Old 10-26-2016, 02:32 PM   #15
Daver
http://www.ft86club.com/forums/showthread.php?t=41083
Edit: You are getting +40 rear, which would push the wheel out 5mm compared to the rear wheel in post 90. Which will be really flush, and convinces me further 265 is too wide without the other suspension parts.
Thanks! I had been pouring through some other threads, did not look at the meaty tire thread.
To make sure I am understanding this all correctly I can:
Buy Coilovers and LCA in order to run 18x8.5+45 on 235/40/18 Fronts and 18x9.5+40 on 265/35/18 Rears
Or perhaps run a 255 tire in the rear and avoid getting the other components? I don't like to see lip (poke doesn't really bother me either) so I am starting to think I will just need to bite the bullet and buy the dang suspension.
Daver is offline   Reply With Quote
Old 10-26-2016, 02:37 PM   #16
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes. Then you will be able to dial them in properly. I am happy to help.
Good luck!
Old 11-30-2016, 08:53 PM   #17
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
I'd been eyeing this set in the +33 front offset variation for a long time, but ended up buying the +45 front offset due to the others being out of stock. I noticed there's hardly any pictures of this setup available here, so hopefully these pictures help others in their decision.
SPECS:
18x8.5+45 / 18x9.5+40 F/R (+ 5mm spacer in front)
MPSS 235/40 / 265/35 F/R
Factory alignment specs
Lowered ~1" front, ~0.75" rear (due to tire rubbing in rear, need to add a bit more camber)
amaciose is offline   Reply With Quote
Old 02-15-2017, 12:01 PM   #18
Daver
Finally Got em on
Big thanks to @ExxelDistributions for the sick deal on Rims, and suspension. Those guys are good peeps!
Old 02-18-2017, 06:46 PM   #19
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
Finally Got em on
Looks great!!!
ExxelDistributions is offline   Reply With Quote
Scion FR-S with 18x8.5 Gram Lights 57xtremes all around? IAmNotTheDriftKing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 11-22-2015 03:36 AM
Wheel Directory: Rota RKR 18x8.5 +44 / 18x9.5 +44 Hindi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 99 06-08-2015 08:07 AM
Wheel Directory: Gram Lights 57Xtreme 19x8.5 +43 / 19x9.5 +45 86 FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 05-19-2014 12:28 AM
Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 JRoldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-07-2014 08:10 AM
FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 funcheung Canada Classifieds 7 09-16-2013 05:01 PM
