Old 12-20-2016, 03:02 PM   #15
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by FX86 View Post
hey guys how can i fit P295/30R18 tires in the front and P355/30R19 tires in the rear on a stock fr-s?
It is possible, but is going to look something like this... Forget turning too, straight line only!
via Imgflip Meme Generator
I LIKE TIRES!
Old 12-20-2016, 03:04 PM   #16
FX86
It is possible, but is going to look something like this... Forget turning too.
oil changes would be a lot easier tho
Old 12-20-2016, 03:10 PM   #17
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by jasonojordan View Post
Not to mention it would be considered illegal in California.
Why?
As long as you meet sound requirements and aren't pumping exhaust into the cabin there's nothing illegal about modifying the catback.
ineedyourdiddly
Old 12-20-2016, 03:15 PM   #18
jasonojordan
Drives: 2013 satin white brz limited
Why?
At that point you are not modifying the cat back you are completely removing it. I'm no expert in California emissions laws but I'm fairly certain they will not let you run a straight pipe from the cats back and it pass inspection.
jasonojordan is offline   Reply With Quote
Old 12-20-2016, 03:19 PM   #19
jasonojordan
Why?
CA. V.C. 27151 No person shall modify the exhaust system of a motor vehicle in a manner which will amplify or increase the noise emitted by the motor of such vehicle so that the vehicle is not in compliance with the provisions of Section 27150 or exceeds the noise limits established for the type of vehicle in Article 2.5(commencing with Section 27200) of this chapter. No person shall operate a motor vehicle with an exhaust system so modified.
This shows that there are other characteristics that the exhaust system must conform to truly show a violation. This also shows that other vehicle codes must be considered when in violation of this vehicle code.
CA. V.C. 27150 (a) Every motor vehicle subject to registration shall be equipped with an adequate muffler in constant operation and properly maintained to prevent any excessive or unusual noise, and no muffler or exhaust system shall be equipped with a cutout, bypass, or similar device.
(b) Except as provided in Division 16.5 (commencing with Section 38000) with respect to off-highway motor vehicles subject to identification, every passenger vehicle operated off the highways shall at all times be equipped with an adequate muffler in constant operation and proper maintained so as to meet the requirements of Article 2.5 (commencing with Section 27200), and no muffler or exhaust system shall be equipped with a cutout, bypass, or similar device. (c) The provision of subdivision (b) shall not be applicable to passenger vehicles being operated off the highways in an organized racing or competitive event conducted under the auspices of a recognized sanctioning body or by permit issued by the local governmental authority having jurisdiction.
Part (a) states that the muffler must suppress any excessive or unusual noise. This refers to part (b) which states that the muffler must meet the requirements of Article 2.5, which refers to noise levels. Part (a) and (b) also refer to a cut-away, bypass or similar device commonly known as a "dump."
The Following User Says Thank You to jasonojordan For This Useful Post:
strat61caster (12-20-2016)
Old 12-20-2016, 03:24 PM   #20
strat61caster
The only purpose the exhaust serves after the catalytic converts is to direct exhaust gases away from the cabin of the vehicle and to reduce sound to reasonable levels.
The Fiat Abarth is running a straight pipe from the factory post-cat.
One of the family cars is running a straight pipe post cat as well, family member worked for the BAR smog department, shouldn't be any issues.
Here's a summary of the vehicle code if you feel so inclined to think I am incorrect:
http://www.bobsmuffler.com/noise.htm
ineedyourdiddly
Old 12-20-2016, 03:26 PM   #21
jasonojordan
I copied my info from the link you had posted lol. Seems like it would be to the discretion of the officer involved as the car does not come that way from the manufacture then it would be interpreted as "modified" and fall under the segment that I copied and pasted.
Old 12-20-2016, 03:27 PM   #22
strat61caster
Which subjects the vehicle to a noise measurement, nothing more.
ineedyourdiddly
Old 12-20-2016, 03:27 PM   #23
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I honestly can't even think of what the exhaust would sound like with that weird gap, because I can't imagine why anyone would do that. If you want it to be louder for cheap, just get a muffler delete.
Also, I'd stop going to that dealership for service if they're employing mechanics who would suggest that.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following 2 Users Say Thank You to Shark_Bait88 For This Useful Post:
strat61caster (12-20-2016), Tcoat (12-20-2016)
Old 12-20-2016, 03:42 PM   #24
Never done it on purpose nor had it happen to a boxer engine but generally when my cars had the pipe rot off before the muffler and leave a gap like that the sound was sort of like
BRRRAAAAAPPPPPP
POP
POP
POP
POP
BRRRRRRAAAAAAAPPPPPPP
humfrz (12-21-2016), Leonardo (12-20-2016), Shark_Bait88 (12-20-2016)
Old 12-20-2016, 03:49 PM   #25
Shark_Bait88
BRRRAAAAAPPPPPP
POP
POP
POP
POP
Yeah, I kinda guessed it'd just sound like a car with a hole in the exhaust. Which sounds terrible.
Old 12-20-2016, 04:45 PM   #26
D_Thissen
D_Thissen's Avatar
Don't let that 'mechanic' touch your car.
Old 12-20-2016, 05:06 PM   #27
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Just drop the muffler. It's free and sounds better than the washer mod
guybo is offline   Reply With Quote
Old 12-20-2016, 05:08 PM   #28
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
IceFyre13th is offline   Reply With Quote
The Following User Says Thank You to IceFyre13th For This Useful Post:
exhaust, muffler
FS.. JDL UEL headers, Motiv over pipe, Invidia front pipe, FT-86 Speedfactory exhaust Ridgerunr Engine, Exhaust, Bolt-Ons 14 11-11-2015 10:08 AM
Manzo Performance Super Sale: Coilovers / Headers / Exhaust / Over-pipe & Front Pipe JonMotoring Groupbuys 68 04-19-2014 05:05 PM
Exhaust,test pipe, over pipe, headers, or suspension build ShikoBariki Engine, Exhaust, Transmission 20 05-01-2013 04:16 PM
