Old 12-13-2016, 03:08 AM   #239
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Adam_L View Post
So I've read a few things on here in regards to drop-in K&N ( bolt on upgrades sticky thread) or TRD , vs going with a full out ($350+) CAI system.
So what is the consensus ? Is it possible to go K&N drop in, and rig up the snorkel air inlet system so it's sucking in colder air from outside the car ?
Thanks in advance
You can try the TRD intake. Here is a review: http://www.ft86club.com/forums/showp...&postcount=701
Old 12-13-2016, 03:50 AM   #240
Originally Posted by Somerandom18 View Post
Anyone know a drop in that fits the 2017 /w manual trans yet?
Sent from my Pixel XL using Tapatalk
Originally Posted by Hawk77FT View Post
Same drop in that fits the 2013-2016! Nothing special really
Same filter size though! So replacing it with the same aftermarket filter used for 2013-2016 should not be a problem.
No it is not the same filter. Not even close. They totally changed the size.
funwheeldrive (12-28-2016), Hawk77FT (12-13-2016), Somerandom18 (12-14-2016), Teseo (12-27-2016), Vic4uf (12-28-2016)
Old 12-13-2016, 09:35 AM   #241
churchx
churchx's Avatar
Drives: 2014 GT86
More then quadruppled filtration area? Should be less resistive. Hmm, though then again it's fabric vs filter paper, no clue how they fare against each other. Maybe more filtration area is almost completely offset by more airflow resistance of used material.
Old 12-13-2016, 01:30 PM   #242
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Thanks. Sure I could try it, but it is a $350 or so part. Most users seem to like it , but given the cost not so sure it's worth it. Other members here say do the K&N drop in, and call it a day (most cost/benefit)
I know the header makes the most significant boost NA, going zero-65 mph so there isn't any short changing that part. Other parts are minimal change in performance, 2-6 hp/torque. On top of that, if I am changing out 3-4 bolt on intake/exhaust parts , then it sounds worth while to also get some basic tune after parts are installed to maximize performance benefits (tune for more hp , or mpg , etc)
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 12-13-2016, 04:53 PM   #243
Hawk77FT
Drives: GTS 86
I stand corrected! I looked at the sizes of the box and it looks like they are the same size.
Hawk77FT is offline   Reply With Quote
The Following User Says Thank You to Hawk77FT For This Useful Post:
Tcoat (12-13-2016)
Old 12-22-2016, 01:42 PM   #244
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Anyone know what the best performing single exit exhaust for the 86 is?
Right now I'm using the HKS Racing single exit, want to see if there's any better performing.
Sound noise isn't an issue, chasing max power.
I'll be changing to ACE header next year, either the A250 or the Anaconda 42.7mm.
stevo_12v is offline   Reply With Quote
The Following User Says Thank You to stevo_12v For This Useful Post:
D_Thissen (12-22-2016)
Old 12-22-2016, 02:59 PM   #245
Lantana frs
Drives: 13 frs red
If you're after real gains a tune is mandatory.
Lantana frs is offline   Reply With Quote
The Following User Says Thank You to Lantana frs For This Useful Post:
Old 12-27-2016, 11:09 AM   #246
Ricks919
Drives: 2014 BRZ brand new!
i have 190whp dyno tuned at drift office on knn drop in filter, cheapo sound tube delete, jdl catless uel, hks resonated front pipe, hks single exit catback. 190whp 152wtq
Ricks919 is offline   Reply With Quote
The Following User Says Thank You to Ricks919 For This Useful Post:
Teseo (12-27-2016)
Old 12-27-2016, 11:19 AM   #247
Teseo
Drives: frs
91oct, 93 or e85?
Old 12-27-2016, 11:22 AM   #248
Teseo
Drives: frs
Your post made me realize i need to buy aftermarker inlet tube (perrin or mishimoto) and drop in filter (non oiled) ASAP.
Old 12-27-2016, 12:05 PM   #249
gramicci101
Off Topic
Cat-back? As long as it's 2.25" or bigger, I don't think it matters. You're not going to see a noticeable difference between your HKS and anything else. The header and front pipe are where the major restrictions are. Header/front pipe/tune for power; cat-back for sound. That said, a free-flowing single exit canister exhaust with a catless header and catless front pipe is going to be louder than hell.
Old 12-28-2016, 10:44 AM   #250
Ricks919
Originally Posted by Teseo View Post
91oct, 93 or e85?
93 octane. tuner told me that i could easily get 200+ whp with e85 but theres no pumps around me unfortunately.... or i would jump right on it lol.
the biggest kicker was the tune. i drove on that setup for a few hundred miles (clearing the P0420 every time it came up lol!) and once i got it tuned it was like night and day difference
Old 12-28-2016, 11:26 AM   #251
Lantana frs
Drives: 13 frs red
Thank God I don't live anywhere near drift office. I would be penniless.
Old 12-28-2016, 11:33 AM   #252
Yep! People think they can just bolt stuff on and get instant power. The car doesn't know it is there and self tune to take advantage of the changes. It needs to be told to change all the perimeters so that the parts actually make a difference.
Recommended cheaper power gains mods emishor86 Scion FR-S / Toyota 86 GT86 General Forum 38 03-27-2016 08:49 PM
POWER Mods for NA setup NYCsubaruBRZ Engine, Exhaust, Transmission 61 02-17-2016 09:19 AM
Mods to reduce drivetrain power loss? FRSW12 Engine, Exhaust, Transmission 31 12-28-2015 05:10 PM
Easy mods for power and sound. LWAA BRZ First-Gen (2012+) — General Topics 40 09-13-2015 09:20 PM
More Power VS. other Performance Mods Darryljr11 Mid-Atlantic 38 08-11-2013 08:53 PM
