Old 11-22-2016, 05:14 PM   #29
Kaotic Lazagna
Drives: GR Corolla
Originally Posted by VeganGirl View Post
I did not get an alignment after putting these rims on, I did get an alignment maybe like a few months before I put them on when I got lowering springs, but that was stock rims and tires. I thought if the car still drove fine I didn't need an alignment. It doesn't veer of to one side or anything.
I will check the direction when I get out of work
Nope. The car can track straight, but your toe specs could be all wrong. That means you'll be scrubbing speed, so that in turns means you'll have to apply more gas to drive the same speed you would otherwise. That also means you'll go through those tires a lot quicker.
Old 11-22-2016, 09:26 PM   #30
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
I don't know the exact specs on my wheel. I know they are 18 inches by 9.5 back and 18 inch by 8.5 front and they are rays gram light 57xtremes. My love drives his car with 11inch tires in the back and kraftwerks c30 and his mileage is 19-20. I hope when I out my edelbrock kit it doesn't drop down to like 15 or something. I live in Florida and I haven't changed my driving habits. Me and bf both drive automatics and daily our cars. I don't really know if anything else that would have caused my mpg to drop so bad cause I only noticed it after putting the rims, but to me they feel almost the same weight as stock or lighter, they don't feel heavier but I could be wrong . I am not mechanically inclined at all soo...
The wheels are definitely heavier. But something most people forget to consider is that the tire you're using for a wider diameter + width wheel is going to be considerably heavier than stock. My guess is that your rolling circumference is larger than stock making it seem like you're getting less mpg - which you should be able to notice easily if your speedo is off. And my other guess is that now that you've got some actual grip you're just driving more aggressively without noticing.
tyler_win_photo is offline   Reply With Quote
Old 11-22-2016, 11:15 PM   #31
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
What change negatively affects mpg? Smaller or larger rolling circumference?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Jajanken86 is offline   Reply With Quote
Old 11-23-2016, 03:32 AM   #32
tyler_win_photo
Larger rolling circumference. Your wheels take less rotations to travel a set distance.
Old 11-23-2016, 05:11 AM   #33
churchx
churchx's Avatar
Drives: 2014 GT86
Larger rolling circumference or in other words bigger wheels imho won't affect mpg THAT much for mpg drop to be of mentioned extent. After all, it's just overall gearing change. People installing FDs for lower gearing didn't had mpg change by 41% even while had gearing changed often more so then if with different wheel size.
Old 11-23-2016, 08:10 AM   #34
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
Originally Posted by df.dima View Post
I was getting close to 27-28 stock as well and with wider/stickier tire I get 24.5 (245 MPSS on x9 light weight wheel). Dipping beyond 20 seems pretty excessive, but depends on the way you drive I guess is possible, or you have some other factor. I can't imagine you drove aggressively and got 28mpg on stock, similarly, I expect you don't drive much different with wider tires now.
This sounds like a more realistic reduction for doing nothing but switching to wider wheels/tires. Something else is going on here.
I guess it depends on how much bigger the wheels are. I assume the odometer counts rotations but I'm not 100% sure on this car. If your wheel/tire diameter is larger than stock, the computer may perceive that you are traveling a shorter distance per rotation of the wheel than you actually are. In other words, it will calculate a stock wheel diameter for each rotation instead of what you have. This could result in erroneous MPG but it would have to be a fairly large difference in wheel size to be that noticeable. For example, if your wheel/tire combo goes from a 20 inch diameter to 21, you're only talking like a 7 inch difference in perceived distance, which is roughly a 5% change.
Yardjass is offline   Reply With Quote
Old 11-23-2016, 01:19 PM   #35
tomaszjanczak
Drives: Silver Subaru BRZ
The major factor affecting MPG is the low rolling resistance of the stock tires.
tomaszjanczak is offline   Reply With Quote
FS: OEM tires and rims - Stock rims and tires Webster10 Wheels and Tires 14 11-16-2015 05:50 PM
Gas mileage decrease on wider tires? donoman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-17-2015 08:54 PM
question on putting my tires in the storage tYtEn86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-15-2014 01:23 PM
Does anyone regret putting stickier tires on? unsurety Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 05-14-2014 03:50 PM
245 or 255 bad tires + light rims = 225 mid-gripy tires + normal rims? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-18-2013 02:33 PM
