#141 |
Frickin' Genius
Drives: GBS BRZ 6sp, 2002 ts wagon WRX swap
Update.
The idler pulley in question is scheduled to be at the dealership on Thurs. likely to be installed in my BRZ on Fri. I'll post up the results ASAP. I believe that the tech that is noted here as recommending replacing the fuel pump and other components will find the diagnoses incorrect. I further think that chirping should be the work of crickets, small birds and old Volkswagens.
Cullen
I hear on occasion, people say that they are bored...wrong answer....An engine can be bored, a person would more correctly state that they are boring. |
#142 | |
Drives: 2013 FR-S, 6MT, Ultramarine
#143 | |
Drives: Waiting for the ND Miata
#144 |
Lex Luger
Drives: 2004 GS430
Thread is on my radar, but I'm not sweating it too much, yet....
#145 |
Drives: Mazdaspeed 3
Still waiting for any real proof on any claims this isn't just a normal noise. Every dealer seems to have their own idea. But hey, KNOWN ISSUE GUYS!
#146 | |
Drives: Supercharged Golf Cart
But if by some bizarre reasoning it does in fact prove normal it still begs the question as to why it begins to happen to some after hundreds of miles. That would then suggest that some of these vehicles were assembled better than others, which then becomes a quality control issue...which this car has already suffered from once so far(panel fitting). Regardless of which answer is correct, they should all be doing it or all not be doing it. Logic is logical, but common sense apparently isn't common. |
#147 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
has anyone tried putting some water on the drive belt of a car that's making the noise to see if it changes/goes away? ...simple test that one.
A stethescope would easily pinpoint the source, from the video's here it sounds similar to tensioner idler noise I've heard on other subaru's and toyota's. |
#148 | |
All that said, if it IS an issue, then I want nothing more for it to be diagnosed correctly, and repaired properly. Has anyone who had their car inspected have a write-up on what was tested and how they came to their conclusions? |
#149 | ||
6/22/12-2/6/24
Look for Whiteout-FRS's post - I don't remember where I saw it but its somewhere in the forums here ![]() Edit: I found it, from 6/22 http://www.ft86club.com/forums/showt...t=8285&page=13 Quote:
#150 | |
And, per the link in the post above me, both Subaru and Scion have acted on the issue. All we are waiting on now is the update from the owner "whiteout fr-s", hopefully after he has put several hundred new miles and not an after-action report from an hour after pickup. |
#151 | |
6/22/12-2/6/24
Same thread but on page 16, he only had ~100 miles, but there are people with over 1k miles with same issues.
He got roughly 400 since his last post 4pm "today". Quote:
Regardless, Whiteout-FRS and Stu L Tissimus has gotten the same treatment to their engine (pg 14) - so either they had the same issue or the method to fix 2 problems was identical - who knows. The point being that this needs to be dealt with. Last edited by Bonburner; 06-27-2012 at 02:45 AM. |
#152 | |
EDIT: Seems like this is a different issue though, this is for shuddering and idle RPM issues, neither of these guys say anything about the chirping noise, and the only talk of this noise is being dismissed by people trying to stay on topic. So, different issue, different fix it looks like. :\ Last edited by Fenrir; 06-27-2012 at 03:02 AM. |
#153 |
6/22/12-2/6/24
Yeah I agree its great that there is a means of fixing this issue.
I'm still waiting on some more information/feedback regarding it, but so far Stu L Tissimus said that the engine feels 'more solid' - he has difficulty pointing out what feels better though haha |
#154 |
Frickin' Genius
For those of us that have concerns with our cars, you might find this interesting:
http://www.ft86club.com/forums/showt...458#post241458
Cullen
| Hard shifting into first gear; normal? | blalor | Engine, Exhaust, Transmission | 54 | 08-31-2017 10:57 PM |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 891 | 07-14-2016 11:42 AM |
| What function can it be used for, the idle button place | yuli8466 | Cosmetic Modification (Interior/Exterior/Lighting) | 50 | 01-29-2013 04:17 PM |
| Idle issue poll/role call | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-13-2012 01:00 PM |
| Scion goes normal | terrypm | Other Vehicles & General Automotive Discussions | 21 | 05-02-2012 11:16 AM |
