Old 12-02-2016, 08:18 PM   #29
Originally Posted by TelMinz View Post
Where do you live that an alignment is $400.00? Canada?
Parts & labor costs for replacing damaged suspension components add up quickly on top of the original cost of a standard alignment.
strat61caster (12-02-2016)
Old 12-02-2016, 08:43 PM   #30
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
lol, alignment + parts + labor, I'd be surprised if the whole procedure I outlined (suggested by renfield) could be done for less than $300 even if the dampers are DIY installed.
I'd expect barebones, ~$200 on dampers, free DIY install, ~$100 on alignment, then if something else is broken I'd expect another ~$100 charge to replace it at the alignment shop, minimum.
Some people have been quoted at $400+ for a spring install. If OP takes it to the dealership, buys OE replacements ($95 F, $65 R) I would be surprised if they charged less than $400, and then another $100 for the alignment, then sales tax they'd be paying $600+ on this. And maybe a control arm is bent or a bearing has failed, we don't know, at ~$100 per broken part needing replacing, the real fix for this could run the OP over $1,000.
Yeah, cheap alignment places are <$100, the good ones around me seem to charge $100-$150/axle, that's not needed when only factory adjustment is available, all you can do is toe.
ineedyourdiddly
Old 12-03-2016, 10:17 AM   #31
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
How do you know the OP is a she?
Never said a word about OP - where did you read that OP was leaning? I was referring to the car.
geezerbrzeezer is offline   Reply With Quote
Old 12-03-2016, 11:02 AM   #32
I knew what you meant! Is the use of "she" when referencing a car gone out of fashion? Fallen' prey to the whole Politically Correct camp maybe?
Ultramaroon (12-03-2016)
Old 12-03-2016, 12:45 PM   #33
TelMinz
Rotary for the win
Drives: BRZ, FD3S RX7
I see, I'm picking the corn out of your shit on that.
"Behold, my field of phucks, lay thein eyes upon it, and notice, tis' barren."
TelMinz is offline   Reply With Quote
The Following User Says Thank You to TelMinz For This Useful Post:
Old 12-03-2016, 07:19 PM   #34
TelMinz
Rotary for the win
More like just trying to give someone a hard time for my own amusement, I couldn't give two craps about politically correct
AFR leaning out after shifting gears Toyota John Software Tuning 14 05-23-2014 02:05 AM
Leaning out! Reaper Forced Induction 29 05-04-2014 03:15 PM
leaning to the side from turns? Gilwith1l Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 02-15-2014 05:54 PM
Takeda Intake System; Stage 2 Wrinkle Black; PRO 5R; Scion FR-S 2013 H4-2.0L TM-2013 AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 16 10-03-2012 09:03 PM
i'm leaning toward BRZ but will it be easier to get a FR-S? stlgrym3 BRZ First-Gen (2012+) — General Topics 28 03-30-2012 02:07 PM
