#29 |
Parts & labor costs for replacing damaged suspension components add up quickly on top of the original cost of a standard alignment.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | strat61caster (12-02-2016) |
#30 |
Drives: '13 FRS - STX
lol, alignment + parts + labor, I'd be surprised if the whole procedure I outlined (suggested by renfield) could be done for less than $300 even if the dampers are DIY installed.
I'd expect barebones, ~$200 on dampers, free DIY install, ~$100 on alignment, then if something else is broken I'd expect another ~$100 charge to replace it at the alignment shop, minimum. Some people have been quoted at $400+ for a spring install. If OP takes it to the dealership, buys OE replacements ($95 F, $65 R) I would be surprised if they charged less than $400, and then another $100 for the alignment, then sales tax they'd be paying $600+ on this. And maybe a control arm is bent or a bearing has failed, we don't know, at ~$100 per broken part needing replacing, the real fix for this could run the OP over $1,000. ![]() Yeah, cheap alignment places are <$100, the good ones around me seem to charge $100-$150/axle, that's not needed when only factory adjustment is available, all you can do is toe. |
#31 |
Geezer
Drives: 2016 Subaru BRZ Sport Tech
#32 |
I knew what you meant! Is the use of "she" when referencing a car gone out of fashion? Fallen' prey to the whole Politically Correct camp maybe?
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (12-03-2016) |
#33 |
Rotary for the win
Drives: BRZ, FD3S RX7
I see, I'm picking the corn out of your shit on that.
"Behold, my field of phucks, lay thein eyes upon it, and notice, tis' barren."
| The Following User Says Thank You to TelMinz For This Useful Post: | Ultramaroon (12-03-2016) |
#34 | |
Rotary for the win
| AFR leaning out after shifting gears | Toyota John | Software Tuning | 14 | 05-23-2014 02:05 AM |
| Leaning out! | Reaper | Forced Induction | 29 | 05-04-2014 03:15 PM |
| leaning to the side from turns? | Gilwith1l | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 02-15-2014 05:54 PM |
| Takeda Intake System; Stage 2 Wrinkle Black; PRO 5R; Scion FR-S 2013 H4-2.0L TM-2013 | AMPLIFIED MOTORSPORT | Engine, Exhaust, Bolt-Ons | 16 | 10-03-2012 09:03 PM |
| i'm leaning toward BRZ but will it be easier to get a FR-S? | stlgrym3 | BRZ First-Gen (2012+) — General Topics | 28 | 03-30-2012 02:07 PM |
