View Poll Results: Have you had an issue with your Direct Injection System?
I have had a DI issue and was fixed under warranty (Subaru) 10 12.35%
I had a DI issue that caused Engine Failure and was fixed under warranty (Subaru) 2 2.47%
I have had a DI issue and was fixed under warranty (Toyota) 31 38.27%
I have had a DI issue that caused Engine Failure and was fixed under warranty (Toyota) 3 3.70%
I have had a DI issue and denied warranty by (Subaru) 7 8.64%
I have had a DI issue and denied warranty by (Toyota) 14 17.28%
I had a DI issue that caused Engine Failure and was Denied warranty (Subaru) 8 9.88%
I had a DI issue that caused Engine Failure and was Denied warranty (Toyota) 6 7.41%
Voters: 81. You may not vote on this poll
Old 01-04-2017, 03:24 PM   #547
MagicMexican
Drives: 2013 BRZ Premium
Defrost uses air conditioning to dehumidify the interior, I bet you're using the A/C a lot actually given that it's winter and you're in a snowy climate.
This^ My AC kicks in about three times as often when in defrost /heat mode than it does in actually cooling the car. It only runs for short bursts to dry the air opposed to longer periods required to actually cool it. This results in a much more frequent impact on the idle. First car I have had where you can't turn the function off when heating so it took some getting used to. Don't even notice it anymore.
Oh duh! I actually knew that, I swear I just forgot lol.
MagicMexican is offline   Reply With Quote
Old 01-04-2017, 03:46 PM   #548
Imrac
Drives: 13 SWP BRZ Prem
You can turn off the AC by using the throttle
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 01-04-2017, 03:49 PM   #549
OK for summer. Not such a great idea when in defrost mode in the winter. Unless ice racing of course.
Old 01-04-2017, 04:13 PM   #550
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Why else would you leave the house when it's snowing?
Oh right, Canadian internet sucks more than US internet, no working from home for you guys
ineedyourdiddly
Old 01-04-2017, 05:03 PM   #551
Be really hard for me to work from home. Besides I don't want to stay in the house 5 months of the year!
Old 01-04-2017, 08:01 PM   #552
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
no its the poor factory tune on low quality petrol causing excessive knock on high rpm shifts.
http://www.datazap.me/u/steve99/sout...=1477440000000
notice IAM=0.2 and still getting over -3 degrees knock correction at high rpm shifts and high load, the knock kills the DI seals
Afaik only the transient knock (coming off throttle) is dangerous for DI seals.
On throttle knock while IAM > 0 is admittedly close to, but still within safe working limits.
Old 01-04-2017, 08:35 PM   #553
steve99
Drives: FT86
yep if the iam is above 0 then the ecu still has some room to control knock correction magnitude
apparently even if the iam is =0 the flkc can still retard timing up to the flkc limit set in tables about -5 I think
id be worried about the size and consistency of the knock corrections.
at least when you have iam active (above 0 ) the ecu can reduce the magnitude of the corrections although at 0.2 its got very limited scope to do so
so any flkc corrections wont reduce in size if iam is 0 or close to 0, you just keep getting the knock then the correction, without any magnitude reduction.
yep for sure knock at high rpm/load/cylinder pressures much more dangerous.
I think that why the south Africans has so much problems with DI seals early on.
High temps, no transient retard on early roms, crap fuel (95 ron best they get) alreay very low IAM so they got consistent large knock correction that could not be significantly reduced by IAM.
Old 01-12-2017, 06:12 PM   #554
MagicMexican
Their is TSB out for dealers to flash cars prior to B01C/D calibration to that ECU calibration generally cars built prior to late 2013
http://www.ft86club.com/forums/attac...1&d=1386706237
and
http://www.ft86club.com/forums/attac...1&d=1395947828
just complain of rough idle and idle dips when a/c cut in/out
Just an FYI, I went down to the dealership, handed them the TSB I printed out, and they had my ECU reflashed under warranty without any hiccup. That's a huge weight off my chest! Thanks, I really appreciate your help.
direct injector, engine, failure, meet regal's paranoia, poll, regal's witch hunt, regalnoia, seal, sealions, silly sausage
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 06:54 AM
Wilwood Failure SubieNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 04-09-2013 08:32 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
