Old 02-15-2014, 03:28 PM   #1
Gilwith1l
Gilwith1l's Avatar
Drives: stock brz. saving my money for ls1
leaning to the side from turns?
I have 6000 miles on my brz and its my DD.. Planning on lowering the car and started taking measurements and the left side is about .75" lower . could this be due to having to navigate four huge sweeping turns everyday as part of my daily commute.. I have tried different parking lots , spun the var around in the same spot and the left side still sags. Just wondering if this is going to be an issue with new springs as well or should I just go coilovers
Gilwith1l is offline   Reply With Quote
Old 02-15-2014, 03:32 PM   #2
fatoni
uhh...dont you take those turns on the way back home in the opposite direction?
Old 02-15-2014, 03:33 PM   #3
Gilwith1l
Gilwith1l's Avatar
The turns are all right and I have had the car since new
Old 02-15-2014, 03:39 PM   #4
Gilwith1l
Gilwith1l's Avatar
No .. That's there and back ..I have a deficit of good left handers on my commute
Old 02-15-2014, 03:44 PM   #5
White64Goat
If you're the only one in the car on a daily basis, your weight does have an effect on the springs.
Old 02-15-2014, 03:48 PM   #6
d1ck
Drives: Black 2013 FRS
After 6k there should be no sag in the springs unless the roads you drive on daily are totally shit. Make sure the surface you're measuring on is level.
d1ck is offline   Reply With Quote
Old 02-15-2014, 03:51 PM   #7
Gilwith1l
Gilwith1l's Avatar
So do you think that a set of eibach pro would become bias as quickly. I do weigh 220 lbs. Knowing the car sits .75" with me out of it will drive me nuts . it has to be at least an inch difference with me in it
Old 02-15-2014, 03:54 PM   #8
Gilwith1l
Gilwith1l's Avatar
I'm usually at the top of second with the back end stepping out slightly so the roads are good
Old 02-15-2014, 03:59 PM   #9
Gilwith1l
Gilwith1l's Avatar
I guess what I want to know has anyone else experienced this with stock or aftermarket springs
Old 02-15-2014, 04:08 PM   #10
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
You may have discovered the least invasive and cost efficient method of lowering a BRZ.
On topic, Is it the entire left side that has measured lower? I measured mine before installing sportlines, and everything more or less came up square.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 02-15-2014, 04:10 PM   #11
White64Goat
My left front is 26 1/16 from ground to fender lip @ wheel centerline. Right front is 25 15/16, so mine is actually higher on the left. I did not check air pressures in tires first. I'm about 245 lbs. so I'd say you need to recheck your readings on a good flat surface with all tire pressures checked. 3/4" sag to me would seem to be a little more than normal to me.
Old 02-15-2014, 04:20 PM   #12
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
Is it possible to swap the springs from the left side to the right?
KKaWing is offline   Reply With Quote
Old 02-15-2014, 04:33 PM   #13
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Great idea. This would test the hypothesis.
Old 02-15-2014, 04:54 PM   #14
Gilwith1l
Gilwith1l's Avatar
Yes it would but if it is indeed the springs should I expect that from aftermarket springs or should I write it off as a low tolerance factory component. I don't want to keep the factory springs i am just trying to get a base measurement to see what route i wanna go with my suspension. Ultimately i will probably go with the eibach pro amd start from there
Beeping after ignition turns off.. chadstyle BRZ First-Gen (2012+) — General Topics 45 07-20-2020 01:53 PM
Charging Phone Turns On Air-Bag onepremiere Issues | Warranty | Recalls / TSB 19 09-27-2013 02:23 AM
Bluetooth turns on in driveway Pete156 Electronics | Audio | NAV | Infotainment 2 08-05-2013 12:12 AM
FR-S: Highbeam turns on lowbeam, how to disable? civicdrivr Cosmetic Modification (Interior/Exterior/Lighting) 6 07-03-2012 07:08 PM
i'm leaning toward BRZ but will it be easier to get a FR-S? stlgrym3 BRZ First-Gen (2012+) — General Topics 28 03-30-2012 01:07 PM
