Old 12-02-2016, 12:10 PM   #211
churchx
churchx's Avatar
Drives: 2014 GT86
350 for best overall no-compromise gains, lightest weight. CS400 is cheaper and less clearance issues (especially on RHD), sacrificing slightly power at top rpms, adding a bit weight.
jasonojordan (12-02-2016)
Old 12-02-2016, 12:41 PM   #212
Irace86
Drives: BRZ + Ducati M796
Effective mods for NA hp seem to be gutted header or aftermarket header, exhaust and intake, tune and flex fuel. More power seems to take much more money for much less gains.
If you want to do these mods for faster lap times, and not just more grunt on the street then consider the following:
--Depending on the track, good tires can be the cheapest mod for better track times.
[ame="https://www.youtube.com/watch?v=S2S6MJt0998"]https://www.youtube.com/watch?v=S2S6MJt0998[/ame]
--Our cars are more momentum cars, so aero can help keep the momentum going.
[ame="https://www.youtube.com/watch?v=aXOASqWt0Zo"]https://www.youtube.com/watch?v=aXOASqWt0Zo[/ame]
--Effective mods for increasing rpm response or rate of rpm changes seems to be gearing changes and reducing rotational masses through light weight components like LWFW or lighter rims, etc. This will get you into the higher power band faster.
--Braking will improve lap times...pads, stainless lines, master cylinder brace, fluids.
--Suspension with lower center of gravity and help with traction...springs, camber bolts, etc and work up from there in cost.
Irace86 is offline   Reply With Quote
The Following User Says Thank You to Irace86 For This Useful Post:
why? (12-02-2016)
Old 12-02-2016, 04:56 PM   #213
CSG Mike
CSG Mike's Avatar
Actually, the CS400 has more clearance issues, but is RHD compatible. The A/350 clears with zero chassis/panel modification, but is not RHD compatible.
Old 12-02-2016, 05:07 PM   #214
gramicci101
Off Topic
Are there performance differences between the two? For instance, CS400 has more low-mid torque, A350 has more top end torque, that kind of thing.
Old 12-02-2016, 05:09 PM   #215
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Have you tried pushing the right hand pedal more?
Scrappydoo is offline   Reply With Quote
Old 12-02-2016, 05:33 PM   #216
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Exactly.
Old 12-02-2016, 07:35 PM   #217
CSG Mike
CSG Mike's Avatar
The CS400 has slightly more low end torque (2000-4000), the A/350 makes more power everywhere else, particularly up top where you really need power to go fast.
The CS400 makes for a slightly better street driving (non-revving-high) experience.
gramicci101 (12-02-2016)
Old 12-08-2016, 11:12 AM   #218
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
What a good ACE header that'll take advantage of my JUN intake?
Looking for powerband from 6,000-8,000rpm probably
Oh, and i'm RIGHT HAND DRIVE too
stevo_12v is offline   Reply With Quote
Old 12-08-2016, 11:32 AM   #219
churchx
churchx's Avatar
Drives: 2014 GT86
stevo: i'd think of A/250 or A/150 if it's track-only, as A/350 won't fit on RHD, CS400 is for mid/low rpms, 250 imho might be good compromise.
OK, supposedly 150 or anaconda is even more top rpm optimised, but if you use it for daily driving aswell, i doubt 6-8K is range header must be optimised only for, as often even on track it's not 6-8K, but rather 4K-7.5K (OK, maybe, just maybe +500rpm in your case to both ends of range). If you log rpms on track, i doubt car spends that big share of time at very top. And certainly it doesn't at daily driving on public roads.
stevo_12v (12-08-2016)
Old 12-09-2016, 07:51 PM   #220
celek
Resident Gear Head
celek's Avatar
I need a header for 9500 RPM
celek is offline   Reply With Quote
Old 12-09-2016, 08:24 PM   #221
gramicci101
Off Topic
Do the normal high end headers like ptuning or ace not cut it for you?
Old 12-09-2016, 08:30 PM   #222
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Let us know what exact powerband you expect power in and where you are willing to give up.
There are off the shelf header available to take on this endeavor, but it is severely dependent on what type of powerband is being used. For example, the ACE A-350 maximizes the factory FA20 powerband extremely well offering the best overall power delivery out of all the ACE headers, the A-250 shifts the optimal powerband slightly north, the CS400 shifts the optimal powerband down, etc. At that point, we need to know exactly where you are planning to use the power and where you are willing to give up before making a recommendation. Thank you!
CounterSpace Garage is offline   Reply With Quote
Old 12-09-2016, 08:35 PM   #223
gramicci101
Off Topic
Originally Posted by CounterSpace Garage View Post
There are off the shelf header available to take on this endeavor, but it is severely dependent on what type of powerband is being used. For example, the ACE A-350 maximizes the factory FA20 powerband extremely well. At that point, we need to know exactly where you are planning to use the power and where you are willing to give up before making a recommendation. Thank you!
I had been thinking A350 or Anaconda 42.7mm, with the Anaconda 48mm if he really needed the ability to move a lot of exhaust gas. 9500 RPM is far enough outside the realm of normal usage that I can't even guess at his requirements. You guys are the experts though.
Old 12-09-2016, 10:18 PM   #224
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
What is the powerband of the Ace 150 then?
Recommended cheaper power gains mods emishor86 Scion FR-S / Toyota 86 GT86 General Forum 38 03-27-2016 08:49 PM
POWER Mods for NA setup NYCsubaruBRZ Engine, Exhaust, Transmission 61 02-17-2016 09:19 AM
Mods to reduce drivetrain power loss? FRSW12 Engine, Exhaust, Transmission 31 12-28-2015 05:10 PM
Easy mods for power and sound. LWAA BRZ First-Gen (2012+) — General Topics 40 09-13-2015 09:20 PM
More Power VS. other Performance Mods Darryljr11 Mid-Atlantic 38 08-11-2013 08:53 PM
