Old 12-24-2016, 11:57 PM   #1
dutchman1
Drives: 2017 86 6-Speed
Odd sound at 6k RPM
On throttle at 6000 rpm, my car makes a noise that sounds like it's coming from below the steering wheel in the dash, or in that general direction. It comes on at about 5900 rpm, is the loudest at 6000-6100, and is gone again by 6500. It is definitely repeatable and happens in 1st, 2nd, and 3rd gear. Probably the other ones too but that'd be a big ticket lol. It sounds like some kind of tapping/knocking but at a much higher frequency than you would hear knock. Almost like a high pitched rattling or scraping noise.
I tried to get a recording of it but can't hear it over the regular engine noise. Did a good bit of searching and didn't find anything that sounded the same.
Is this a normal sound from these engines? A VVT thing or something?
dutchman1 is offline   Reply With Quote
Old 12-25-2016, 02:32 AM   #2
Next time while it's happening try tapping your clutch pedal. Just a little tap. May not be it but if it affects the sound then I can explain that one. 6K is a little high for that specific resonance though.
May also be a loose bolt in your engine bottom cover (skid plate), or one of the heat shields on your exhaust.
Old 12-25-2016, 11:51 PM   #3
dutchman1
Nope, doesn't seem to be the slave cylinder spring (assuming that's what you were thinking). Tapping the clutch has no effect. Nor does the reverse lockout seem to be the culprit.
You're probably right, if it's not a common issue it's probably just a heat shield or something. My first oil change I'll look everything over.
If it's something in the engine, which it doesn't sound like, it'll probably get worse. If it it does I'll have it looked at, got a lot of warranty left lol.
Old 12-26-2016, 12:08 AM   #4
Ha! Yeah, I was thinking exactly that. Mine sings sometimes at around 4K. Don't remember exactly.
Let us know when you find it. Good luck.
Old 12-26-2016, 02:01 AM   #5
Does it make that noise when the car is stationary or while the car is moving .... or both ...... ??
Old 12-26-2016, 02:02 AM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
[ame="https://www.youtube.com/watch?v=KAWoP1kncRE"]Dumb And Dumber (1994) - The Most Annoying Sound In The World - YouTube[/ame]
Old 12-26-2016, 08:53 PM   #7
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Time for an exhaust or turbo? My car is so god damn ungodly loud at 6k, i cant even think.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 12-26-2016, 09:32 PM   #8
dutchman1
Both, it seems to be related to engine speed only, not wheel speed.
Old 12-26-2016, 09:34 PM   #9
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Does your car still have the sound generator tube?
...Because that tube pipes some intake resonance into the cabin in the passenger footwell, under the dash. It can sound pretty strange...
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 12-26-2016, 11:06 PM   #10
Good thought.
If you have one and it5 hasn't been plugged, you might consider sticking a cork in it.
Old 12-27-2016, 08:57 PM   #11
dutchman1
Found it! Just a loose bolt on the header heat shield. Crazy to me that I could hear it in the cab over tall the mentioned intake noise.
Thanks for the suggestions everyone
The Following 2 Users Say Thank You to dutchman1 For This Useful Post:
humfrz (12-27-2016), Spartarus (12-27-2016)
Old 12-27-2016, 09:28 PM   #12
How it feels when you find it and fix it.
Congrats!
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
dutchman1 (12-28-2016), FX86 (12-28-2016), Spartarus (12-27-2016), Tcoat (12-28-2016)
Old 12-28-2016, 12:44 AM   #13
Lantana frs
Drives: 13 frs red
If I were to have an issue with a brand new car, the dealer would be my first stop. Not a message board. Lol. Either way, good job on the find.
Lantana frs is offline   Reply With Quote
Old 12-28-2016, 12:49 AM   #14
I guess you've never had a sloppy mechanic fuck up your shit.
dutchman1 (12-28-2016), FX86 (12-28-2016), soulreapersteve (01-01-2017)
Does this sound deal sound decent ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 29 11-21-2015 10:02 AM
what is this sound? 93frs BRZ First-Gen (2012+) — General Topics 0 03-01-2015 01:22 PM
What is this sound? trsiidno Issues | Warranty | Recalls / TSB 5 01-14-2015 06:04 PM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 01:04 AM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 09:57 AM
