Old 12-29-2016, 01:48 PM   #141
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by norcalpb View Post
Yeah an aftermarket intake only provides gains IF you are tuned. Maybe it'll lean the car out when you first install it, but the ecu will correct the AFR and you will lose all gains.
Once you go stage 2 an intake will not provide any gains whatsoever.
IMHO, aftermarket tune only makes sense in two ways to add any measurable power short of FI: 1. cat delete, 2. E85 mod
I don't want to deal with illegal inspections, driving around with that crazy noise, or lose my fuel efficiency for a fractional gain. I would give up my warranty only for FI.
If you are really racing and need every bit of power, that is another story. I am not racing.
Old 12-29-2016, 03:06 PM   #142
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
One other thing. The OFT tunes make noticeably more power with a header than without. The difference between stock versus stock+OFT feels less than the difference between stock+OFT and OFT+header. In other words, I wouldn't get a tune unless you're getting a header too. Also, e85 + header = nice.
The Following User Says Thank You to EAGLE5 For This Useful Post:
funwheeldrive (12-29-2016)
Old 12-29-2016, 04:03 PM   #143
86Boyz
Drives: on the highway to hell
i like your grumpy looking avatar
86Boyz is offline   Reply With Quote
Old 12-29-2016, 05:40 PM   #144
Tokay444
If the factory intake is "very very" good, is the aftermarket intake triple very good? I will take the "very very good" option, it is enough for me. Next step upgrade is forced induction that adds 50% hp. Until then, it is not worth spending time and big money on infinitesimal gains. People forget to enjoy driving this car, while "screwing" it all around.
Oh very good then.
Originally Posted by Subie_Nubie View Post
The TRD intake is actually quite shit. For stock rides it's ok. If you try to use it with an OTS tune, it'll muck up the MAF scaling. Only aftermarket intake I like is Grimmspeed, but then again I'm biased because that's what I run. But the MAF scaling on this is closer to stock and is more compatible with stage 1/2 tunes. A new intake should probably be the least prioritized on your mod list.
That's what you get for not running a proper tune.
OTS FTL.
Old 12-30-2016, 12:30 AM   #145
Subie_Nubie
Subie_Nubie's Avatar
Drives: 2013 Subaru BRZ Limted
Originally Posted by Tokay444 View Post
Oh very good then.
OTS FTL.
Say that too a majority of OFT users who are quite happy with Shiv's OTS tunes.
2013 SWP BRZ Limited // 6 MT // Grimmspeed Intake // Tomei Supreme UEL Header // OFT Stage 2, 93 Oct, UEL Tune // Enkei RPF1's // Borla Catback and Diffuser // Bilstein Shocks // Eibach Anti-Roll Kit // TRD Strut Bar
Subie_Nubie is offline   Reply With Quote
Old 12-30-2016, 04:39 AM   #146
Poodles
Drives: 2015 Series.Blue
Crazy noise is subjective (and can simply be tuned around if you're speaking of VVT noise), and fuel efficiency doesn't matter when 1) you're making noticeably more power 2) E85 is far cheaper than premium
But it's OK, we all have our opinions of what something is worth. Back in the early days of these cars a tune was all but required if you didn't want to have DI injector seal failures...
That's ignoring the other drivability improvements. Not to mention E85 on a stock header has quite a gain as well.
MAF scaling is the simplest part of the tuning and you SHOULD be checking it even with a completely stock setup. That's the whole point of the open tunes.
The Following User Says Thank You to Poodles For This Useful Post:
Tokay444 (12-30-2016)
Old 12-30-2016, 04:56 AM   #147
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by CTB727 View Post
Never buy lowering springs. Eventually you will want coilovers.
Considering how good our OEM dampers are and how most people buy adjustable coils and never touch the adjustment lowering springs are just fine for a majority of owners
The Following 3 Users Say Thank You to finch1750 For This Useful Post:
chaoskaze (12-30-2016), guybo (12-30-2016), Tcoat (12-30-2016)
Old 12-30-2016, 10:50 AM   #148
Lantana frs
Drives: 13 frs red
Yes, 190-200 whp is plenty for this car. Just fattening the torque curve makes it a different animal altogether.
Lantana frs is offline   Reply With Quote
Old 12-30-2016, 11:22 AM   #149
86Boyz
but if you make it fat then it will be a slower animal
Old 12-30-2016, 12:05 PM   #150
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Am I the only one who doesn't mind having a steel shift knob in cold weather? NYC gets pretty cold... :|
It does kinda suck, but I get over it after a few minutes.
Old 12-30-2016, 12:16 PM   #151
finch1750
finch1750's Avatar
I put a sleeve over mine for winter mornings or summer during the day. I could probably stand the cold but when it gets 100+ here it's brutal trying to grab it hot
Old 12-30-2016, 03:41 PM   #152
PandaSPUR
PandaSPUR's Avatar
Hmm I guess I haven't driven my car on a day that hot yet. Last summer, the temps didnt even break 100 around here i think.
Old 12-30-2016, 06:23 PM   #153
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
How absolutely awful.
Scrappydoo is offline   Reply With Quote
Old 12-31-2016, 01:08 AM   #154
Poodles
Dampers are tuned to the spring and weight of the car. Lowering springs will have higher spring rates meaning they're then under damped with factory stuff.
Going the tS route with the springs and struts is the way to avoid this...
Wait... what?
radroach (12-31-2016)
Safe mods to avoid warranty- feedback/experience? slags BRZ First-Gen (2012+) — General Topics 8 09-19-2014 02:05 PM
Can't avoid the curse. Tried. D4S Mid-Atlantic 16 06-23-2014 12:29 PM
What sites do you avoid if you are %$@*! merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 6 07-05-2013 01:55 PM
For those in NC avoid this red FRS Zgrinch Southeast 2 05-19-2012 04:30 PM
