Old 11-22-2016, 02:47 AM   #29
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
It will be pretty hard to get an answer. JRZ support and knowledge of the 86 platform is very good.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 11-22-2016, 11:21 AM   #30
Racecomp Engineering
That's basically it.
Both companies have great support stateside, but there are a good amount of 86 drivers running JRZ and a couple shops with JRZ experience on this platform in the USA. I can pick up the phone and call Bryan at JRZ to talk tuning and get his input on whatever. We can help you set up the car (and so can a few other shops)...all the homework has been done.
As far as I know, there aren't any shops with first hand experience with the Bilstein MDS in the USA. Bilstein always provides good support, but it likely won't be specific to the 86 platform. You'll still have a lot of rebuild/revalve options but these are motorsports shocks that are basically intended to be used by a race team with a suspension engineer who might even be revalving them himself.
You can't go wrong with either, but you have a little more work to do with the Bilsteins.
- Andrew
Old 11-22-2016, 08:56 PM   #31
86Tony
Drives: 2015 AOZORA EDITION
- Andrew
thanks for your reply, i ended up goin with the bilstein MDS 2way hope these wont dissapoint. i do have TMG 86 cup car setup specs so it should help put me in the right direction.
86Tony is offline   Reply With Quote
Old 11-23-2016, 03:54 AM   #32
ajc209
Drives: GT86 Cosworth
I was as going to say, the mostly likely reason these have been released if the fact that they were developed with TMG for the CS-V3 Cup cars in Germany. So they have had some R&D.
ajc209 is offline   Reply With Quote
Old 11-23-2016, 04:02 AM   #33
MaximeT
MaximeT's Avatar
We cant wait for your feedback
You went for the 13/16k spring rate ?
Old 11-23-2016, 04:55 AM   #34
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
......but there are a good amount of 86 drivers running JRZ and a couple shops with JRZ experience on this platform in the USA..........
As far as I know, there aren't any shops with first hand experience with the Bilstein MDS in the USA..........
You won't truly appreciate local support until you need it.
Old 11-23-2016, 05:36 PM   #35
86Tony
will be running 10 12k as a few guys told me i need slicks for that higher rate
Old 11-24-2016, 03:06 AM   #36
MaximeT
MaximeT's Avatar
I use 10/12 with JRZ 12-32 and 245 40 17 AD08R.
It's very good.
I'll soon switch to 230 610 17 A005 slicks. I have the feeling I will need more sway bar.
Old 11-28-2016, 08:45 PM   #37
86Tony
Originally Posted by NA 86 View Post
I will soon be running the MDS and my buddy just got the JRZ so we will soon be able to compare since we are in same class with similar setups.
Sent from my iPhone using Tapatalk Pro
very intrested to see results. also good to know another memeber will be running the mds aswell. i keep hearing that these are very similar to jrz but will have less rebuild times
Old 02-18-2017, 05:22 PM   #38
86Tony
Recieved my mds, will let you guys kno how they are when tracks open up
Old 02-19-2017, 03:53 AM   #39
churchx
churchx's Avatar
Drives: 2014 GT86
Ooh. Do review thoroughly.
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 11:22 AM
Bilstein b14's vs KW ST. Bongertz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-13-2014 02:36 AM
WTB: Used Bilstein B14 or B16 InvalidJohnny5 Brakes, Suspension, Chassis 0 03-11-2014 10:40 AM
Bilstein I-RC C3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-16-2013 11:45 AM
bilstein PSS mokinbird87 Southern California 1 10-29-2013 10:12 PM
