Old 12-20-2016, 05:50 PM   #1
HubertK
Drives: GT86
Fault Code: U0122
Long story short I have bought a damaged BRZ on auction and planning on fixing it. I am currently in the middle of getting all parts sourced and thought I would use this time to get the car atleast running in the mean time. The auction house stated that the engine was starting but cutting out. After putting the air intake back together and jump starting the car as the battery was completly flat. The engine started and runs just fine but most of the warning lights are on.
I have scanned the faults and it comes up with U0122 - Lost Comm with Vehicle Dynamics Ctrl Mod. Any idea on what it could be and how to fix it?
HubertK is offline   Reply With Quote
Old 12-20-2016, 06:42 PM   #2
jvincent
jvincent's Avatar
Either the Vehicle Dynamics Ctrl Mod is damaged or the wiring to it is damaged.
Old 12-20-2016, 07:36 PM   #3
new2subaru
Weight Weenie
Drives: 15 FR-S
This may be of some help
https://www.obd-codes.com/u0122
Old 12-20-2016, 09:45 PM   #4
I would start by getting all the smashed parts off and checking all wires and plugs.
Old 04-03-2017, 12:03 PM   #5
dem8
Drives: Toyota Avensis III
My brother in law found a company near him that sells auction cars, but he is afraid because it's his first time.
He doesn't know how to participate...
What is your advice?
If there is passion and motivation accomplishment is at hand.
dem8 is offline   Reply With Quote
Old 09-28-2017, 09:49 PM   #6
AlexBRZ
Drives: 2015 Subaru BRZ Limited
Hey did you ever figure out the problem? i bought car of auction too with almost the exact damage on the same side and am having the same issue, Please help! Thanks!!
AlexBRZ is offline   Reply With Quote
OFT Code U0122.. Limp mode.. Help cameronjones239 Software Tuning 16 05-19-2021 01:25 AM
Fault Code P000B, before I got to the dealer TURBObro10 Issues | Warranty | Recalls / TSB 4 11-08-2016 05:29 PM
Got ECU fault code U0073. Need help! xiayu0320 Issues | Warranty | Recalls / TSB 4 11-19-2015 12:41 AM
DTC Codes U0122 and U0131 pleong Electronics | Audio | NAV | Infotainment 1 09-03-2014 02:40 AM
U0122 Code - AFR and other stuff is wack Synack Issues | Warranty | Recalls / TSB 10 11-01-2013 12:16 PM
