often and I can never get rid of it. I thought maybe I could just put the stock bar back on and compensate with damping?
smg1138 is offline   Reply With Quote
Old 01-11-2017, 12:09 PM   #2628
redlined600
Drives: Fr-s
I was, but switched to a Perrin rear bar. 450f/500r rates I think I'm going to try 550 rear this year and go back to the stock bar.
I'm only locally competitive and compromise between a car that's track and autox. so take with lots of salt.
The Following User Says Thank You to redlined600 For This Useful Post:
smg1138 (01-11-2017)
Old 01-11-2017, 01:37 PM   #2629
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'd try different end links before ditching the bar...
That said, I think a stock bar setup with the 400lb springs all around is fairly similar to the setup I ended up with, but keep in mind it'll be a little more playful at the limit and you're going to lose time being sideways more often.
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
justint5387 (01-12-2017), smg1138 (01-11-2017)
Old 01-11-2017, 01:55 PM   #2630
renfield90
The Stig's German cousin
You can sorta compensate with damping, but keep in mind shocks are primarily a tuning tool for transitional phases and sway bars are primarily a tool for steady state phases.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
DocWalt (01-11-2017), smg1138 (01-11-2017)
Old 01-11-2017, 02:14 PM   #2631
smg1138
smg1138's Avatar
I've tried shorter endlinks that I bought from Feal, but I still get pops. Maybe it's just unavoidable with aftermarket sway bars. The stock bar was always dead quiet, even with the stock endlinks.
Old 01-11-2017, 02:22 PM   #2632
strat61caster
My 20mm whiteline is relatively quiet, gotta really crank down on those endlink nuts, I think the whiteline links kinda suck, they're on my list of things to replace, probably with just hardware store parts like I did for my rear end links.
Hell maybe just try the stock endlinks for a day if your dampers aren't totally whack on the mounting points.
ineedyourdiddly
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
