#393 |
Drives: FT86
B01C will run in all manual cars up to 2016 ie including F40C
so what you need is waynos B01C rom calid hacked to F40C and matching B01C def hacked to F40C if you have oft if you have tactrix just flash the B01C and use standard B01C defs |
#394 | |
Drives: 86
this is old issue. can be fix by edit xml file offset to 9 . before 16 |
#395 |
@steve99 thanks alot
About hacking the B01C to F40C for OFT; ive looked at my oft rom in a hex editor (700C) and what ive noticed is the 3rd instance of ZA1J is B01C, the other 2 are 700C. So is hacking the rom done by simply changing the first 2 instances of B01C to 700C ? Or in guybos case, B01C to F40C ? Sent from my LG-H812 using Tapatalk |
#396 |
So I am trying to achieve flames with my 2013 Subaru BRZ 6AT Full catless straightpipe with Invidia headerback. What am I supposed to be doing? Changing the fuel overrun? OP Posted this on his update "just an update don't mess with fueling or overrun..." Should I still add those in with my tune?
As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear god, protect my ride.
#397 |
Drives: BRZ SWP Limited -6MT
do pops or backfire noises mess up the engine? asking b/c was in parking garage over weekend, gave it a lil gas while pressing start button, got a loud pop upon startup. OTS stg 2 catless header stock front pipe, AB-M out back. im not interested in fiddling with the tune, just curious.
#398 | |
#399 | |
Drives: 2015 CWP BRZ Limited
The only thing I'm worried about is the Base Timing Idle table going crazy after 2000rpm.
#400 |
Drives: UK GT86
That table doesn't look properly defined.
.: Stealth 86 :.
#401 |
#402 | |
Drives: 86
Code:
<table type="2D" name="Base Timing Idle (In-Gear)(Above Speed Threshold) " category="Ignition Timing - Advance" storagetype="uint8" endian="big" sizey="9" userlevel="4">
<scaling units="Base Ignition Timing (degrees BTDC)" expression="(x*.3515625)-20" to_byte="(x+20)/.3515625" format="0.00" fineincrement=".2" coarseincrement="1" />
<table type="Y Axis" name="Engine Speed" storagetype="float" endian="little" logparam="P8">
<scaling units="RPM" expression="x" to_byte="x" format="#" fineincrement="50" coarseincrement="100" />
</table>
<description>This is the base timing in idle mode when vehicle speed is greater than the 'Base Timing Idle Vehicle Speed Threshold' and transmission is not in neutral.</description>
</table>
<table type="3D" name="Base Timing Idle (In-Gear)(Above Speed Threshold)" category="Ignition Timing - Advance" storagetype="uint8" endian="big" sizex="10" sizey="2" userlevel="4">
<table type="X Axis" name="Engine Speed" storagetype="float" endian="little" logparam="P8">
</table>
<table type="Y Axis" name="Coolant Temperature" storagetype="float" endian="little" logparam="P2">
<scaling units="Degrees F" expression="x" to_byte="x" format="#" fineincrement="1" coarseincrement="5" />
</table>
</table>
#403 | |
#404 |
Drives: 86
#405 |
Drives: '14 BRZ | '95 Range Rover
I just have a catback on my car and made the column change as suggested for the table Base Timing B, however I kept the first two the stock stg 1 tune values and everything higher in the RPMs were -10. This seemed to make the smell of gas when sitting idle go away.
Results: |
#406 |
Drives: 2013 FRS 10 series
I've noticed this works a lot better with e85. I switch back to 91 and haven't really had much with this. But on e85 with down shifts, and friends following me I was able to shoot foot long blue flames, full catless of course.
| rom tuning for pops and backfires | andrew5826 | Software Tuning | 110 | 12-23-2016 04:39 AM |
| First romraider defs are up | jamesm | Software Tuning | 95 | 01-13-2015 05:29 AM |
| Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 07:48 AM |
| OFT-Help with Romraider/FFS and Launch Control-issues | continuecrushing | Software Tuning | 9 | 04-17-2014 11:07 PM |
| Possible backfires | Bg8780 | Engine, Exhaust, Transmission | 0 | 05-22-2013 02:12 PM |
