Old 12-23-2016, 02:33 PM   #1
CjTotten
OFT UEL stage 2 tune throwing CODE P0351 . HELP
What could cause this & why? What do I do? I am catless UEL headers and straight piped on OFT UEL stage 2 tune. Drove it 5 miles and it throws P0351 for bad 1 coil.... HELP
CjTotten is offline   Reply With Quote
Old 12-23-2016, 03:07 PM   #2
Susurs
Drives: GT86
It's the heat from the header and has nothing to do with the tune itself. You can try to insulate the ignition coils on the passenger side as discussed here, at least that's what I did and the error didn't came up again. The error isn't necessarily related to your header but non-isolated or coated headers might even intensify this problem. If the error persists, buy a new ignition coil. Can be replaced within few minutes by yourself. HTH.
Gesendet von iPhone mit Tapatalk
Susurs is offline   Reply With Quote
Old 12-23-2016, 03:27 PM   #3
steve99
Drives: FT86
common problem especially on early model cars. later cars had updated coil pack.
happens on cars with stock headers and tunes as well.
just replace coil pack
https://www.google.com.au/search?q=p...e:ft86club.com
KalbiCool88 (12-27-2016)
Old 12-23-2016, 03:36 PM   #4
Teseo
Drives: frs
Its possible to swap coils to early models?
Old 12-23-2016, 03:37 PM   #5
Susurs
Drives: GT86
Yes, they are backwards compatible.
The Following User Says Thank You to Susurs For This Useful Post:
Teseo (12-23-2016)
Old 12-23-2016, 03:54 PM   #6
phrosty
You can reset the code but there's a good chance it'll come back soon when you go wide open. I've got the latest one even in the winter (freezing temps) when you'd expect to not have any heat issues
Luckily it doesn't indicate imminent failure and seems safe to drive on until you get it replaced.
phrosty is offline   Reply With Quote
Old 12-23-2016, 05:25 PM   #7
CjTotten
How do I isolate it? Any way?
Old 12-23-2016, 05:35 PM   #8
CjTotten
What if I replace the coil packs. Does anyone think it'll happen soon?
Old 12-27-2016, 02:52 PM   #9
renfield90
The Stig's German cousin
I recently started throwing a P0353, same problem but with #3 coil. I've got an uncoated, uncatted JDL UEL header I installed a year ago, so I'd say replacement coil packs would last at least a year (maybe longer if there indeed has been a redesign of the part).
I'm going to replace both #1 and #3 coil packs. I'm also going to look into wrapping the header to keep temps down, if people think that's a good idea. There is a mega thread somewhere if you search for it.
Old 12-29-2016, 12:56 PM   #10
Subie_Nubie
Subie_Nubie's Avatar
Drives: 2013 Subaru BRZ Limted
Happens to me too, mostly when I try to redline all gears in a straightaway. I guess it means you encounter a misfire or knock at WOT. If you daily it at about 70% aggressiveness, it shouldn't happen often. I guess it's inevitable that you will see this issue though and will eventually have to replace.
2013 SWP BRZ Limited // 6 MT // Grimmspeed Intake // Tomei Supreme UEL Header // OFT Stage 2, 93 Oct, UEL Tune // Enkei RPF1's // Borla Catback and Diffuser // Bilstein Shocks // Eibach Anti-Roll Kit // TRD Strut Bar
Subie_Nubie is offline   Reply With Quote
P0700 CODE AFTER OFT TUNE (AT TRANS) xcuz31 Software Tuning 12 12-10-2019 06:36 PM
Code P0351 Trouble shooting? Bahraini86 Issues | Warranty | Recalls / TSB 46 09-10-2017 05:07 PM
OFT CEL Code reading clearing - reset tune? Walla Walla Software Tuning 4 08-13-2016 01:02 AM
Unichip throwing p0102 code ?? jdubz13frs Software Tuning 3 07-10-2014 04:27 PM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
