Old 11-14-2016, 04:25 AM   #3263
nima314
Drives: Subaru BRZ 2017 (almost)
Originally Posted by bored@work84 View Post
later on. right now im just looking into getting tires and getting them on. Thanks for the info
All good, refer to Meaty Tire Thread for more
Sent from my Nexus 6P using Tapatalk
nima314 is offline   Reply With Quote
Old 11-29-2016, 07:33 PM   #3264
Kordless
Drives: '13 BRZ Limited
265/35/18 on 18x9.5+30 SSR SP1 in the rear,
235/40/18 on 18x8.5+30 SSR SP1 in the front
Tires are federal 595rs-rr
i have no LCA and no camber bolts, on TEIN Flex Z
Kordless is offline   Reply With Quote
Old 11-29-2016, 10:48 PM   #3265
Leonardo
Country Boy 4 Life
Leonardo's Avatar
+30. It's going to rub. You need those parts you listed, probably narrower tires. Read through the Meaty tire thread. Low offset wheels are usually running 225/40. 265 tires are usually on +38 offset and higher wheels. I'm not saying it can't be done, be you will need more camber.
On a positive note, I love SSR SP1 wheels!
Good luck!
Old 12-08-2016, 02:05 PM   #3266
ishfaqrubab
Drives: Toyota GT86
rocketbunny wheel fitment crisis!! guys I need some advice!! :'(
ishfaqrubab is offline   Reply With Quote
Old 12-08-2016, 02:10 PM   #3267
Leonardo
Country Boy 4 Life
Leonardo's Avatar
There are a few Rocket bunny threads... Try posting in one of them...
Good luck!
http://www.ft86club.com/forums/showthread.php?t=102357
http://www.ft86club.com/forums/showthread.php?t=74923
Old 12-14-2016, 04:12 PM   #3268
MyGT86Yas
Drives: 2017 WRB BRZ
Just got a set of Advan RG3 18x9.5" 45offset
My car has 1.2" drop in the front and 1" drop in the back.
My goal is to have the 235 or 245? Will these fill the wheels width?
And what tire size fit my set without rubbing? Thank in advance.
MyGT86Yas is offline   Reply With Quote
Old 12-14-2016, 04:26 PM   #3269
Leonardo
Country Boy 4 Life
Leonardo's Avatar
First of all, Welcome to the forum!
With out more info on your car, I would suggest you read page #1 here:
http://www.ft86club.com/forums/showthread.php?t=41083
Good Luck!
Old 12-14-2016, 04:35 PM   #3270
swarb
Are you on springs or coilovers?
Springs, 9.5's don't fit well. You would need spacers.
Coilovers, you are good. 245/35 or 255/35 will fit.
The Following User Says Thank You to swarb For This Useful Post:
Leonardo (12-14-2016)
Old 12-16-2016, 04:11 PM   #3271
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Is anybody running a 17x8.5 +45 up front with -2* camber on oem sized springs/dampers (lowered on springs, bilstein coilovers, etc)?
I have found results of people saying that the set up will fit with minimal camber, but ideally would like to retain as close to -2* camber as possible without running a spacer and not have to switch to new coilover set up.
tire size 245/40/17
asdf is offline   Reply With Quote
Old 12-24-2016, 01:33 PM   #3272
Leonardo
Country Boy 4 Life
Leonardo's Avatar
tire size 245/40/17
You will need a spacer. It is going to rub with those specs. I was running a 18x8+45 with a 245/35. I got a 10mm spacer to add camber bolts. Your wheel is 6.3mm closer to tbe perch/strut than mine. ( before camber) I was about 7mm away before adding camber and the spacers.
This is really useful...
http://www.willtheyfit.com/
I LIKE TIRES!
Old 12-25-2016, 07:31 PM   #3273
MyGT86Yas
Good Luck!
Thanks. Trying to learn/read as much information about the car as possible.
Old 12-25-2016, 07:34 PM   #3274
MyGT86Yas
I just got a set of kw v3 and they don't come with front camber plate.
My goal is to run the 245/35 tires with my 18x9.5 wheels, and I think I will need negative camber for fender clearance? Will I need front camber plates and rear LCA? Thanks.
Old 12-26-2016, 01:31 PM   #3275
swarb
Need is relative. If you want sporty/trackish alignment you will want more camber in the front than in the rear. So you would "need" those parts. If you are fine with rear having more camber and just want to fit the wheels, you are fine.
Old 12-27-2016, 12:57 PM   #3276
MyGT86Yas
Thanks. If I only have budget for one, should I get the front camber plates or the LCA?
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
