Old 12-26-2016, 01:47 PM   #15
nmctacticz
2010 WRX - 2015 FRS
nmctacticz's Avatar
Drives: 2015 FRS
Originally Posted by Tokay444 View Post
He's not the one with the swap...
wutsaiu is the one with the swap
2010 Subaru WRX - 2015 Scion FR-S
"Life's too short to drive boring cars"
nmctacticz is offline   Reply With Quote
Old 12-26-2016, 01:49 PM   #16
nmctacticz
2010 WRX - 2015 FRS
nmctacticz's Avatar
Drives: 2015 FRS
Originally Posted by wbradley View Post
Even if you go to the dealer, you wouldn't be taking "your car". That's the point, the car belongs to Toyota.
yea technically its toyotas car but im driving it
Old 12-26-2016, 03:10 PM   #17
Tokay444
He has a swap, but he's referring to someone else in his post to you.
Old 12-26-2016, 04:02 PM   #18
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You really want a nose heavy car? In some shitty old Camaro, who cares, but in a twin? Besides, the Al block is just as reliable as the Fe block.
You're best off getting an LS1 and T56. You can buy mounts premade. If you really want to save money and go with that heavy iron block, you can, but you're still probably better off with the T56. Also, why get a 5-gear Nissan when you can have a 6-gear?
The Following User Says Thank You to EAGLE5 For This Useful Post:
nmctacticz (12-28-2016)
Old 12-26-2016, 05:13 PM   #19
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
wutsaiu is offline   Reply With Quote
The Following 2 Users Say Thank You to wutsaiu For This Useful Post:
Scrappydoo (01-02-2017), Spartarus (12-26-2016)
Old 12-28-2016, 06:24 PM   #20
nmctacticz
2010 WRX - 2015 FRS
nmctacticz's Avatar
Drives: 2015 FRS
Well I finally got a hold of the head manager at toyota he said the swap is not a problem as long as I plan on buying the car in the end.
I went to meet my mechanic today and we're going ahead with the LQ4 6.0L V8 and rebuilding it. I know the Iron block is heavier but Im not worried about that, also, the reason for it Im on a budget. The only thing we havent decided yet is what transmission to go with. From what Ive heard the T56 is a nightmare to fit in the twins
Old 12-28-2016, 08:21 PM   #21
mrk1
Drives: Sterling BRZ Ltd
Swapping in the LQ will be hardly any different then an LS. The truck engines have bulkier intake manifolds and front pulley assemblies so those will need to be swapped over to one of the car versions. The camshaft is profiled for truck duty so thats got to go but its a single camshaft with a million options for new ones out there so have your pick and install it.
As for trans, nothing it easy. T56 would be simplest, sure its hard to get in the tunnel but being able to buy off the shelf clutch/flywheel and bell housing should ease some of the pain. There are other trans out there but when you have to deal with adapters and converters things get messy.
Look up successful LS swaps and go from there. I've looked into the truck motors myself, no shame in budget power.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
nmctacticz (12-30-2016), Summerwolf (12-28-2016)
Old 12-28-2016, 08:49 PM   #22
EAGLE5
Dismember
EAGLE5's Avatar
Budget and engine swap don't go together. I strongly suggest you post your parts list, and then we can add all the other parts you'll need, from a custom driveshaft to a new fuel pump.
Old 12-28-2016, 08:51 PM   #23
wutsaiu
wutsaiu's Avatar
Stock fuel pump is fine.
The Following User Says Thank You to wutsaiu For This Useful Post:
Old 12-28-2016, 08:52 PM   #24
EAGLE5
Dismember
EAGLE5's Avatar
Let me put it another way. Do it right or not at all. Fucking up a car AND spending many thousands seems stupid.
wutsaiu (12-28-2016)
Old 12-28-2016, 10:56 PM   #25
EAGLE5
Dismember
EAGLE5's Avatar
I respect what you did, but you did it yourself.
Old 12-29-2016, 11:38 PM   #26
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
The T56 fits very well compared to the hackery you have to do in most swaps.
You only need to drill out spot welds for a single tunnel brace, and weld in a new one.
The 04-06 Pontiac GTO T56 has a perfect shifter location, and requires no modification.
No hammering required, no clearancing required. You *may* have to slightly trim a few external tabs on the passeger side of the trans, but they aren't structural.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 3 Users Say Thank You to Spartarus For This Useful Post:
nmctacticz (12-30-2016), Summerwolf (12-30-2016), wutsaiu (12-30-2016)
Old 12-30-2016, 08:25 AM   #27
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Talking from experience, don't use the stock GTO shifter. Throw in a GMM or MGW-P from the get go. They basically get rid of the remote linkage and have an offset direct shift lever.
Remote linkage is the reason why the GTO shifter is different - but you can make other T56 transmissions have the GTO shifter location. The GTO specific trans has Z06 gearing....which could or could not be beneficial.
GMM
STOCK
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
nmctacticz (12-30-2016), Spartarus (12-30-2016)
Old 12-30-2016, 03:23 PM   #28
nmctacticz
2010 WRX - 2015 FRS
nmctacticz's Avatar
Drives: 2015 FRS
Me and my mechanic are still doing our homework. I appreciate the comments.... i will keep you posted
The Following User Says Thank You to nmctacticz For This Useful Post:
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
LED swap Skorov AUSTRALIA 28 09-23-2014 09:46 PM
2jz swap p3raltaboi Scion FR-S / Toyota 86 GT86 General Forum 54 06-11-2014 08:09 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 07:59 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
